龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny25V-10SSU 带有2K系统内可编程Flash存储器SOIC-8封装 (208mil
  • 发布时间:2009/8/18 18:08:01   修改时间:2009/8/18 18:08:01 浏览次数:1494
  • ATtiny25V-10SSU 带有2K系统内可编程Flash存储器SOIC-8封装 (208mil)
    Flash (Kbytes)   2
    EEPROM (Kbytes)   0.125
    SRAM (Bytes)   128
    Max I/O Pins   6
    F.max (MHz)   20
    Vcc (V)   1.8-5.5
    8-bit Timer   2
    PWM (channels)   4
    SPI   USI
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   4
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   15
    Ext Interrupts   7
    Self Program Memor   Yes
    Pb-Free Packages   PDIP 8
    MLF (WQFN) 20
    SOIC (150mil) 8
    SOIC (208mil) 8
    2K Bytes of In-System Self-Programmable Flash, 128 Bytes In-System Programmable EEPROM, 128 Bytes Internal SRAM. Two 8-bit timer/counters with PWM and prescaler, 10-bit ADC, USI-Universal Serial Interface. debugWIRE for on-chip-debug. Up to 20 MIPS throughput at 20 MHz. 1.8 - 5.5 V operation.
    The ATtiny25/45/85 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny25/45/85 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny25V-10SSU 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 120 Powerful Instructions
      – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
    • Non-volatile Program and Data Memories
      – 4K Byte of In-System Programmable Program Memory Flash (ATtiny25)
    • Endurance: 10,000 Write/Erase Cycles
      – 256 Bytes In-System Programmable EEPROM (ATtiny25)
    • Endurance: 100,000 Write/Erase Cycles
      – 256 Bytes Internal SRAM (ATtiny25)
      – Programming Lock for Self-Programming Flash Program and EEPROM Data Security
    • Peripheral Features
      – 8-bit Timer/Counter with Prescaler and Two PWM Channels
      – 8-bit High Speed Timer/Counter with Separate Prescaler
    • 2 High Frequency PWM Outputs with Separate Output Compare Registers
    • Programmable Dead Time Generator
      – USI – Universal Serial Interface with Start Condition Detector
      – 10-bit ADC
    • 4 Single Ended Channels
    • 2 Differential ADC Channel Pairs with Programmable Gain (1x, 20x)Temperature Measurement
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
    • Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – External and Internal Interrupt Sources
      – Low Power Idle, ADC Noise Reduction, and Power-down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-out Detection Circuit
      – Internal Calibrated Oscillator
    • I/O and Packages
      – Six Programmable I/O Lines
      – 8-pin PDIP, 8-pin SOIC and 20-pad QFN/MLF
    • Operating Voltage
      – 1.8 - 5.5V for ATtiny25V
      – 2.7 - 5.5V for ATtiny25
    • Speed Grade
      – ATtiny25V: 0 - 4 MHz @ 1.8 - 5.5V, 0 - 10 MHz @ 2.7 - 5.5V
      – ATtiny25: 0 - 10 MHz @ 2.7 - 5.5V, 0 - 20 MHz @ 4.5 - 5.5V
    • Industrial Temperature Range
    • Low Power Consumption
      – Active Mode:
    • 1 MHz, 1.8V: 300 μA
      – Power-down Mode:
    • 0.1μA at 1.8V
    ATtiny25V-10SSU 相关订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    10 1.8 - 5.5V ATtiny25V-10PU
    ATtiny25V-10SU
    ATtiny25V-10SSU
    ATtiny25V-10MU
    8P3
    8S2
    S8S1
    20M1
    Industrial (-40°C to 85°C)
    20 2.7 - 5.5V ATtiny25-20PU
    ATtiny25-20SU
    ATtiny25-20SSU
    ATtiny25-20MU
    8P3
    8S2
    S8S1
    20M1
    ATtiny25-20SU 汽车级订购型号
    Power Supply Speed (MHz) Ordering Code Package Operation Range
    2.7 - 5.5V 8 - 16 ATtiny25-15ST
    ATtiny25-15ST1
    ATtiny25-15SZ
    T5 Automotive (-40°C to +85°C)
    Automotive (-40°C to +105°C)
    Automotive (-40°C to 125°C)
    2.7 - 5.5V 8 - 16 ATtiny25-15MT
    ATtiny25-15MT1
    ATtiny25-15MZ
    PC Automotive (-40°C to 85°C)
    Automotive (-40°C to +125°C)
    ATtiny25V-10SSU 技术支持
    1. ATtiny25 数据手册DataSheet 在线下载(简洁版DataSheet据数手册)
    2. ATtiny25 数据手册DataSheet 在线下载(完整版DataSheet据数手册)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF
    4. 面向新手的AVR开发工具,及基本知识.PDF
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 汽车应用相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
    11. 8-bit Microcontroller Drives Battery-powered Thermostat (Article, 2 pages, updated 1/04)
    12. Algorithm Builder for AVR (Article, 2 pages, updated 1/04)
    13. Atmel AVR-based Constant Current Supply (Article, 4 pages, updated 1/04)
    14. Atmel Motor Driver Solutions (Brochure, 16 pages, revision A, updated 10/08)
    15. Heterogeneous Device Networking (Article, 2 pages, updated 1/04)
    16. High-level Tool Targeted for AVR Controllers (Article, 2 pages, updated 1/04)
    17. Mixed-signal ICs for Body and Powertrain Electronics (Brochure, 20 pages, revision C, updated 07/07)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
