龙人旗下深圳市龙芯世纪科技有限公司
  • AT93C46A 2Kbit,3线串行EEPROM存储器
  • 发布时间:2009/8/14 11:40:35   修改时间:2009/8/14 11:40:35 浏览次数:1099
    Density 2K
    Interface Type 3-WIRE
    Organization 64 x 16
    Vcc (V) 2.7
    Packages TSSOP 8
    SOIC 8
    Pb-Free
    Packages
    TSSOP 8
    PDIP 8
    SOIC 8
    1Kbit, 3-wire Bus Serial Automotive EEPROM, supports x16 data format memory organization.
    The AT93C46A provides 1024 bits of serial electrically-erasable programmable read-only memory (EEPROM) organized as 64 words of 16 bits each. The device is optimized for use in many automotive applications where low-power and low-voltage operation are essential. The AT93C46A is available in space-saving 8-lead JEDEC SOIC and 8-lead TSSOP packages. The AT93C46A is enabled through the Chip Select pin (CS) and accessed via a three-wire serial interface consisting of Data Input (DI), Data Output (DO), and Shift Clock (SK). Upon receiving a Read instruction at DI, the address is decoded and the data is clocked out serially on the data output pin DO. The write cycle is completely self-timed and no separate erase cycle is required before write. The write cycle is only enabled when the part is in the erase/write enable state. When CS is brought high following the initiation of a write cycle, the DO pin outputs the ready/busy status of the part. The AT93C46A is available in 2.7V to 5.5V versions.
    AT93C46A 特性
    • Low-voltage and Standard-voltage Operation
      –2.7 (VCC = 2.7V to 5.5V)
    • Three-wire Serial Interface
    • 2 MHz Clock Rate Compatibility
    • Self-timed Write Cycle (10 ms max)
    • High Reliability
      –Endurance: 1 Million Write Cycles
      –Data Retention: 100 Years
    • Lead-free/Halogen-free Devices Available
    • 8-lead JEDEC SOIC and 8-lead TSSOP Packages
    AT93C46A 订货型号:
    Ordering Code Package Operation Range
    AT93C46A-10SQ-2.7
    AT93C46A-10TQ-2.7
    8S1
    8A2
    Automotive Temperature
    (?40°C to 125°C)
    AT93C46A 技术支持:
    1. ATMEL 爱特梅尔汽车级EEPROM 存储器AT93C46A 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. Interfacing AT93CXXX Serial EEPROMs with AT89CX051 MCU (4 pages, updated 10/98)
      This Application Note demonstrates interfacing AT89CX051 Microcontrollers to the AT93CXX 3-Wire type of Serial EEPROMs.
    4. 中文版ATMEL 汽车应用解决方案 . pdf
    5. 英文版ATMEL 汽车应用解决方案 . pdf
    6. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    7. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
