龙人旗下深圳市龙芯世纪科技有限公司
  • AT49BV642DT 64Mbit,Flash存储器
  • 发布时间:2009/8/15 10:19:48   修改时间:2009/8/15 10:19:48 浏览次数:1329
    Density 64M
    Organization 4M x 16
    Speed 70 ns
    Vcc (V) 2.7-3.6
    Pb-Free
    Packages
    TSOP 48
    64-Mbit (4M x 16), 2.7-Volt Sectored Flash,Top Boot Block.
    The AT49BV642D(T) is a 2.7-volt 64-megabit Flash memory organized as 4,194,304 words of 16 bits each. The memory is divided into 135 sectors for erase operations. The device can be read or reprogrammed off a single 2.7V power supply, making it ideally suited for in-system programming. To increase the flexibility of the device, it contains an Erase Suspend and Program Suspend feature. This feature will put the erase or program on hold for any amount of time and let the user read data from or program data to any of the remaining sectors. The end of program or erase is detected by Data Polling or toggle bit. The VPP pin provides data protection and faster programming times. When the VPP input is below 0.4V, the program and erase functions are inhibited. When VPP is at 1.65V or above, normal program and erase operations can be performed. With VPP at 10.0V, the program (dual-word program command) operation is accelerated. A six-word command (Enter Single Pulse Program Mode) to remove the requirement of entering the three-word program sequence is offered to further improve programming time. After entering the six-word code, only single pulses on the write control lines are required for writing into the device. This mode (Single Pulse Word Program) is exited by powering down the device, by taking the RESET pin to GND or by a highto- low transition on the VPP input. Erase, Erase Suspend/Resume, Program Suspend/ Resume and Read Reset commands will not work while in this mode; if entered they will result in data being programmed into the device. It is not recommended that the six-word code reside
    AT49BV642DT 特性
    • Single Voltage Operation Read/Write: 2.65V - 3.6V
    • 2.7V - 3.6V Read/Write
    • Access Time – 70 ns
    • Sector Erase Architecture
      – One Hundred Twenty-seven 32K Word Main Sectors with Individual Write Lockout
      – Eight 4K Word Sectors with Individual Write Lockout
    • Fast Word Program Time – 10 μs
    • Typical Sector Erase Time: 32K Word Sectors – 500 ms; 4K Word Sectors – 100 ms
    • Suspend/Resume Feature for Erase and Program
      – Supports Reading and Programming Data from Any Sector by Suspending Erase
      of a Different Sector
      – Supports Reading Any Word by Suspending Programming of Any Other Word
    • Low-power Operation
      – 10 mA Active
      – 15 μA Standby
    • Data Polling and Toggle Bit for End of Program Detection
    • VPP Pin for Write Protection and Accelerated Program Operations
    • RESET Input for Device Initialization
    • Sector Lockdown Support
    • TSOP Package
    • Top or Bottom Boot Block Configuration Available
    • 128-bit Protection Register
    • Common Flash Interface (CFI)
    • Green (Pb/Halide-free) Packaging
    AT49BV642DT 订购型号
    Devices tACC
    (ns)
    ICC (mA) Ordering Code Package Operation Range
    Active Standby
    AT49BV642D 70 15 0.025 AT49BV642D-70TU 48C20 Industrial (-40° to 85° C)
    AT49BV642DT AT49BV642DT-70TU 48C20
    AT49BV642DT 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT49BV642DT 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 并行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
