龙人旗下深圳市龙芯世纪科技有限公司
  • 工业级ATmega1284P-AU 带有128K系统内可编程Flash存储器TQFP-44封装
  • 发布时间:2009/8/22 11:44:33   修改时间:2009/8/22 11:44:33 浏览次数:981
    Flash (Kbytes) 128
    EEPROM (Kbytes) 4
    SRAM (Bytes) 16K
    Max I/O Pins 32
    F.max (MHz) 20
    Vcc (V) 1.8 - 5.5
    10-bit A/D Channels Yes
    Analog Comparator Yes
    16-bit Timers 2
    8-bit Timer 2
    Brown Out Detector Yes
    Ext Interrupts 3
    Hardware Multiplier Yes
    Interrupts 35
    ISP Yes
    On Chip Oscillator Yes
    PWM Channels 6
    RTC Yes
    Self Program Memory Yes
    SPI Yes
    TWI Yes
    UART 2
    Watchdog Yes
    Pb-Free Packages MLF (VQFN) 44
    PDIP 40
    TQFP 44
    128K Bytes self-programming Flash Program Memory, 16K Bytes SRAM, 4K Bytes EEPROM, two 16-bit Timer/Counters, two 8-bit Timer/Counters, Real Time Counter, 8 Channel 10-bit A/D-converter(TQFP/MLF). JTAG Interface for On-chip Debug. Up to 20 MIPS throughput at 20 MHz. The ATmega1284P is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATmega1284P achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega1284P-AU 产品特性
    • High-performance, Low-power AVR? 8-bit Microcontroller
    • Advanced RISC Architecture
      – 131 Powerful Instructions – Most Single-clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 20 MIPS Throughput at 20 MHz
      – On-chip 2-cycle Multiplier
    • Nonvolatile Program and Data Memories
      – 128K Bytes of In-System Self-Programmable Flash
      Endurance: 10,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits
      In-System Programming by On-chip Boot Program
      True Read-While-Write Operation
      – 4K Bytes EEPROM
      Endurance: 100,000 Write/Erase Cycles
      – 16K Bytes Internal SRAM
      – Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 Compliant) Interface
      – Boundary-scan Capabilities According to the JTAG Standard
      – Extensive On-chip Debug Support
      – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • Peripheral Features
      – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes
      – Two 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
      Mode
      – Real Time Counter with Separate Oscillator
      – Six PWM Channels
      – 8-channel, 10-bit ADC
      Differential mode with selectable gain at 1x, 10x or 200x
      – Byte-oriented Two-wire Serial Interface
      – Two Programmable Serial USART
      – Master/Slave SPI Serial Interface
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal Calibrated RC Oscillator
      – External and Internal Interrupt Sources
      – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby
      and Extended Standby
    • I/O and Packages
      – 32 Programmable I/O Lines
      – 40-pin PDIP, 44-lead TQFP, and 44-pad QFN/MLF
    • Operating Voltages
      – 1.8 - 5.5V for ATmega1284P
    • Speed Grades
      – 0 - 4 MHz @ 1.8 - 5.5V
      – 0 - 10 MHz @ 2.7 - 5.5V
      – 0 - 20 MHz @ 4.5 - 5.5V
    • Power Consumption at 1 MHz, 1.8V, 25°C
      – Active: TBD μA
      – Power-down Mode: TBD μA
      – Power-save Mode: TBD μA (Including 32 kHz RTC)
      8-bit
      Microcontroller
      with 128K Bytes
      In-System
      Programmable
      Flash
      ATmega1284P
      Preliminary
      8059B–AVR–05/08
    ATmega1284P-AU 订购型号
    速度 (MHz) 所需电源 产品型号 封装 工作范围
    20 1.8 - 5.5V ATmega1284P-AU
    ATmega1284P-PU
    ATmega1284P-MU
    44A
    40P6
    44M1
    工业级(-40°C - 85°C)
    ATmega1284P-AU 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATmega1284P 数据手册DataSheet 下载. PDF(简洁版)
    2. ATMEL 爱特梅尔AVR 微控制器ATmega1284P 数据手册DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
