龙人旗下深圳市龙芯世纪科技有限公司
  • AT49F1024A 1Mbit,Flash存储器
  • 发布时间:2009/8/15 10:32:20   修改时间:2009/8/15 10:32:20 浏览次数:1247
    Density 1M
    Organization 64K x 16
    Speed 45 ns
    Vcc (V) 4.5
    Pb-Free
    Packages
    VSOP 40
    1M bit (64K x 16), 5-Volt Read and 5-Volt Write Flash
    The AT49F1024A is a 5-volt-only in-system Flash memory organized as 65,536 words by 16 bits. Manufactured with Atmel’s advanced nonvolatile CMOS technology, the devices offer access times to 45 ns with power dissipation of just 275 mW over the commercial temperature range. When the device is deselected, the CMOS standby current is less than 100 μA. To allow for simple in-system reprogrammability, the AT49F1024A does not require high-input voltages for programming. Five-volt-only commands determine the read and programming operation of the device. Reading data out of the device is similar to reading from an EPROM. Reprogramming the AT49F1024A is performed by erasing a block of data (entire chip or main memory block) and then programming on a word-byword basis. The typical word programming time is a fast 10 μs. The end of a program cycle can be optionally detected by the Data Polling feature. Once the end of a byte program cycle has been detected, a new access for a read or program can begin. The typical number of program and erase cycles is in excess of 10,000 cycles.
    AT49F1024A 特性
    • Single-voltage Operation
      – 5V Read
      – 5V Reprogramming
    • Fast Read Access Time – 45 ns
    • Internal Program Control and Timer
    • 8K Word Boot Block with Lockout
    • Fast Erase Cycle Time – 1.5 seconds
    • Word-by-word Programming – 10 μs/Word Typical
    • Hardware Data Protection、
    • Data Polling for End of Program Detection
    • Small 10 x 14 mm VSOP Package
    • Typical 10,000 Write Cycles
    AT49F1024A 订购型号
    tACC
    (ns)
    ICC (mA) Ordering Code Package Operation Range
    Active Standby
    45 50 0.1 AT49F1024A-45VC 40V Commercial
    (-40° to 85° C)
    AT49F1024A-45VL
    AT49F1024A 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT49F1024A 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 并行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
