龙人旗下深圳市龙芯世纪科技有限公司
  • AT25F512A 512Kbit,SPI接口串行Flash存储器
  • 发布时间:2009/8/17 18:36:47   修改时间:2009/8/17 18:36:47 浏览次数:1060
    Density 512K
    Interface Type SPI
    Organization 65,536 x 8
    Vcc (V) 2.7
    Pb-Free Packages SOIC (150mil)8
    For new designs use AT25F512B. 512K-bit, SPI Bus Serial Flash, High Speed, SPI Mode 0 and 3.
    The AT25F512A provides 524,288 bits of serial reprogrammable Flash memory organized as 65,536 words of 8 bits each. The device is optimized for use in many industrial and commercial applications where low-power and low-voltage operation are essential. The AT25F512A is available in a space-saving 8-lead JEDEC SOIC and 8-lead SAP packages.
    The AT25F512A is enabled through the Chip Select pin (CS) and accessed via a three-wire interface consisting of Serial Data Input (SI), Serial Data Output (SO), and Serial Clock (SCK). All write cycles are completely self-timed. Block write protection for the entire memory array is enabled by programming the status register. Separate write enable and write disable instructions are provided for additional data protection. Hardware data protection is provided via the Write Protect (WP) pin to protect against inadvertent write attempts to the status register. The HOLD pin may be used to suspend any serial communication without resetting the serial sequence.
    AT25F512A 特性
    • Serial Peripheral Interface (SPI) Compatible
    • Supports SPI Modes 0 (0,0) and 3 (1,1)
      – Datasheet Describes 0 Operation
    • 33 MHz Clock Rate
    • Byte Mode and 128-byte Page Mode for Program Operations
    • Sector Architecture:
      – Two Sectors with 32K Bytes Each
      – 256 Pages per Sector
    • Product Identification Mode
    • Low-voltage Operation
      – 2.7 (VCC = 2.7 to 3.6V)
    • Sector Write Protection
    • Write Protect (WP) Pin and Write Disable Instructions for both Hardware and Software Data Protection
    • Self-timed Program Cycle (75 μs/byte typical)
    • Self-timed Sector Erase Cycle (1 second/sector typical)
    • Single Cycle Reprogramming (Erase and Program) for Status Register
    • High Reliability
      – Endurance: 10,000 Write Cycles Typical
      – Data Retention: 20 Years
    • 8-lead JEDEC SOIC and 8-lead SAP Packages
    AT25F512A 订购型号
    Ordering Code Package Operation Range
    AT25F512AN-10SH-2.7
    AT25F512AY4-10YH-2.7
    8S1
    8Y4
    Lead-free/Halogen-free/NiPdAu Lead Finish
    Industrial Temperature (?40 to 85°C)
    AT25F512B 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT25F512A 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT25F512A Reliability Qualification Report (Qualification, 4 pages, updated 8/05)
    5. Programmer Support for Serial Flash Devices (Other, 8 pages, revision C, updated 4/08)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
