龙人旗下深圳市龙芯世纪科技有限公司
  • AT90PWM1-16MU 带有8K系统内可编程Flash存储器QFN-24封装
  • 发布时间:2009/8/22 11:22:13   修改时间:2009/8/22 11:22:13 浏览次数:1328
    Flash (Kbytes) 8
    EEPROM (Kbytes) 0.5
    SRAM (Bytes) 512
    Max I/O Pins 19
    F.max (MHz) 16
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 1
    Brown Out Detector Yes
    Ext Interrupts 4
    Hardware Multiplier Yes
    Interrupts 26
    On Chip Oscillator Yes
    Self Program Memory Yes
    RTC Yes
    SPI 1
    UART No
    Vcc (V) 2.7-5.5
    Watchdog Yes
    ISP Yes
    Packages SOIC 24
    Specially designed for Lamp ballast and Motor Control applications, the AT90PWM1 AVR microcontroller features 8 KBytes Flash memory, 7-channel advanced PWM, 8-channel 8-bit ADC, two 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution Enhancement.
    The AT90PWM1 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the AT90PWM1 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    AT90PWM1-16MU 特性
    • High Performance, Low Power AVR ? 8-bit Microcontroller
    • Advanced RISC Architecture
      – 131 Powerful Instructions - Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 1 MIPS throughput per MHz
      – On-chip 2-cycle Multiplier
    • Data and Non-Volatile Program Memory
      – 8K Bytes Flash of In-System Programmable Program Memory
    • Endurance: 10,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program
    • True Read-While-Write Operation
      – 512 Bytes of In-System Programmable EEPROM
    • Endurance: 100,000 Write/Erase Cycles
      – 512 Bytes Internal SRAM
      – Programming Lock for Flash Program and EEPROM Data Security
    • On Chip Debug Interface (debugWIRE) Peripheral Features
      – Two 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution
      Enhancement Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time Variable PWM duty Cycle and Frequency Synchronous Update of all PWM Registers Auto Stop Function for Event Driven PFC Implementation Less than 25 Hz Step Width at 150 kHz Output Frequency
    • PSC2 with four Output Pins and Output Matrix
      – One 8-bit General purpose Timer/Counter with Separate Prescaler and Capture Mode
      – One 16-bit General purpose Timer/Counter with Separate Prescaler, Compare
      Mode and Capture Mode
      – Master/Slave SPI Serial Interface
      – 10-bit ADC
    • 8 Single Ended Channels and 1 Fully Differential ADC Channel Pair
    • Programmable Gain (5x, 10x, 20x, 40x on Differential Channel)
    • Internal Reference Voltage
      – Two Analog Comparator with Resistor-Array to Adjust Comparison Voltage
      – 4 External Interrupts
      – Programmable Watchdog Timer with Separate On-Chip Oscillator
    • Special Microcontroller Features
      – Low Power Idle, Noise Reduction, and Power Down Modes
      – Power On Reset and Programmable Brown Out Detection
      – Flag Array in Bit-programmable I/O Space (4 bytes)
      – In-System Programmable via SPI Port
      – Internal Calibrated RC Oscillator ( 8 MHz)
      – On-chip PLL for fast PWM ( 32 MHz, 64 MHz) and CPU (16 MHz)
    AT90PWM1-16MU 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    16 2.7 - 5.5V AT90PWM1-16SU SO24 Extended (-40°C to 105°C)
    16 2.7 - 5.5V AT90PWM1-16MU QFN32 Extended (-40°C to 105°C)
    AT90PWM1-16MU 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器AT90PWM1 数据手册DataSheet 下载. PDF (完整版)
    2. ATMEL 爱特梅尔AVR 微控制器AT90PWM1 数据手册DataSheet 下载. PDF(简洁版)
    3. ATMEL 爱特梅尔半导体公司产品线. PDF (编号:Atmel Products)
    4. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    5. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    6. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    7. AVR指令集(版本:0856G–AVR–07/08)
    8. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    9. AVR 微控制器汽车应用解决方案 . pdf
    10. AVR 微控制器选型指南. pdf
    11. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
