龙人旗下深圳市龙芯世纪科技有限公司
  • AT32UC3A0512-ALUT 带有512KB系统内可编程Flash存储器LQFP-144封装
  • 发布时间:2009/8/24 10:07:03   修改时间:2009/8/24 10:07:03 浏览次数:1181
    MIPS 91
    SRAM (Kbytes) 64
    Flash (Kbytes) 512
    I/O Pins 109
    USB Full-Speed
    + OTG
    Ethernet
    MAC 10/100
    1
    External
    Bus Interface
    Yes
    UART 4
    F.max (MHz) 66
    Pb-Free
    Packages
    LQFP 144
    爱特梅尔的AVR. 微控制器有一个RISC 核心运行单周期指令和限制对外在组分的需要的一个明确定义的I/O 结构。内部振荡器, 定时器, UART, SPI, 上拉电阻, 脉冲宽度调制, ADC, 模拟比较器和看门狗定器是AVR 设备里的一些特性。AVR 指令可协调用于减小程序的规模,不论代码是用C 或汇编写的。AVR有内嵌于芯片的系统可编程的Flash和EEPROM, 这是为了优化成本和使产品迅速面向市场的一个理想选择。
    32-bit Flash Microcontroller based on AVR32 UC core featuring 512K bytes Flash, 64 KBytes SRAM, 10/100 Ethernet MAC, full-speed (12 Mbps) USB 2.0 with On-The-Go (OTG) capability.
    The AT32UC3A0512 also feature SRAM/SDRAM external bus interface.
    The AT32UC3A devices deliver 91 Dhrystone MIPS (DMIPS) at 66 MHz and consume only 40 mA at 3.3V.
    The AT32UC3A is a complete System-On-Chip microcontroller based on the AVR32 UC RISC processor running at frequencies up to 66 MHz. AVR32 UC is a high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption, high code density and high performance.
    The processor implements a Memory Protection Unit (MPU) and a fast and flexible interrupt controller for supporting modern operating systems and real-time operating systems. Higher computation capabilities are achievable using a rich set of DSP instructions.
    The AT32UC3A incorporates on-chip Flash and SRAM memories for secure and fast access. For applications requiring additional memory, an external memory interface is provided on AT32UC3A0 derivatives. The Peripheral Direct Memory Access controller (PDCA) enables data transfers between peripherals and memories without processor involvement. PDCA drastically reduces processing overhead when transferring continuous and large data streams between modules within the MCU.
    The PowerManager improves design flexibility and security: the on-chip Brown-Out Detector monitors the power supply, the CPU runs from the on-chip RC oscillator or from one of external oscillator sources, a Real-Time Clock and its associated timer keeps track of the time. The Timer/Counter includes three identical 16-bit timer/counter channels. Each channel can be independently programmed to perform frequency measurement, event counting, interval measurement, pulse generation, delay timing and pulse width modulation.
    The PWM modules provides seven independent channels with many configuration options including polarity, edge alignment and waveform non overlap control. One PWM channel can trigger ADC conversions for more accurate close loop control implementations.
    The AT32UC3A also features many communication interfaces for communication intensive applications. In addition to standard serial interfaces like UART, SPI or TWI, other interfaces like flexible Synchronous Serial Controller, USB and Ethernet MAC are available. The Synchronous Serial Controller provides easy access to serial communication protocols and audio standards like I2S. The Full-Speed USB 2.0 Device interface supports several USB Classes at the same time thanks to the rich End-Point configuration. The On-The-GO (OTG) Host interface allows device like a USB Flash disk or a USB printer to be directly connected to the processor. The media-independent interface (MII) and reduced MII (RMII) 10/100 Ethernet MAC module provides on-chip solutions for network-connected devices.
    AT32UC3A integrates a class 2+ Nexus 2.0 On-Chip Debug (OCD) System, with non-intrusive real-time trace, full-speed read/write memory access in addition to basic runtime control.
    AT32UC3A0512-ALUT 特性
      ? High Performance, Low Power AVR?32 UC 32-Bit Microcontroller
      – Compact Single-cycle RISC Instruction Set Including DSP Instruction Set
      – Read-Modify-Write Instructions and Atomic Bit Manipulation
      – Performing 1.49 DMIPS / MHz
      Up to 91 DMIPS Running at 66 MHz from Flash (1 Wait-State)
      Up to 49 DMIPS Running at 33MHz from Flash (0 Wait-State)
      – Memory Protection Unit
      ? Multi-hierarchy Bus System
      – High-Performance Data Transfers on Separate Buses for Increased Performance
      – 15 Peripheral DMA Channels Improves Speed for Peripheral Communication
      ? Internal High-Speed Flash
      – 512K Bytes, 256K Bytes, 128K Bytes Versions
      – Single Cycle Access up to 33 MHz
      – Prefetch Buffer Optimizing Instruction Execution at Maximum Speed
      – 4ms Page Programming Time and 8ms Full-Chip Erase Time
      – 100,000 Write Cycles, 15-year Data Retention Capability
      – Flash Security Locks and User Defined Configuration Area
      ? Internal High-Speed SRAM, Single-Cycle Access at Full Speed
      – 64K Bytes (512KB and 256KB Flash), 32K Bytes (128KB Flash)
      ? External Memory Interface on AT32UC3A0 Derivatives
      – SDRAM / SRAM Compatible Memory Bus (16-bit Data and 24-bit Address Buses)
      ? Interrupt Controller
      – Autovectored Low Latency Interrupt Service with Programmable Priority
      ? System Functions
      – Power and Clock Manager Including Internal RC Clock and One 32KHz Oscillator
      – Two Multipurpose Oscillators and Two Phase-Lock-Loop (PLL) allowing
      Independant CPU Frequency from USB Frequency
      – Watchdog Timer, Real-Time Clock Timer
      ? Universal Serial Bus (USB)
      – Device 2.0 Full Speed and On-The-Go (OTG) Low Speed and Full Speed
      – Flexible End-Point Configuration and Management with Dedicated DMA Channels
      – On-chip Transceivers Including Pull-Ups
      ? Ethernet MAC 10/100 Mbps interface
      – 802.3 Ethernet Media Access Controller
      – Supports Media Independent Interface (MII) and Reduced MII (RMII)
      ? One Three-Channel 16-bit Timer/Counter (TC)
      – Three External Clock Inputs, PWM, Capture and Various Counting Capabilities
      ? One 7-Channel 16-bit Pulse Width Modulation Controller (PWM)
      ? Four Universal Synchronous/Asynchronous Receiver/Transmitters (USART)
      – Independant Baudrate Generator, Support for SPI, IrDA and ISO7816 interfaces
      – Support for Hardware Handshaking, RS485 Interfaces and Modem Line
      ? Two Master/Slave Serial Peripheral Interfaces (SPI) with Chip Select Signals
      ? One Synchronous Serial Protocol Controller
      – Supports I2S and Generic Frame-Based Protocols
      ? One Master/Slave Two-Wire Interface (TWI), 400kbit/s I2C-compatible
      ? One 8-channel 10-bit Analog-To-Digital Converter
      ? 16-bit Stereo Audio Bitstream
      – Sample Rate Up to 50 KHz
      ? On-Chip Debug System (JTAG interface)
      – Nexus Class 2+, Runtime Control, Non-Intrusive Data and Program Trace
      ? 100-pin TQFP (69 GPIO pins), 144-pin LQFP (109 GPIO pins) , 144 BGA (109 GPIO pins)
      ? 5V Input Tolerant I/Os
      ? Single 3.3V Power Supply or Dual 1.8V-3.3V Power Supply
    AT32UC3A0512-ALUT 订购型号
    Device Ordering Code Package Conditioning Temperature
    Operating Range
    AT32UC3A0512 AT32UC3A0512-ALUT 144 LQFP Tray Industrial
    (-40°C to 85°C)
    AT32UC3A0512-ALUR 144 LQFP Reel
    AT32UC3A0512-ALTR 144 LQFP Reel Automotive
    (-40°C to 85°C)
    AT32UC3A0512-ALTT 144 LQFP Tray
    AT32UC3A0512-ALTES 144 LQFP Tray Automotive
    (-40°C to 85°C) samples
    AT32UC3A0512-CTUT 144 FFBGA Tray Industrial (-40°C to 85°C)
    AT32UC3A0512-CTUR 144 FFBGA Reel
    AT32UC3A0256 AT32UC3A0256-ALUT 144 LQFP Tray Industrial (-40°C to 85°C)
    AT32UC3A0256-ALUR 144 LQFP Reel
    AT32UC3A0256-CTUT 144 FFBGA Tray
    AT32UC3A0256-CTUR 144 FFBGA Reel
    AT32UC3A0128 AT32UC3A0128-ALUT 144 lead LQFP Tray Industrial (-40°C to 85°C)
    AT32UC3A0128-ALUR 144 lead LQFP Reel
    AT32UC3A0128-CTUT 144 FFBGA Tray
    AT32UC3A0128-CTUR 144 FFBGA Reel
    AT32UC3A1512 AT32UC3A1512-AUT 100 TQFP Tray Industrial (-40°C to 85°C)
    AT32UC3A1512-AUR 100 TQFP Reel
    AT32UC3A1256 AT32UC3A1256-AUT 100 TQFP Tray Industrial
    (-40°C to 85°C)
    AT32UC3A1256-AUR 100 TQFP Reel
    AT32UC3A1128 AT32UC3A1128-AUT 100 TQFP Tray Industrial
    (-40°C to 85°C)
    AT32UC3A1128-AUR 100 TQFP Reel
    AT32UC3A0512-ALUT 技术支持
    1. ATMEL 爱特梅尔AVR32 微控制器AT32UC3A0512 数据手册DataSheet 下载. PDF(完整版)
    2. ATMEL 爱特梅尔AVR32 微控制器AT32UC3A0512 数据手册DataSheet 下载. PDF(简洁版)
    3. ATMEL 爱特梅尔半导体公司产品线. PDF (编号:Atmel Products)
    4. Atmel 爱特梅尔AVR32 微控制器简介.PDF
    5. AVR32UC技术参考手册 .PDF
    6. AVR32 UC3 USB DFU Bootloader (28 pages, revision A, updated 7/07)
    7. AVR32架构手册 .PDF
    8. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    9. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
