龙人旗下深圳市龙芯世纪科技有限公司
  • AT25020A 2Kbit,SPI接口串行EEPROM存储器
  • 发布时间:2009/8/14 11:34:04   修改时间:2009/8/14 11:34:04 浏览次数:1228
    Density 2K
    Interface Type SPI
    Organization 256 x 8
    Vcc (V) 2.7
    Packages PDIP 8
    SOIC 8
    Pb-Free
    Packages
    TSSOP 8
    PDIP 8
    SOIC 8
    2Kbit, SPI Bus Serial Automotive EEPROM, supports Mode 0 and 3 operation.
    The AT25010A/020A/040A provides 1024/2048/4096 bits of serial electrically-erasable programmable read-only memory (EEPROM) organized as 128/256/512 words of 8 bits each. The device is optimized for use in many automotive applications where low-power and low-voltage operation are essential. The AT25010A/020A/040A is available in space-saving 8-lead JEDEC SOIC and 8-lead TSSOP packages. The AT25010A/020A/040A is enabled through the Chip Select pin (CS) and accessed via a three-wire interface consisting of Serial Data Input (SI), Serial Data Output (SO), and Serial Clock (SCK). All programming cycles are completely self-timed, and no separate erase cycle is required before write. Block write protection is enabled by programming the status register with one of four blocks of write protection. Separate program enable and program disable instructions are provided for additional data protection. Hardware data protection is provided via the WP pin to protect against inadvertent write attempts. The HOLD pin may be used to suspend any serial communication without resetting the serial sequence.
    AT25020A 特性
    • Serial Peripheral Interface (SPI) Compatible
    • Supports SPI Modes 0 (0,0) and 3 (1,1)
      – Data Sheet Describes Mode 0 Operation
    • Medium-voltage and Standard-voltage Operation
      – 2.7 (VCC = 2.7V to 5.5V)
    • Extended Temperature Range ?40°C to +125°C
    • 5.0 MHz Clock Rate
    • 8-byte Page Mode
    • Block Write Protection
      – Protect 1/4, 1/2, or Entire Array
    • Write Protect (WP) Pin and Write Disable Instructions for Both Hardware and Software Data Protection
    • Self-timed Write Cycle (10 ms max)
    • High Reliability
      – Endurance: One Million Write Cycles
      – Data Retention: 100 Years
    • 8-lead JEDEC SOIC and 8-lead TSSOP Packages
    AT25020A 订货型号
    Ordering Code Package Operation Range
    AT25010AN-10SQ-2.7
    AT25010A-10TQ-2.7
    8S1
    8A2
    Lead-free/Halogen-free/
    Automotive Temperature
    (–40°C to 125°C)
    AT25020AN-10SQ-2.7
    AT25020A-10TQ-2.7
    8S1
    8A2
    AT25040AN-10SQ-2.7
    AT25040A-10TQ-2.7
    8S1
    8A2
    AT25020A 技术支持
    1. ATMEL 爱特梅尔汽车级EEPROM存储器AT25020A 数据手册DataSheet 下载. PDF(完整版)
    2. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. 中文版ATMEL 汽车应用解决方案 . pdf
    4. 英文版ATMEL 汽车应用解决方案 . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
