龙人旗下深圳市龙芯世纪科技有限公司
  • AT91RM9200-CI-002 32位ARM单片机LFBGA-256封装
  • 发布时间:2009/8/24 10:48:11   修改时间:2009/8/24 10:48:11 浏览次数:1164
    Status Production
    SRAM (Bytes) 16K
    Ethernet MAC 10/100 1
    USB Host 2xFS
    External Bus Interface 1
    RTC/RTT 39814
    Peripheral DMA Channels 20
    Max. Clock Speed (MHz) 180
    I/O Pins 122
    SDRAM Interface 1
    Enhanced USART 4
    USART/DBGU -/1
    SPI 1
    TWI 1
    SSC 3
    MCI 1
    USB Device FS
    16-bit Timers 6
    Period Interval Timer 1
    Watchdog Timer 1
    Crystal Oscillator/PLL 39846
    ARM Core 920T
    Cache Memory (Bytes) 2x16K
    MMU/MPU MMU
    I/O Voltage Domain (V) 3.3
    In-System Programming Y
    Single Supply N
    Pb-Free Packages LFBGA 256
    PQFP 208
    AT91RM9200-CI-002 描述
    The AT91RM9200 microcontroller offers a flexible configuration of on- and off-chip memories together with an extensive set of peripherals for control, communication and data storage purposes. It is based on the ARM920T 200-MIPS advanced 32-bit RISC processor with 16K byte instruction and 16K byte data cache memories. It features 16K bytes of on-chip SRAM and 128K bytes of ROM, together with an external bus interface with controllers for SDRAM and static memories including NAND Flash and CompactFlash.
    Its extensive peripheral set includes USB Full Speed Host and Device Ports, 10/100 Base T Ethernet MAC, Multimedia Card Interface (MCI), three Synchronous Serial Controllers (SSC), four USARTs, Master/Slave Serial Peripheral Interface (SPI), Timer Counters (TC) and Two Wire Interface (TWI). Four 32-bit Parallel I/O Controllers multiplex the pins to/from these peripherals in order to reduce the device pin count, and peripheral DMA channels maximize the data throughput between these interfaces and the on- and off-chip memories.
    The AT91RM9200 has a fully featured system controller for efficient system management, including two on-chip oscillators and PLLs, clock generator, advanced interrupt controller (AIC), debug unit (DBGU), periodic interval timer, watchdog timer and real-time clock with alarm interrupt. It is supplied in a 208-pin PQFP or 266-ball BGA package.
    The AT91RM9200 is supported by the AT91RM9200-EK Evaluation Board and extensive third-party application development tools. It supports both Linux and Windows CE. It targets applications requiring enhanced performance such as host processors for system control and connectivity. Examples include telematics systems connecting GPS receivers and GPRS communications, industrial automation, medical systems and point-of-sales terminals.
    AT91RM9200-CI-002 产品特性
      ? Incorporates the ARM920T? ARM? Thumb? Processor
      – 200 MIPS at 180 MHz, Memory Management Unit
      – 16-KByte Data Cache, 16-KByte Instruction Cache, Write Buffer
      – In-circuit Emulator including Debug Communication Channel
      – Mid-level Implementation Embedded Trace Macrocell? (256-ball BGA Package
      only)
      ? Low Power: On VDDCORE 24.4 mA in Normal Mode, 520 μA in Standby Mode
      ? Additional Embedded Memories
      – 16K Bytes of SRAM and 128K Bytes of ROM
      ? External Bus Interface (EBI)
      – Supports SDRAM, Static Memory, Burst Flash, Glueless Connection to
      CompactFlash? and NAND Flash/SmartMedia?
      ? System Peripherals for Enhanced Performance:
      – Enhanced Clock Generator and Power Management Controller
      – Two On-chip Oscillators with Two PLLs
      – Very Slow Clock Operating Mode and Software Power Optimization Capabilities
      – Four Programmable External Clock Signals
      – System Timer Including Periodic Interrupt, Watchdog and Second Counter
      – Real-time Clock with Alarm Interrupt
      – Debug Unit, Two-wire UART and Support for Debug Communication Channel
      – Advanced Interrupt Controller with 8-level Priority, Individually Maskable Vectored
      Interrupt Sources, Spurious Interrupt Protected
      – Seven External Interrupt Sources and One Fast Interrupt Source
      – Four 32-bit PIO Controllers with Up to 122 Programmable I/O Lines, Input Change
      Interrupt and Open-drain Capability on Each Line
      – 20-channel Peripheral DMA Controller (PDC)
      ? Ethernet MAC 10/100 Base-T
      – Media Independent Interface (MII) or Reduced Media Independent Interface (RMII)
      – Integrated 28-byte FIFOs and Dedicated DMA Channels for Receive and Transmit
      ? USB 2.0 Full Speed (12 Mbits per second) Host Double Port
      – Dual On-chip Transceivers (Single Port Only on 208-lead PQFP Package)
      – Integrated FIFOs and Dedicated DMA Channels
      ? USB 2.0 Full Speed (12 Mbits per second) Device Port
      – On-chip Transceiver, 2-Kbyte Configurable Integrated FIFOs
      ? Multimedia Card Interface (MCI)
      – Automatic Protocol Control and Fast Automatic Data Transfers
      – MMC and SD Memory Card-compliant, Supports Up to Two SD Memory Cards
      ? Three Synchronous Serial Controllers (SSC)
      – Independent Clock and Frame Sync Signals for Each Receiver and Transmitter
      – I2S Analog Interface Support, Time Division Multiplex Support
      – High-speed Continuous Data Stream Capabilities with 32-bit Data Transfer
      ? Four Universal Synchronous/Asynchronous Receiver/Transmitters (USART)
      – Support for ISO7816 T0/T1 Smart Card
      – Hardware Handshaking
      – RS485 Support, IrDA? Up To 115 Kbps
      – Full Modem Control Lines on USART1
      ? Master/Slave Serial Peripheral Interface (SPI)
      – 8- to 16-bit Programmable Data Length, 4 External Peripheral Chip Selects
      ? Two 3-channel, 16-bit Timer/Counters (TC)
      – Three External Clock Inputs, Two Multi-purpose I/O Pins per Channel
      – Double PWM Generation, Capture/Waveform Mode, Up/Down Capability
      ? Two-wire Interface (TWI)
      – Master Mode Support, All 2-wire Atmel EEPROMs Supported
      ? IEEE? 1149.1 JTAG Boundary Scan on All Digital Pins
      ? Power Supplies
      – 1.65V to 1.95V for VDDCORE, VDDOSC and VDDPLL
      – 3.0V to 3.6V for VDDIOP (Peripheral I/Os) and for VDDIOM (Memory I/Os)
      ? Available in a 208-pin Green PQFP or 256-ball RoHS-compliant BGA Package
    AT91RM9200-CI-002 订购型号
    Ordering Code Package Package Type Operating Temperature Range
    AT91RM9200-CI-002 BGA 256 Standard Industrial (-40° C to 85° C)
    AT91RM9200-QU-002 PQFP 208 Green
    AT91RM9200-CJ-002 BGA 256 RoHS-compliant
    AT91RM9200-CI-002 技术支持
    1. AT91R40008 数据手册DataSheet 下载. PDF
    2. ARM7TDMI 技术白皮书
    3. AT91SAM 系列产品选型指南(Brochure, 2 pages, revision E, updated 2/09)
      Product selection guide to Atmel's AT91SAM microcontrollers that give immediate access to market-leading ARM processors.
    4. Atmel's ARM-based Microcontroller Excels in Real-Time (White Paper, 6 pages, revision A, updated 3/01)
      Applications such as mobile communicators, PDAs, solid-state music players and internet appliances demand the best possible real-time performance. Atmel's AT91 series of ARM-based microcontrollers incorporates a number of advanced features that enhance the real-time performance of the ARM7TDMI core, making it ideal for applications of this nature.
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
