龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega649V-8MI 带有64K系统内可编程Flash存储器QFN-64封装
  • 发布时间:2009/8/22 11:01:20   修改时间:2009/8/22 11:01:20 浏览次数:1239
    Flash (Kbytes) 64
    EEPROM (Kbytes) 2
    SRAM (Bytes) 4096
    Max I/O Pins 54
    F.max (MHz) 16
    Vcc (V) 1.8-5.5
    16-bit Timers 1
    8-bit Timer 2
    PWM Channels 4
    RTC Yes
    SPI 1+USI
    UART 1
    TWI USI
    ISP Yes
    10-bit A/D Channels 8
    Analog Comparator Yes
    Brown Out Detector Yes
    Watchdog Yes
    On Chip Oscillator Yes
    Hardware Multiplier Yes
    Interrupts 25
    Ext Interrupts 17
    Self Program Memory Yes
    Pb-Free Packages TQFP 100
    MLF (VQFN) 64
    TQFP 64
    64-Kbyte self-programming Flash Program Memory, 4-Kbyte SRAM, 2-KByte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. 4 X 25 Segment LCD Driver. Up to 16 MIPS throughput at 16 MHz. 1.8 - 5.5 Volt operation.
    • 32KB 系统内可编程Flash存储器:ATmega329
    • 32KB 系统内可编程Flash存储器:ATmega3290
    • 64KB 系统内可编程Flash存储器:ATmega649
    • 64KB 系统内可编程Flash存储器:ATmega6490
    The ATmega329/3290/649/6490 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture.
    By executing powerful instructions in a single clock cycle, the ATmega329/3290/649/6490 achieves throughputs
    approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega649V-8MI 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 130 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 16 MIPS Throughput at 16 MHz
      – On-Chip 2-cycle Multiplier
    • High Endurance Non-volatile Memory Segments
      – In-System Self-programmable Flash Program Memory 32K Bytes (ATmega329/ATmega3290) 64K Bytes (ATmega649/ATmega6490)
      – EEPROM:1K bytes (ATmega329/ATmega3290),2K bytes (ATmega649/ATmega6490)
      – Internal SRAM:2K bytes (ATmega329/ATmega3290),4K bytes (ATmega649/ATmega6490)
      – Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM
      – Data retention: 20 years at 85°C/100 years at 25°C(1),Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation,Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 compliant) Interface Boundary-scan Capabilities According to the JTAG Standard,Extensive On-chip Debug Support
      Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • Peripheral Features
      – 4 x 25 Segment LCD Driver (ATmega329/ATmega649)
      – 4 x 40 Segment LCD Driver (ATmega3290/ATmega6490)
      – Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
      – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode
      – Real Time Counter with Separate Oscillator
      – Four PWM Channels
      – 8-channel, 10-bit ADC
      – Programmable Serial USART
      – Master/Slave SPI Serial Interface
      – Universal Serial Interface with Start Condition Detector
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal Calibrated Oscillator
      – External and Internal Interrupt Sources
      – Five Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, and
      Standby
    • I/O and Packages
      – 53/68 Programmable I/O Lines
      – 64-lead TQFP, 64-pad QFN/MLF, and 100-lead TQFP
    • Speed Grade:
      – ATmega329V/ATmega3290V/ATmega649V/ATmega6490V:
      – 0 - 4 MHz @ 1.8 - 5.5V, 0 - 8 MHz @ 2.7 - 5.5V
      – ATmega329/3290/649/6490:
      – 0 - 8 MHz @ 2.7 - 5.5V, 0 - 16 MHz @ 4.5 - 5.5V
    • Temperature range:
      – -40°C to 85°C Industrial
    • Ultra-Low Power Consumption
      – Active Mode:
    • 1 MHz, 1.8V:350 μA32 kHz, 1.8V: 20 μA (including Oscillator)
      32 kHz, 1.8V: 40 μA (including Oscillator and LCD)
    • Power-down Mode:100 nA at 1.8V
    ATmega649V-8MI 订购型号
    Speed (MHz) Power Supply Ordering Code Package Type Operational Range
    8 1.8 - 5.5V ATmega649V-8AI
    ATmega649V-8AU
    ATmega649V-8MI
    ATmega649V-8MU
    64A
    64A
    64M1
    64M1
    Industrial (-40°C to 85°C)
    16 2.7 - 5.5V ATmega649-16AI
    ATmega649-16AU
    ATmega649-16MI
    ATmega649-16MU
    64A
    64A
    64M1
    64M1
    ATmega649V-8MI 技术支持
    1. ATmega649 数据手册DataSheet 下载. PDF(完整版)
    2. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    3. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    4. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    5. AVR指令集(版本:0856G–AVR–07/08)
    6. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    7. AVR 微控制器汽车应用解决方案 . pdf
    8. AVR 微控制器选型指南. pdf
    9. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
