龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny861V-10SU 带有8K系统内可编程Flash存储器SOIC-20封装
  • 发布时间:2009/8/19 9:46:02   修改时间:2009/8/19 9:46:02 浏览次数:1075
    Flash (Kbytes)   8
    EEPROM (Kbytes)   0.5
    SRAM (Bytes)   512
    Max I/O Pins   16
    F.max (MHz)   16
    Vcc (V)   2.7 - 5.5
    16-bit Timers   1
    8-bit Timer   2
    PWM (channels)   2
    SPI   Yes
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   11
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   19
    Ext Interrupts   2
    Self Program Memor   Yes
    Pb-Free Packages     VQFN (Sawn) 32
     SOIC 20
    8K Bytes of In-System Self-Programmable Flash, 512 Bytes In-System Programmable EEPROM, 512 Bytes Internal SRAM. One 8/16-bit timer/counter with PWM and prescaler, one 8/10-bit High-speed timer/counter with PWM and separate prescaler, 10-bit ADC, USI-Universal Serial Interface. debugWIRE for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 V operation.
    • 2KB 系统内可编程Flash存储器:ATtiny261
    • 4KB 系统内可编程Flash存储器:ATtiny461
    • 8KB 系统内可编程Flash存储器:ATtiny861
    The ATtiny261/461/861 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny261/461/861 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny861V-10SU 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 123 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
    • Non-volatile Program and Data Memories
      – 2/4/8K Byte of In-System Programmable Program Memory Flash
      (ATtiny261/461/861)
      Endurance: 10,000 Write/Erase Cycles
      – 128/256/512 Bytes In-System Programmable EEPROM (ATtiny261/461/861)
      Endurance: 100,000 Write/Erase Cycles
      – 128/256/512 Bytes Internal SRAM (ATtiny261/461/861)
      – Programming Lock for Self-Programming Flash Program and EEPROM Data
      Security
    • Peripheral Features
      – 8/16-bit Timer/Counter with Prescaler and Two PWM Channels
      – 8/10-bit High Speed Timer/Counter with Separate Prescaler
      3 High Frequency PWM Outputs with Separate Output Compare Registers
      Programmable Dead Time Generator
      – Universal Serial Interface with Start Condition Detector
      – 10-bit ADC
      11 Single Ended Channels
      16 Differential ADC Channel Pairs
      15 Differential ADC Channel Pairs with Programmable Gain (1x, 8x, 20x, 32x)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
    • Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – External and Internal Interrupt Sources
      – Low Power Idle, ADC Noise Reduction, and Power-down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-out Detection Circuit
      – Internal Calibrated Oscillator
    • I/O and Packages
      – 16 Programmable I/O Lines
      – 20-pin PDIP, 20-pin SOIC and 32-pad MLF
    • Operating Voltage:
      – 1.8 - 5.5V for ATtiny261V/461V/861V
      – 2.7 - 5.5V for ATtiny261/461/861
    • Speed Grade:
      – ATtiny261V/461V/861V: 0 - 4 MHz @ 1.8 - 5.5V, 0 - 10 MHz @ 2.7 - 5.5V
      – ATtiny261/461/861: 0 - 10 MHz @ 2.7 - 5.5V, 0 - 20 MHz @ 4.5 - 5.5V
    • Industrial Temperature Range
    • Low Power Consumption
      – Active Mode: 1 MHz, 1.8V: 380μA
      – Power-down Mode: 0.1μA at 1.8V
    ATtiny861V-10SU 汽车级订购型号
    Ordering Code Speed (MHz) Power Supply Package Operational Range
    ATtiny861-15SZ 16 2.7-5.5V TG Automotive(-40°to+125°C)
    ATtiny861-15MZ 16 2.7-5.5V PN Automotive(-40°to+125°C)
    ATtiny861-15XZ 16 2.7-5.5V 6G Automotive(-40°to+125°C)
    ATtiny861V-10SU 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    10 1.8-5.5V ATtiny861V-10MU
    ATtiny861V-10PU
    ATtiny861V-10SU
    32M1-A
    20P3
    20S2
    Industrial (-40°C to 85°C)
    20 2.7-5.5V ATtiny861-20MU
    ATtiny861-20PU
    ATtiny861-20SU
    32M1-A
    20P3
    20S2
    ATtiny861V-10SU 技术支持
    1. ATMEL 爱特梅尔汽车级AVR 微控制器ATtiny861 数据手册DataSheet 下载. PDF(完整版)
    2. ATMEL 爱特梅尔汽车级AVR 微控制器ATtiny861 数据手册DataSheet 下载.PDF(简洁版)
    3. ATMEL 爱特梅尔汽车级AVR 微控制器ATtiny861 数据手册DataSheet 下载.PDF(附录)
    4. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    5. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    6. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    7. AVR指令集(版本:0856G–AVR–07/08)
    8. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    9. AVR 微控制器汽车应用解决方案 . pdf
    10. AVR 微控制器选型指南. pdf
    11. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
