龙人旗下深圳市龙芯世纪科技有限公司
  • AT24C64C 64Kbit,2线串行EEPROM存储器
  • 发布时间:2009/8/14 12:10:40   修改时间:2009/8/14 12:10:40 浏览次数:1276
    Density 64K
    Interface Type 2-WIRE
    Organization 8192 x 8
    Vcc (V) 1.8
    Pb-Free
    Packages
     PDIP 8
    UDFN 8
    SOIC 8
    TSSOP 8
    dBGA2 8
    ULLGA 8
    64Kbit, 2-Wire Bus Serial EEPROM with full memory Write Protect, supports up to 8 devices on single 2-Wire bus.
    The AT24C64C provides 32,768/65,536 bits of serial electrically erasable and programmable read only memory (EEPROM) organized as 4096/8192 words of 8 bits each. The device’s cascadable feature allows up to 8 devices to share a common 2-wire bus. The device is optimized for use in many industrial and commercial applications where low power and low voltage operation are essential. The AT24C64C is available in space saving 8-lead PDIP, 8-lead JEDEC SOIC, 8-lead Ultra Lead Frame Land Grid Array (ULA), 8-lead TSSOP, 8-lead Ultra Thin Mini-MAP (MLP2x3) and, 8- ball dBGA2 packages and is accessed via a 2-wire serial interface. In addition, the entire family is available in 1.8V (1.8 to 5.5V) version.
    AT24C64C 特性
    • Low-voltage and Standard-voltage Operation
      – 1.8 (VCC = 1.8 to 5.5V)
    • Internally Organized 4096 x 8, 8192 x 8
    • 2-Wire Serial Interface
    • Schmitt Trigger, Filtered Inputs for Noise Suppression
    • Bi-directional Data Transfer Protocol
    • 1 MHz (5.0V) and 400 KHz (1.8V Compatibility)
    • Write Protect Pin for Hardware Data Protection
    • 32-Byte Page Write Mode (Partial Page Writes Allowed)
    • Self-Timed Write Cycle (5 ms max)
    • High Reliability
      – Endurance: 1 Million Write Cycles
      – Data Retention: 100 Years
    • Lead-free/Halogen-free Devices
    • 8-lead PDIP, 8-lead JEDEC SOIC, 8-lead Ultra Lead Frame Land Grid Array (ULA), 8-lead TSSOP, 8-lead Ultra Thin Mini-MAP (MLP2x3), and 8-ball dBGA2 Packages.
    • Die Sales: Wafer Form, Waffle Pack, and Bumped Wafers
    AT24C64C 订货型号:
    Ordering Code Package Voltage Operation Range
    AT24C64C-PU
    AT24C64CN-SH-B
    AT24C64CN-SH-T
    AT24C64C-TH-B
    AT24C64C-TH-T
    AT24C64CY6-YH-T
    AT24C64CD3-DH-T
    AT24C64CU2-UU-T
    8P3
    8S1
    8S1
    8A2
    8A2
    8Y6
    8D3
    8U2-1
    1.8V Lead-free/Halogen-free/
    Industrial Temperature
    (–40°C to 85°C)
    AT24C64C 技术支持:
    1. ATMEL 爱特梅尔EEPROM 存储器AT24C64C 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. AT24系列存储器数据串并转换接口的IP核设计
    3. 串行EEPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    4. Interfacing AT24CXX Serial EEPROMs with AT89CX051 Microcontrollers . pdf
    5. 嵌入式系统中EEPROM文件系统的设计与实现 . PDF
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
