龙人旗下深圳市龙芯世纪科技有限公司
  • AT93C66A 4Kbit,3线串行EEPROM存储器
  • 发布时间:2009/8/14 11:41:41   修改时间:2009/8/14 11:41:41 浏览次数:1284
    Density 4K
    Interface
    Type
    3-WIRE
    Organization 512 x 8 or
    256 x 16
    Vcc (V) 2.7
    Packages TSSOP 8
    SOIC 8
    Pb-Free
    Packages
    TSSOP 8
    PDIP 8
    SOIC 8
    4Kbit, 3-wire Bus Serial Automotive EEPROM with sequential read, supports x8 or x16 data format memory organization.
    The AT93C56A/66A provides 2048/4096 bits of serial electrically-erasable programmable read-only memory (EEPROM). The EEPROM is organized as 128/256 words of 16 bits each when the ORG pin is connected to VCC and 256/512 words of 8 bits each when it is tied to ground. The device is optimized for use in many automotive applications where low-power and low-voltage operations are essential. The AT93C56A/66A is available in space-saving 8-lead JEDEC SOIC and 8-lead TSSOP packages. The AT93C56A/66A is enabled through the Chip Select (CS) pin and accessed via a three-wire serial interface consisting of Data Input (DI), Data Output (DO), and Shift Clock (SK). Upon receiving a Read instruction at DI, the address is decoded and the data is clocked out serially on the data output pin DO. The write cycle is completely self-timed and no separate erase cycle is required before write. The write cycle is only enabled when the part is in the Erase/Write Enable state. When CS is brought high following the initiation of a write cycle, the DO pin outputs the Ready/Busy status of the part. The AT93C56A/66A is available in 2.7V to 5.5V versions.
    AT93C66A 特性
    • Medium-voltage and Standard-voltage Operation
      – 2.7 (VCC = 2.7V to 5.5V)
    • Automotive Temperature Range –40°C to 125°C
    • User-selectable Internal Organization
      – 2K: 256 x 8 or 128 x 16
      – 4K: 512 x 8 or 256 x 16
    • Three-wire Serial Interface
    • Sequential Read Operation
    • 2 MHz Clock Rate
    • Self-timed Write Cycle (10 ms max)
    • High Reliability
      – Endurance: 1 Million Write Cycles
      – Data Retention: 100 Years
    • Lead-free/Halogen-free Devices Available
    • 8-lead JEDEC SOIC and 8-lead TSSOP Packages
    AT93C66A 订货型号:
    Ordering Code Package Operation Range
    AT93C56A-10SQ-2.7
    AT93C56A-10TQ-2.7
    8S1
    8A2
    (?40°C to 125°C)
    AT93C66A-10SQ-2.7
    AT93C66A-10TQ-2.7
    8S1
    8A2
    AT93C66A 技术支持:
    1. ATMEL 爱特梅尔汽车级EEPROM 存储器AT93C66A 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. Interfacing AT93CXXX Serial EEPROMs with AT89CX051 MCU (4 pages, updated 10/98)
      This Application Note demonstrates interfacing AT89CX051 Microcontrollers to the AT93CXX 3-Wire type of Serial EEPROMs.
    4. 中文版ATMEL 汽车应用解决方案 . pdf
    5. 英文版ATMEL 汽车应用解决方案 . pdf
    6. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    7. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
