龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega32M1 汽车级带有32K系统内可编程Flash存储器
  • 发布时间:2009/8/22 9:54:52   修改时间:2009/8/22 9:54:52 浏览次数:989
    Flash (Kbytes) 32
    EEPROM (Kbytes) 1
    SRAM (Bytes) 2048
    Max I/O Pins 27
    F.max (MHz) 16
    Vcc (V) 2.7 - 5.5
    10-bit A/D Channels 11
    Analog Comparator 4
    16-bit Timers Yes
    8-bit Timer Yes
    Brown Out Detector Yes
    Ext Interrupts 4
    Hardware Multiplier Yes
    Interrupts 31
    On Chip Oscillator Yes
    PWM Channels 10
    Self Program Memory Yes
    SPI Yes
    TWI Yes
    UART 1
    Watchdog Yes
    Pb-Free Packages
    QFP 32
    VQFN (Sawn) 32
    The ATtiny167 provides the following features: 16K byte of In-System Programmable Flash, 512 bytes EEPROM, 512 bytes SRAM, 6 general purpose I/O lines, 32 general purpose working reg-isters, one 8-bit Timer/Counter with compare modes, one 8-bit high speed Timer/Counter, Universal Serial Interface, a LIN controller, Internal and External Interrupts, a 4-channel, 10-bit ADC, a programmable Watchdog Timer with internal Oscillator, and three software selectable power saving modes
    • 32KB 系统内可编程Flash存储器:ATmega32M11
    • 64KB 系统内可编程Flash存储器:ATmega64M1
    • 32KB 系统内可编程Flash存储器:ATmega32C1
    • 64KB 系统内可编程Flash存储器:ATmega64C1
    The ATmega16/32/64/M1/C1 is a low-power CMOS 8-bit microcontroller based on the AVR
    enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the
    ATmega16/32/64/M1/C1 achieves throughputs approaching 1 MIPS per MHz allowing the system
    designer to optimize power consumption versus processing speed.
    ATmega32M1 产品特性
    • High Performance, Low Power AVR ? 8-bit Microcontroller
    • Advanced RISC Architecture
      – 131 Powerful Instructions - Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 1 MIPS throughput per MHz
      – On-chip 2-cycle Multiplier
    • Data and Non-Volatile Program Memory
      – 16K/32K/64K Bytes Flash of In-System Programmable Program Memory
    • Endurance: 10,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits
      – In-System Programming by On-chip Boot Program
    • True Read-While-Write Operation
      – 512/1024/2048 Bytes of In-System Programmable EEPROM
    • Endurance: 50,000 Write/Erase Cycles
    • Programming Lock for Flash Program and EEPROM Data Security
    • 1024/2048/4096 Bytes Internal SRAM
    • On Chip Debug Interface (debugWIRE)
    • CAN 2.0A/B with 6 Message Objects - ISO 16845 Certified (1)
    • LIN 2.1 and 1.3 Controller or 8-Bit UART
    • One 12-bit High Speed PSC (Power Stage Controller) (only ATmega16/32/64M1)
    • Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time
    • Variable PWM duty Cycle and Frequency
    • Synchronous Update of all PWM Registers
    • Auto Stop Function for Emergency Event
    • Peripheral Features
      – One 8-bit General purpose Timer/Counter with Separate Prescaler, Compare Mode
      and Capture Mode
      – One 16-bit General purpose Timer/Counter with Separate Prescaler, Compare
      Mode and Capture Mode
      – One Master/Slave SPI Serial Interface
      – 10-bit ADC
    • Up To 11 Single Ended Channels and 3 Fully Differential ADC Channel Pairs
    • Programmable Gain (5x, 10x, 20x, 40x) on Differential Channels
    • Internal Reference Voltage
    • Direct Power Supply Voltage Measurement
      – 10-bit DAC for Variable Voltage Reference (Comparators, ADC)
      – Four Analog Comparators with Variable Threshold Detection
      – 100μA ±3% Current Source (LIN Node Identification)
      – Interrupt and Wake-up on Pin Change
      – Programmable Watchdog Timer with Separate On-Chip Oscillator
      – On-chipTemperature Sensor
    • Special Microcontroller Features
      – Low Power Idle, Noise Reduction, and Power Down Modes
      – Power On Reset and Programmable Brown Out Detection
      – In-System Programmable via SPI Port
      – High Precision Crystal Oscillator for CAN Operations
    ATmega32M1工业级 订购型号
    Memory Size PSC Power Supply Ordering Code Package Operation Range
    32K No 2.7-5.5V ATmega32M1-15AZ MA -40°C to 125°C
    32K No 2.7-5.5V ATmega32M1-15MZ PV -40°C to 125°C
    32K No 2.7-5.5V ATmega32M1-ESAZ MA Engineering Samples
    32K No 2.7-5.5V ATmega32M1-ESMZ PV Engineering Samples
    ATmega32M1 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATmega32M1 数据手册DataSheet 下载. PDF(简洁版)
    2. ATMEL 爱特梅尔AVR 单片机ATmega32M1 数据手册DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
