龙人旗下深圳市龙芯世纪科技有限公司
  • AT29C010A 1Mbit,Flash存储器
  • 发布时间:2009/8/15 10:30:08   修改时间:2009/8/15 10:30:08 浏览次数:2054
    Density 1M
    Organization 128K x 8
    Speed 70, 90 120 ns
    Vcc (V) 4.5-5.5
    Pb-Free Packages TSOP 32
    PLCC 32
    1M bit (128k x 8), 5-Volt Read and 5-Volt Write Flash
    The AT29C010A is a 5-volt-only in-system Flash programmable and erasable read only memory (PEROM). Its 1 megabit of memory is organized as 131,072 words by 8 bits. Manufactured with Atmel’s advanced nonvolatile CMOS technology, the device offers access times to 70 ns with power dissipation of just 275 mW over the industrial temperature range. When the device is deselected, the CMOS standby current is less than 300 μA. The device endurance is such that any sector can typically be written to in excess of 10,000 times. To allow for simple in-system reprogrammability, the AT29C010A does not require high input voltages for programming. Five-volt-only commands determine the operation of the device. Reading data out of the device is similar to reading from an EPROM. Reprogramming the AT29C010A is performed on a sector basis; 128 bytes of data are loaded into the device and then simultaneously programmed. During a reprogram cycle, the address locations and 128 bytes of data are internally latched, freeing the address and data bus for other operations. Following the initiation of a program cycle, the device will automatically erase the sector and then program the latched data using an internal control timer. The end of a program cycle can be detected by DATA polling of I/O7. Once the end of a program cycle has been detected, a new access for a read or program can begin.
    AT29C010A 特性
    • Fast Read Access Time – 70 ns
    • 5-volt Only Reprogramming
    • Sector Program Operation
      – Single Cycle Reprogram (Erase and Program)
      – 1024 Sectors (128 Bytes/Sector)
      – Internal Address and Data Latches for 128 Bytes
    • Two 8K Bytes Boot Blocks with Lockout
    • Internal Program Control and Timer
    • Hardware and Software Data Protection
    • Fast Sector Program Cycle Time – 10 ms
    • DATA Polling for End of Program Detection
    • Low Power Dissipation
      – 50 mA Active Current
      – 300 μA CMOS Standby Current
    • Typical Endurance > 10,000 Cycles
    • Single 5V ± 10% Supply
    • CMOS and TTL Compatible Inputs and Outputs
    • Commercial and Industrial Temperature Ranges
    • Green (Pb/Halide-free) Packaging Option
    AT29C010A 订购型号
    tACC
    (ns)
    ICC (mA) Ordering Code Package Operation Range
    Active Standby
    70 50 0.3 AT29C010A-70JU
    AT29C010A-70TU
    32J
    32T
    Industrial (-40° to 85° C)
    90 50 0.3 AT29C010A-90JU
    AT29C010A-90TU
    32J
    32T
    AT29C010A 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT29C010A 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 并行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT20C010A Reliability Qualification Report (Qualification, 11 pages, updated 7/06) . pdf
    5. AT29 Series Software Chip Erase (4 pages, updated 10/98) . pdf
      This Application Note describes Software Chip Erase for the AT29 Series Flash family.
    6. Atmel AT29 Flash Memories (8 pages, updated 10/98) . pdf
      This Application Note describes Atmel's AT29 Flash Memories.
    7. Programming Atmel's AT29 Flash Family (12 pages, updated 10/98). pdf
      This Application Note describes the design benefits of Atmel's AT29 Flash architecture as well as how the device ID feature is used to adjust for varying densities and supply voltages.
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
