龙人旗下深圳市龙芯世纪科技有限公司
  • AT25128A 128Kbit,SPI接口串行EEPROM存储器
  • 发布时间:2009/8/14 11:38:04   修改时间:2009/8/14 11:38:04 浏览次数:1348
    Density 128K
    Interface Type SPI
    Organization 16384 x 8
    Vcc (V) 2.7
    Packages TSSOP 8
    PDIP 8
    SOIC 8
    Pb-Free
    Packages
    TSSOP 8
    PDIP 8
    SOIC 8
    128Kbit, SPI Bus Serial Automotive EEPROM, supports Mode 0 and 3 operation.
    The AT25128A/256A provides 131,072/262,144 bits of serial electrically-erasable programmable read-only memory (EEPROM) organized as 16,384/32,768 words of 8 bits each. The device is optimized for use in many industrial and automotive applications where low-power and low-voltage operation are essential. The devices are available in space-saving 8-lead JEDEC SOIC and 8-lead TSSOP packages. The AT25128A/256A is enabled through the Chip Select pin (CS) and accessed via a three-wire interface consisting of Serial Data Input (SI), Serial Data Output (SO), and Serial Clock (SCK). All programming cycles are completely self-timed, and no separate erase cycle is required before write.
    AT25128A 特性
    • Serial Peripheral Interface (SPI) Compatible
    • Supports SPI Modes 0 (0,0) and 3 (1,1)
      – Data Sheet Describes Mode 0 Operation
    • Standard-voltage Operation
      – 2.7 (VCC = 2.7V to 5.5V)
    • Automotive Temperature Range ?40°C to +125°C
    • 5 MHz Clock Rate
    • 64-byte Page Mode and Byte Write Operation
    • Block Write Protection
      – Protect 1/4, 1/2, or Entire Array
    • Write Protect (WP) Pin and Write Disable Instructions for both Hardware and Software Data Protection
    • Self-timed Write Cycle (5 ms max)
    • High Reliability
      – Endurance: 1 Million Write Cycles
      – Data Retention: >100 Years
    • 8-lead JEDEC SOIC and 8-lead TSSOP Packages
    AT25128A 订货型号
    Ordering Code Package Operation Range
    AT25128AN-10SQ-2.7
    AT25128A-10TQ-2.7
    8S1
    8A2
    Lead-free/Halogen-free/
    (–40°C to 125°C)
    AT25256AN-10SQ-2.7
    AT25256A-10TQ-2.7
    8S1
    8A2
    AT25128A 技术支持
    1. ATMEL 爱特梅尔汽车级EEPROM存储器AT25128A 数据手册DataSheet 下载. PDF(完整版)
    2. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. 中文版ATMEL 汽车应用解决方案 . pdf
    4. 英文版ATMEL 汽车应用解决方案 . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
