龙人旗下深圳市龙芯世纪科技有限公司
  • AT24C64B 64Kbit,2线串行EEPROM存储器
  • 发布时间:2009/8/14 12:10:12   修改时间:2009/8/14 12:10:12 浏览次数:1251
    Density 64K
    Interface Type 2-WIRE
    Organization 8192 x 8
    Vcc (V) 1.8, 2.7
    Packages  PDIP 8
    SOIC 8
    TSSOP 8
    Pb-Free
    Packages
     PDIP 8
    SOIC 8
    TSSOP 8
    64Kbit, 2 wire Bus Serial EEPROM with 1/4 memory Write Protect, supports up to 8 devices on single 2-Wire bus.
    The AT24C64B provides 65,536 bits of serial electrically erasable and programmable read only memory (EEPROM) organized as 8192 words of 8 bits each. The device’s cascadable feature allows up to 8 devices to share a common 2-wire bus. The device is optimized for use in many industrial and commercial applications where low power and low voltage operation are essential. The AT24C64B is available in space saving 8-lead JEDEC SOIC and 8-lead TSSOP packages and is accessed via a 2-wire serial interface. In addition, the entire family is available in 2.7V (2.7 to 5.5V) and 1.8V (1.8 to 5.5V) versions.
    AT24C64B 特性
    • Low-voltage and Standard-voltage Operation
      – 2.7 (VCC = 2.7 to 5.5V)
      – 1.8 (VCC = 1.8 to 5.5V)
    • Low-power Devices (ISB = 6 μA at 5.5V) Available
    • Internally Organized 8192 x 8
    • 2-Wire Serial Interface
    • Schmitt Trigger, Filtered Inputs for Noise Suppression
    • Bi-directional Data Transfer Protocol
    • 400 kHz Clock Rate
    • Write Protect Pin for Hardware Data Protection
    • 32-Byte Page Write Mode (Partial Page Writes Allowed)
    • Self-Timed Write Cycle (5 ms max)
    • High Reliability
      – Endurance: 1 Million Write Cycles
      – Data Retention: 100 Years
    • Lead-free/Halogen-free Devices Available
    • 8-lead JEDEC SOIC and 8-lead TSSOP Packages
    • Die Sales: Wafer Form, Waffle Pack, and Bumped Wafers
    AT24C64B 订货型号:
    Ordering Code Package Operation Range
    AT24C64BN-10SU-2.7
    AT24C64BN-10SU-1.8
    AT24C64B-10TU-2.7
    AT24C64B-10TU-1.8
    8S1
    8S1
    8A2
    8A2
    Lead-free/Halogen-free/
    Industrial Temperature
    (–40°C to 85°C)
    AT24C64B 技术支持:
    1. ATMEL 爱特梅尔EEPROM 存储器AT24C64B 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. AT24系列存储器数据串并转换接口的IP核设计
    3. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    4. Interfacing AT24CXX Serial EEPROMs with AT89CX051 Microcontrollers . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
