龙人旗下深圳市龙芯世纪科技有限公司
  • AT90PWM316-16SE 带有16K系统内可编程Flash存储器SOIC-32封装
  • 发布时间:2009/8/22 11:27:03   修改时间:2009/8/22 11:27:03 浏览次数:1230
    Flash (Kbytes) 16
    EEPROM (Kbytes) 0.5
    SRAM (Bytes) 1024
    Max I/O Pins 27
    F.max (MHz) 16
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 1
    Brown Out Detector Yes
    Ext Interrupts 4
    Hardware Multiplier Yes
    Interrupts 29
    On Chip Oscillator Yes
    Self Program Memory Yes
    RTC Yes
    SPI 1
    UART Yes
    Vcc (V) 2.7-5.5
    Watchdog Yes
    ISP Yes
    Pb-Free Packages VQFN (Punched) 32
     SOIC 32
    Specially designed for Lamp ballast and Motor Control applications, the AT90PWM316 AVR microcontroller features 16 Kbytes Flash memory, 10-channel advanced PWM, 11-channel 10-bit ADC, a 10-bit DAC, three 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution Enhancement and DALI protocol support.
    • 16KB 系统内可编程Flash存储器:AT90PWM216
    • 16KB 系统内可编程Flash存储器:AT90PWM316
    The AT90PWM216/316 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced
    RISC architecture. By execut ing powerful inst ruct ions in a single clock cycle, the
    AT90PWM216/316 achieves throughputs approaching 1 MIPS per MHz allowing the system
    designer to optimize power consumption versus processing speed.
    AT90PWM316-16SE 特性
    • High Performance, Low Power AVR ? 8-bit Microcontroller
    • Advanced RISC Architecture
      – 129 Powerful Instructions - Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 1 MIPS throughput per MHz
      – On-chip 2-cycle Multiplier
    • Data and Non-Volatile Program Memory
      – 16K Bytes Flash of In-System Programmable Program Memory
    • Endurance: 10,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits
    • In-System Programming by On-chip Boot Program
    • True Read-While-Write Operation
      – 512 Bytes of In-System Programmable EEPROM
    • Endurance: 100,000 Write/Erase Cycles
      – 1024 Bytes Internal SRAM
      – Programming Lock for Flash Program and EEPROM Data Security
    • On Chip Debug Interface (debugWIRE)
    • Peripheral Features
      – Two or three 12-bit High Speed PSC (Power Stage Controllers) with 4-bit
    • Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time
    • Variable PWM duty Cycle and Frequency
    • Synchronous Update of all PWM Registers
    • Auto Stop Function for Event Driven PFC Implementation
    • Less than 25 Hz Step Width at 150 kHz Output Frequency
    • PSC2 with four Output Pins and Output Matrix
      – One 8-bit General purpose Timer/Counter with Separate Prescaler and Capture
      Mode
      – One 16-bit General purpose Timer/Counter with Separate Prescaler, Compare
      Mode and Capture Mode
      – Programmable Serial USART
    • Standard UART mode
    • 16/17 bit Biphase Mode for DALI Communications
      – Master/Slave SPI Serial Interface
      – 10-bit ADC
    • Up To 11 Single Ended Channels and 2 Fully Differential ADC Channel Pairs
    • Programmable Gain (5x, 10x, 20x, 40x on Differential Channels)
    • Internal Reference Voltage
      – 10-bit DAC
      – Two or three Analog Comparator with Resistor-Array to Adjust Comparison
      Voltage
      – 4 External Interrupts
      – Programmable Watchdog Timer with Separate On-Chip Oscillator
    • Special Microcontroller Features
      – Low Power Idle, Noise Reduction, and Power Down Modes
      – Power On Reset and Programmable Brown Out Detection
      – Flag Array in Bit-programmable I/O Space (4 bytes)
      – In-System Programmable via SPI Port
      – Internal Calibrated RC Oscillator ( 8 MHz)
      – On-chip PLL for fast PWM ( 32 MHz, 64 MHz) and CPU (16 MHz)
    • Operating Voltage: 2.7V - 5.5V
    • Extended Operating Temperature:
      – -40°C to +105°
    AT90PWM316-16SE 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    16 2.7 - 5.5V AT90PWM316-16SE SO32 Engineering Samples
    16 2.7 - 5.5V AT90PWM316-16SU SO32 Extended (-40°C to 105°C)
    16 2.7 - 5.5V AT90PWM316-16MU QFN32 Extended (-40°C to 105°C)
    16 2.7 - 5.5V AT90PWM316-16ME QFN32 Extended (-40°C to 105°C)
    AT90PWM316-16SE 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器AT90PWM316 数据手册DataSheet 下载. PDF (完整版)
    2. ATMEL 爱特梅尔AVR 微控制器AT90PWM316 数据手册DataSheet 下载. PDF(简洁版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
