龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega3290-16AI 带有32K系统内可编程Flash存储器TQFP-100封装
  • 发布时间:2009/8/22 10:07:57   修改时间:2009/8/22 10:07:57 浏览次数:1314
    Flash (Kbytes)   32
    EEPROM (Kbytes)   1
    SRAM (Bytes)   2048
    Max I/O Pins   69
    F.max (MHz)   16
    Vcc (V)   1.8-5.5
    16-bit Timers   1
    8-bit Timer   2
    PWM (channels)   4
    RTC   Yes
    SPI   1+USI
    UART   1
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   8
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Hardware Multiplie   Yes
    Interrupts   25
    Ext Interrupts   32
    Self Program Memor   Yes
    Packages     MLF 64
    Pb-Free Packages     TQFP 64
    TQFP 100
    32-Kbyte self-programming Flash Program Memory, 2-Kbyte SRAM, 1-KByte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. 4 X 40 Segment LCD Driver. Up to 16 MIPS throughput at 16 MHz. 1.8 - 5.5 Volt Operation.
    • 32KB 系统内可编程Flash存储器:ATmega329
    • 32KB 系统内可编程Flash存储器:ATmega3290
    • 64KB 系统内可编程Flash存储器:ATmega649
    • 64KB 系统内可编程Flash存储器:ATmega6490
    The ATmega329/3290/649/6490 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture.
    By executing powerful instructions in a single clock cycle, the ATmega329/3290/649/6490 achieves throughputs
    approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega3290-16AI 特性
    • High Performance, Low Power AVR?8-Bit Microcontroller
    • Advanced RISC Architecture
      - 130 Powerful Instructions ?Most Single Clock Cycle Execution
      - 32 x 8 General Purpose Working Registers
      - Fully Static Operation
      - Up to 20 MIPS Throughput at 20 MHz
      - On-Chip 2-cycle Multiplier
    • High Endurance Non-volatile Memory segments
      - 32K Bytes of In-System Self-programmable Flash program memory
      - 1024 Bytes EEPROM
      - 2K Bytes Internal SRAM
      - Write/Erase cyles: 10,000 Flash/100,000 EEPROM(1)(3)
      - Data retention: 20 years at 85°C /100 years at 25°C (2)(3)
      - Optional Boot Code Section with Independent Lock Bits,In-System Programming by On-chip Boot Program
      True Read-While-Write Operation
      - Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 compliant) Interface
      - Boundary-scan Capabilities According to the JTAG Standard
      - Extensive On-chip Debug Support
      - Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • Peripheral Features
      - 4 x 40 Segment LCD Driver (ATmega3290P)
      - Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
      - One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
      Mode
      - Real Time Counter with Separate Oscillator
      - Four PWM Channels
      - 8-channel, 10-bit ADC
      - Programmable Serial USART
      - Master/Slave SPI Serial Interface
      - Universal Serial Interface with Start Condition Detector
      - Programmable Watchdog Timer with Separate On-chip Oscillator
      - On-chip Analog Comparator
      - Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      - Power-on Reset and Programmable Brown-out Detection
      - Internal Calibrated Oscillator
      - External and Internal Interrupt Sources
      - Five Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, and
      Standby
    • I/O and Packages
      - 54/69 Programmable I/O Lines
      - 64-lead TQFP, 64-pad QFN/MLF, and 100-lead TQFP
    • Speed Grade:
      - ATmega3290PV:0 - 4 MHz @ 1.8 - 5.5V, 0 - 10 MHz @ 2.7 - 5.5V
      - ATmega3290P:0 - 10 MHz @ 2.7 - 5.5V, 0 - 20 MHz @ 4.5 - 5.5V
    • Temperature range:-40°C to 85°C Industrial
    • Ultra-Low Power Consumption
      - Active Mode:420°C at 1 MHz, 1.8V
      - Power-down Mode:40 nA at 1.8V
      - Power-save Mode:750 nA at 1.8V
    ATmega3290-16AI 订购型号
    Speed (MHz) Power Supply Ordering Code Package Type Operational Range
    8 1.8 - 5.5V ATmega3290V-8AI
    ATmega3290V-8AU
    100A
    100A
    Industrial
    (-40°C to 85°C)
    16 2.7 - 5.5V ATmega3290-16AI
    ATmega3290-16AU
    100A
    100A
    Industrial
    (-40°C to 85°C)
      ATmega3290-16AI 技术支持
      1. ATmega3290 数据手册DataSheet 下载. PDF(完整版)
      2. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
      3. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
      4. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
      5. AVR指令集(版本:0856G–AVR–07/08)
      6. 相关产品选型Excel 文档格式选型 Excel 文档格式)
      7. AVR 微控制器汽车应用解决方案 . pdf
      8. AVR 微控制器选型指南. pdf
      9. ATMEL 爱特梅尔公司全线产品目录. pdf
    龙人旗下深圳市龙芯世纪科技有限公司
    联系人:BDTIC
    地址:深圳市福田区福虹路世界贸易广场B座12F
    邮编:100089
    电话:0755-83574969
    传真:0755-83778351
    公司网址:http://www.BDTIC.com/IC
    • 李小东 在2023/8/23 0:15:00留言
    • 详细留言:了解产品的合作
    • 徐工 在2022/11/23 15:39:00留言
    • 详细留言:ATMEGA32 TWI硬件从机使用。
    • 徐工 在2022/11/21 9:30:00留言
    • 详细留言:ATMEAG32 硬件11C主从通信
    • 于方元 在2021/7/8 19:21:00留言
    • 详细留言:全以太网工控系统开发。
    • 明小姐 在2015/3/26 16:06:00留言
