龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega169P-15AT 汽车级带有16K系统内可编程Flash存储器TQFP-64封装
  • 发布时间:2009/8/22 10:03:29   修改时间:2009/8/22 10:03:29 浏览次数:1239
    Flash (Kbytes) 16
    EEPROM (Kbytes) 0.5
    SRAM (Bytes) 1024
    Max I/O Pins 54
    F.max (MHz) 16
    Vcc (V) 2.7 - 5.5
    10-bit A/D Channels 8
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 2
    Brown Out Detector Yes
    Ext Interrupts 17
    Hardware Multiplier Yes
    Interrupts 23
    On Chip Oscillator Yes
    PWM Channels 4
    RTC Yes
    Self Program Memory Yes
    SPI Yes
    TWI USI
    UART 1
    Watchdog Yes
    Pb-Free Packages TQFP 64
    16-Kbyte self-programming Flash Program Memory, 1-Kbyte SRAM, 512 Byte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. 4 X 25 Segment LCD Driver. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt Operation.
    The ATmega169P is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executingpowerful instructions in a single clock cycle, the ATmega169P achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega169P-15AT 特性
    • High Performance, Low Power AVR?8-Bit
    • Microcontroller
      - Advanced RISC Architecture
      - 130 Powerful Instructions ?Most Single Clock Cycle Execution
      - 32 x 8 General Purpose Working Registers
      - Fully Static Operation
      - Up to 16 MIPS Throughput at 16 MHz
      - On-Chip 2-cycle Multiplier
    • High Endurance Non-volatile Memory segments
      - 16K Bytes of In-System Self-programmable Flash program memory
      - 512 Bytes EEPROM
      - 1K Bytes Internal SRAM
      - Write/Erase cyles: 10,000 Flash/100,000 EEPROM(1)(3)
      - Data retention: 20 years at 85°C /100 years at 25°C (2)(3)
      - Optional Boot Code Section with Independent Lock Bits
      In-System Programming by On-chip Boot Program
      True Read-While-Write Operation
      - Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 compliant) Interface
      - Boundary-scan Capabilities According to the JTAG Standard
      - Extensive On-chip Debug Support
      - Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • Peripheral Features
      - 4 x 25 Segment LCD Driver
      - Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
      - One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
      Mode
      - Real Time Counter with Separate Oscillator
      - Four PWM Channels
      - 8-channel, 10-bit ADC
      - Programmable Serial USART
      - Master/Slave SPI Serial Interface
      - Universal Serial Interface with Start Condition Detector
      - Programmable Watchdog Timer with Separate On-chip Oscillator
      - On-chip Analog Comparator
      - Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      - Power-on Reset and Programmable Brown-out Detection
      - Internal Calibrated Oscillator
      - External and Internal Interrupt Sources
      - Five Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, and
      Standby
    • I/O and Packages
      - 54 Programmable I/O Lines
      - 64-lead TQFP and 64-pad QFN/MLF
    • Speed Grade:
      - ATmega169PV: 0 - 4 MHz @ 1.8 - 5.5V, 0 - 8 MHz @ 2.7 - 5.5V
      - ATmega169P: 0 - 8 MHz @ 2.7 - 5.5V, 0 - 16 MHz @ 4.5 - 5.5V
    • Temperature range:
      - -40°C to 85°C Industrial
    • Ultra-Low Power Consumption
      - Active Mode:
      1 MHz, 1.8V: 330 μA
      32 kHz, 1.8V: 10 μA (including Oscillator)
      32 kHz, 1.8V: 25 μA (including Oscillator and LCD)
      - Power-down Mode:
      0.1 μA at 1.8V
      - Power-save Mode:
      0.6 μA at 1.8V(Including 32 kHz RTC)
    ATmega169P-15AT 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    8 1.8-5.5V ATmega169PV-8AU
    ATmega169PV-8MU
    64A
    64M1
    Industrial (-40°C to 85°C)
    16 2.7-5.5V ATmega169P-16AU
    ATmega169P-16MU
    64A
    64M1
    ATmega169P-15AT汽车级 订购型号
    16 2.7 - 5.5V ATmega169P-15AT MD Automotive
    (-40°C to 85°C)
    ATmega169P-15AT 技术支持
    1. AVR 单片机ATmega169P 数据手册资料 DataSheet 下载. PDF(简洁版)
    2. AVR 单片机ATmega169P 数据手册资料 DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
