龙人旗下深圳市龙芯世纪科技有限公司
  • AT25FS010 1Mbit,SPI接口串行Flash存储器
  • 发布时间:2009/8/17 18:36:10   修改时间:2009/8/17 18:36:10 浏览次数:1290
    1M-bit, SPI Bus Serial Flash, High-speed, Small Sector, SPI Mode 0 and 3.
    The AT25FS010 provides 1,048,576 bits of serial reprogrammable Flash memory organized as 131,072 words of 8 bits each. The device is optimized for use in many industrial and commercial applications where low-power and low-voltage operation are essential. The AT25FS010 is available in a space-saving 8-lead JEDEC SOIC and 8-lead Ultra Thin SAP packages.
    AT25FS010 特性
    • Serial Peripheral Interface (SPI) Compatible
    • Supports SPI Modes 0 (0,0) and 3 (1,1)
      – Datasheet describes Mode 0 Operation
    • 50 MHz Clock Rate
    • Byte Mode and Page Mode Program (1 to 256 Bytes) Operations
    • Sector/Block/Page Architecture
      – 256 byte Pages per Sector
      – Eight 4 Kbyte Sectors per Block
      – Four uniform 32 Kbyte Blocks
    • Self-timed Sector, Block and Chip Erase
    • Product Identification Mode with JEDEC Standard
    • Low-voltage Operation
      – 2.7V (VCC = 2.7V to 3.6V)
    • Hardware and Software Write Protection
      – Device protection with Write Protect (WP) Pin
      – Write Enable and Write Disable Instructions
      – Software Write Protection:
    • Upper 1/32, 1/16, 1/8, 1/4, 1/2 or Entire Array
    • Flexible Op Codes for Maximum Compatibility
    • Self-timed Program Cycle
      – 30 μs/Byte Typical
    • Single Cycle Reprogramming (Erase and Program) for Status Register
    • High Reliability
      – Endurance: 10,000 Write Cycles Typical
    • 8-lead JEDEC 150mil SOIC and 8-lead Ultra Thin Small Array Package (SAP)
    • Die Sales: Waffer Form, Tape and Reel, and Bumped Waffers
    AT25FS010 订购型号
    Ordering Code Package Operation Range
    AT25FS010N-SH27-B 8S1 Lead-Free/Halogen-Free/
    NiPdAu Lead Finish Industrial Temperature
    (–40°C to 85°C)
    AT25FS010Y7-YH27-T 8Y7
    AT25FS010N-SH27-T 8S1
    AT25FS010 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT25FS010 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
