龙人旗下深圳市龙芯世纪科技有限公司
  • AT24C08B 8Kbit,2线串行EEPROM存储器
  • 发布时间:2009/8/14 12:00:11   修改时间:2009/8/14 12:00:11 浏览次数:1058
    Density 8K
    Interface Type 2-WIRE
    Organization 1024 x 8
    Vcc (V) 1.8
    Pb-Free
    Packages
    WDFN 8
    TSSOP 8
    PDIP 8
    dBGA2 8
    SOIC 8
    SOT23 5
    8Kbit, 2-Wire Bus Serial EEPROM with full memory Write Protect, supports up to 4/2 devices respectively on single 2-Wire bus.
    The AT24C04B/08B provides 4096/8192 bits of serial electrically erasable and programmable read-only memory (EEPROM) organized as 512/1024 words of 8 bits each. The device is optimized for use in many industrial and commercial applications where low-power and low-voltage operation are essential. The AT24C04B/08B is available in space-saving 8-lead PDIP, 8-lead JEDEC SOIC, 8-lead Ultra-Thin Mini-MAP (MLP 2x3), 5-lead SOT23, 8-lead TSSOP, and 8-ball dBGA2 packages and is accessed via a Two-wire serial interface. In addition, the AT24C04B/08B is available in 1.8V (1.8V to 5.5V) version.
    AT24C08B 特性
    • Low-voltage and Standard-voltage Operation
      ─1.8 (VCC = 1.8V to 5.5V)
    • Internally Organized 512 x 8 (4K), or 1024 x 8 (8K)
    • Two-wire Serial Interface<
    • Schmitt Trigger, Filtered Inputs for Noise Suppression
    • Bidirectional Data Transfer Protocol<
    • 1 MHz (5V), 400 kHz (1.8V, 2.5V, 2.7V) Compatibility
    • Write Protect Pin for Hardware Data Protection
    • 16-byte Page (4K, 8K) Write Modes
    • Partial Page Writes Allowed
    • Self-timed Write Cycle (5 ms max)
    • High-reliability
      ─Endurance: 1 Million Write Cycles
      ─Data Retention: 100 Years
    • 8-lead PDIP, 8-lead JEDEC SOIC, 8-lead Ultra-Thin Mini-MAP (MLP 2x3), 5-lead SOT23, 8-lead TSSOP and 8-ball dBGA2 Packages
    • Lead-free/Halogen-free
    • Die Sales: Wafer Form and Tape and Reel
    AT24C08B 订货型号:
    Ordering Code Package Voltage
    Range
    Operation Range
    AT24C08B-PU 8P3 1.8V Lead-free/Halogen-free/
    Industrial Temperature
    (–40°C to 85°C)
    AT24C08BN-SH-B 8S1 1.8V
    AT24C08BN-SH-T 8S1 1.8V
    AT24C08B-TH-B 8A2 1.8V
    AT24C08B-TH-T 8A2 1.8V
    AT24C08BY6-YH-T 8Y6 1.8V
    AT24C08B-TSU-T 5TS1 1.8V
    AT24C08BU3-UU-T 8U3-1 1.8V
    AT24C08B 技术支持:
    1. ATMEL 爱特梅尔EEPROM 存储器AT24C08B 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. AT24系列存储器数据串并转换接口的IP核设计
    3. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    4. Interfacing AT24CXX Serial EEPROMs with AT89CX051 Microcontrollers . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
