龙人旗下深圳市龙芯世纪科技有限公司
  • AT25256B 256Kbit,SPI接口串行EEPROM存储器
  • 发布时间:2009/8/14 11:43:27   修改时间:2009/8/14 11:43:27 浏览次数:2880
    Density 256K
    Interface Type SPI
    Organization 32768 x 8
    Pb-Free
    Packages
     PDIP 8
    UDFN 8
     SOIC 8
     SOIC (EIAJ) 8
     TSSOP 8
     dBGA2 8
    256Kbit, SPI Bus Serial EEPROM, High speed, supports Mode 0 and 3.
    The AT25128B/256B provides 131,072/262,144 bits of serial electrically-erasable programmable read only memory (EEPROM) organized as 16,384/32,768 words of 8 bits each. The device is optimized for use in many industrial and commercial applications where low-power and low-voltage operation are essential. The devices are available in space saving 8-lead PDIP, 8-lead EIAJ SOIC, 8-lead JEDEC SOIC, 8-lead TSSOP, 8-ball dBGA2 and 8-lead SAP packages. In addition, the entire family is available in 1.8V (1.8V to 5.5V).
    The AT25128B/256B is enabled through the Chip Select pin () and accessed via a 3-wire interface consisting of Serial Data Input (SI), Serial Data Output (SO), and Serial Clock (SCK). All programming cycles are completely self-timed, and no separate Erase cycle is required before Write.
    AT25256B 特性
    • Serial Peripheral Interface (SPI) Compatible
    • Supports SPI Modes 0 (0,0) and 3 (1,1)
    • Data Sheet Describes Mode 0 Operation
    • Low-voltage and Standard-voltage Operation
      – 1.8 (VCC = 1.8V to 5.5V)
    • 20 MHz Clock Rate (5V)
    • 64-byte Page Mode and Byte Write Operation
    • Block Write Protection
      – Protect 1/4, 1/2, or Entire Array
    • Write Protect (WP) Pin and Write Disable Instructions for Both Hardware and Software Data Protection
    • Self-timed Write Cycle (5 ms Max)
    • High-reliability
      – Endurance: 1 Million Write Cycles
      –Data Retention: >100 Years
    • 8-lead PDIP, 8-lead EIAJ SOIC, 8-lead JEDEC SOIC, 8-lead TSSOP, 8-ball dBGA2 and 8-lead Ultra Thin Mini MAP Packages
    • Lead-free/Halogen-free
    • Available in Automotive
    • Die Sales: Wafer Form, Waffle Pack, and Bumped Die
    AT25256B 订货型号
    Ordering Code Package Voltage
    Range
    Operation Range
    AT25256B-PU
    AT25256BN-SU
    AT25256BW-SU
    AT25256B-TU
    AT25256BU2-UU
    AT25256BY6-YH
    8P3
    8S1
    8S2
    8A2
    8U2-1
    8Y6
    1.8
    1.8
    1.8
    1.8
    1.8
    1.8
    Lead-free/Halogen-free/
    Industrial Temperature
    (?40 to 85°C)
    AT25256B 技术支持
    1. ATMEL 爱特梅尔EEPROM存储器AT25256B 数据手册DataSheet 下载. PDF(完整版)
    2. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. 中文版ATMEL 汽车应用解决方案 . pdf
    4. 英文版ATMEL 汽车应用解决方案 . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
