龙人旗下深圳市龙芯世纪科技有限公司
  • AT24HC02B 2Kbit,2线串行EEPROM存储器
  • 发布时间:2009/8/14 12:09:11   修改时间:2009/8/14 12:09:11 浏览次数:1310
    Density 2K
    Interface Type 2-WIRE
    Organization 256 x 8
    Vcc (V) 1.7
    Pb-Free
    Packages
     UDFN 8
    SOIC 8
    TSSOP 8
    dBGA2 8
    2Kbit, 2-wire Bus Serial EEPROM with Permanent and Reversible Software Write Protection.
    The AT34C02C provides 2048 bits of serial electrically-erasable and programmable read only memory (EEPROM) organized as 256 words of 8 bits each. The first-half of the device incorporates a permanent and a reversible software write protection feature while hardware write protection for the entire array is available via an external pin.
    Once the permanent software write protection is enabled, by sending a special command to the device, it cannot be reversed. However, the reversible software write protection is enabled and can be reversed by sending a special command. The hardware write protection is controlled with the WP pin and can be used to protect the entire array, whether or not the software write protection has been enabled. This allows the user to protect none, first-half, or all of the array depending on the application.
    The device is optimized for use in many industrial and commercial applications where low-power and low-voltage operations are essential. The AT34C02C is available in space saving 8-lead JEDEC SOIC, 8-lead Ultra Thin Mini-MAP (MLP 2x3), 8-lead TSSOP, and 8-ball dBGA2 packages and is accessed via a Two-wire serial interface.It is available in 1.7V (1.7V to 5.5V).
    AT34C02C 特性
    • Permanent and Reversible Software Write Protection for the First-half of the Array
      – Software Procedure to Verify Write Protect Status
    • Hardware Write Protection for the Entire Array
    • Low-voltage and Standard-voltage Operation
      – 1.7 (VCC = 1.7V to 5.5V)
    • Internally Organized 256 x 8
    • Two-wire Serial Interface
    • Schmitt Trigger, Filtered Inputs for Noise Suppression
    • Bidirectional Data Transfer Protocol
    • 100 kHz (1.7V) and 400 kHz (2.7V and 5.0V) Compatibility
    • 16-byte Page Write Modes
    • Partial Page Writes Are Allowed
    • Self-timed Write Cycle (5 ms max)
    • High-reliability
      – Endurance: 1 Million Write Cycles
      – Data Retention: 100 Years
    • 8-lead JEDEC SOIC, 8-lead Ultra Thin Mini-MAP (MLP 2x3), 8-lead TSSOP, and 8-ball
      dBGA2 Packages
    • Die Sales: Wafer Form, Tape and Reel, and Bumped Wafers
    AT34C02C 订货型号:
    Ordering Code Package Operation Range
    AT34C02CN-SH-B 8S1 Lead-free/Halogen-free/
    Industrial Temperature
    (–40°C to 85°C)
    AT34C02CN-SH-T 8S1
    AT34C02C-TH-B 8A2
    AT34C02C-TH-T 8A2
    AT34C02CY6-YH-T 8Y6
    AT34C02CU3-UU-T 8U3-1
    AT34C02C 技术支持:
    1. ATMEL 爱特梅尔EEPROM 存储器AT34V02C 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. AT24系列存储器数据串并转换接口的IP核设计
    3. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    4. Interfacing AT24CXX Serial EEPROMs with AT89CX051 Microcontrollers . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
