龙人旗下深圳市龙芯世纪科技有限公司
  • 汽车级 ATtiny24-15MZ带有2K系统内可编程Flash存储器QFN-20封装
  • 发布时间:2009/8/18 18:06:04   修改时间:2009/8/18 18:06:04 浏览次数:1030
    Flash (Kbytes)   2
    EEPROM (Kbytes)   0.125
    SRAM (Bytes)   128
    Max I/O Pins   12
    F.max (MHz)   16
    Vcc (V)   2.7-5.5
    16-bit Timers   1
    8-bit Timer   1
    PWM (channels)   4
    SPI   USI
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   8
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   17
    Ext Interrupts   12
    Self Program Memor   Yes
    Pb-Free Packages VQFN (Sawn) 20
    PDIP 14
    2K Bytes of In-System Self-Programmable Flash, 128 Bytes In-System Programmable EEPROM, 128 Bytes Internal SRAM. 8-bit and 16-bit timer/counters with PWM, 10-bit ADC, USI-Universal Serial Interface, On-chip Temperature Sensor. debugWIRE for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 V operation.
    The ATtiny24/44/84 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny24/44/84 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny24-15MZ 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 120 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
    • Non-Volatile Program and Data Memories
      – 2/4/8K Bytes of In-System Programmable Program Memory Flash
    • Endurance: 10,000 Write/Erase Cycles
      – 128/256/512 Bytes of In-System Programmable EEPROM
    • Endurance: 100,000 Write/Erase Cycles
      – 128/256/512 Bytes of Internal SRAM
      – Data retention: 20 years at 85°C / 100 years at 25°C
      – Programming Lock for Self-Programming Flash & EEPROM Data Security
    • Peripheral Features
      – One 8-Bit and One 16-Bit Timer/Counter with Two PWM Channels, Each
      – 10-bit ADC
    • 8 Single-Ended Channels
    • 12 Differential ADC Channel Pairs with Programmable Gain (1x / 20x)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-Chip Analog Comparator
      – Universal Serial Interface
    • Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – Internal and External Interrupt Sources: Pin Change Interrupt on 12 Pins
      – Low Power Idle, ADC Noise Reduction, Standby and Power-Down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-Out Detection Circuit
      – Internal Calibrated Oscillator
      – On-Chip Temperature Sensor
    • I/O and Packages
      – Available in 20-Pin QFN/MLF & 14-Pin SOIC and PDIP
      – Twelve Programmable I/O Lines
    • Operating Voltage:
      – 1.8 – 5.5V for ATtiny24V/44V/84V
      – 2.7 – 5.5V for ATtiny24/44/84
    • Speed Grade
      – ATtiny24V/44V/84V
    • 0 – 4 MHz @ 1.8 – 5.5V
    • 0 – 10 MHz @ 2.7 – 5.5V
      – ATtiny24/44/84
    • 0 – 20 MHz @ 4.5 – 5.5V
    • Industrial Temperature Range: -40°C to +85°C
    • Low Power Consumption
      – Active Mode (1 MHz System Clock): 300 μA @ 1.8V
      – Power-down Mode: 0.1 μA @ 1.8V
    ATtiny24-15MZ 汽车级订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    16 2.7 - 5.5V ATtiny24-15SSZ TU Automotive (-40° to +125°C)
    16 2.7 - 5.5V ATtiny24-15MZ PC Automotive (-40° to +125°C)
    ATtiny24-15MZ 技术支持
    1. ATtiny24 数据手册DataSheet 在线下载(简洁版)
    2. ATtiny24 数据手册DataSheet 在线下载(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF
    4. 面向新手的AVR开发工具,及基本知识.PDF
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
