Specially designed for Lamp ballast and Motor Control applications, the AT90PWM3 AVR microcontroller features 8 Kbytes Flash memory, 10-channel advanced PWM, 11-channel 8-bit ADC, a 10-bit DAC, two or three 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution Enhancement and DALI protocol support. AT90PWM3B is the latest product version and must be used for all new designs.
The AT90PWM2/2B/3/3B is a low-power CMOS 8-bit microcontroller based on the AVRenhanced RISC architecture. By executing powerful instructions in a single clock cycle, the AT90PWM2/2B/3/3B achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
