龙人旗下深圳市龙芯世纪科技有限公司
  • AT91SAM7L64 32位ARM单片机
  • 发布时间:2009/8/25 9:11:36   修改时间:2009/8/25 9:11:36 浏览次数:1427
    Status Sampling
    Flash (Bytes) 64K
    SRAM (Bytes) 6K
    LCD Controller 1
    RTC/RTT 1/-
    10-bit ADC Channels 4
    Peripheral DMA Channels 11
    Max. Clock Speed (MHz) 36
    I/O Pins 80
    Enhanced USART 1
    USART/DBGU 1/-
    SPI 1
    TWI 1
    PWM Controller 4
    High Current Pads 4
    16-bit Timers 4
    Period Interval Timer 1
    Watchdog Timer 1
    Power-On-Reset 1
    Brown Out Detection 1
    On-chip RC Oscillator 1
    Crystal Oscillator/PLL 39814
    ARM Core 7TDMI
    I/O Voltage Domain (V) 2.5/3.3V
    In-System Programming Y
    Single Supply Y
    Pb-Free Packages LQFP 128
    LFBGA 144
    AT91SAM7L64 描述
    The AT91SAM7L64 is a member of a series of high-performance, ultra-low power ARM7TDMI?-based microcontrollers, embedding power switches controlling multiple power islands and programmable voltage regulators to reduce power consumption in active and standby modes. In active mode, the power consumption is optimized via a programmable operating voltage, operating frequency, and peripheral clock activity, and the use of DMA instead of the CPU for data transfers. The SAM7L128 operates in single supply mode down to 1.8V and consumes 0.5mA/MHz typical in active mode when executing code out of its Flash memory.
    The power consumption in the different standby modes is controlled via power switches, scalable voltage regulators, and the use of sampling techniques on Voltage Monitors, Power On Reset and Brown Out Detector instead of continuous measurement. This provides a higher level of granularity than is available in competing products, while achieving at least the same levels of power saving. In power down mode, the AT91SAM7L consumes only a typical 100nA, which is believed to be a unique feature for 32-bit MCUs.
    AT91SAM7L64 特性
    • Incorporates the ARM7TDMI? ARM? Thumb? Processor
      – High-performance 32-bit RISC Architecture
      – High-density 16-bit Instruction Set
      – Leader in MIPS/Watt
      – EmbeddedICE? In-circuit Emulation, Debug Communication Channel Support
    • Internal High-speed Flash
      – 128 Kbytes (AT91SAM7L128), Organized in 512 Pages of 256 Bytes Single Plane
      – 64 Kbytes (AT91SAM7L64), Organized In 256 Pages of 256 Bytes Single Plane
      – Single Cycle Access at Up to 15 MHz in Worst Case Conditions
      – 128-bit Read Access
      – Page Programming Time: 4.6 ms, Including Page Auto Erase, Full Erase Time: 10 ms
      – 10,000 Write Cycles, 10-year Data Retention Capability, Sector Lock Capabilities,
      Flash Security Bit
      – Fast Flash Programming Interface for High Volume Production
    • Internal High-speed SRAM, Single-cycle Access at Maximum Speed
      – 6 Kbytes
    • 2 Kbytes Directly on Main Supply That Can Be Used as Backup SRAM
    • 4 Kbytes in the Core
    • Memory Controller (MC)
      – Enhanced Embedded Flash Controller, Abort Status and Misalignment Detection
    • Enhanced Embedded Flash Controller (EEFC)
      – Interface of the Flash Block with the 32-bit Internal Bus
      – Increases Performance in ARM and Thumb Mode with 128-bit Wide Memory
      Interface
    • Reset Controller (RSTC)
      – Based on Zero-power Power-on Reset and Fully Programmble Brownout Detector
      – Provides External Reset Signal Shaping and Reset Source Status
    • Clock Generator (CKGR)
      – Low-power 32 kHz RC Oscillator, 32 kHz On-chip Oscillator, 2 MHz Fast RC
      Oscillator and one PLL
    • Supply Controller (SUPC)
      – Minimizes Device Power Consumption
      – Manages the Different Supplies On Chip
      – Supports Multiple Wake-up Sources
    • Power Management Controller (PMC)
      – Software Power Optimization Capabilities, Including Active and Four Low Power
      Modes:
    • Idle Mode: No Processor Clock
    • Wait Mode: No Processor Clock, Voltage Regulator Output at Minimum
    • Backup Mode: Voltage Regulator and Processor Switched Off
    • Off (Power Down) Mode: Entire Chip Shut Down Except for Force Wake Up Pin (FWUP) that Re-activates the Device. 100 nA Current Consumption.
    • In Active Mode, Dynamic Power Consumption <30 mA at 36 MHz
      – Three Programmable External Clock Signals
      – Handles Fast Start Up ? Incorporates the ARM7TDMI? ARM? Thumb? Processor
      – Page Programming Time: 4.6 ms, Including Page Auto Erase, Full Erase Time: 10 ms 10,000 Write Cycles, 10-year Data Retention Capability, Sector Lock Capabilities,Flash Security Bit
      – 6 Kbytes
      – Increases Performance in ARM and Thumb Mode with 128-bit Wide Memory Interface
      – Low-power 32 kHz RC Oscillator, 32 kHz On-chip Oscillator, 2 MHz Fast RC Oscillator and one PLL
      – Software Power Optimization Capabilities, Including Active and Four Low Power Modes:
    AT91SAM7L64 订购型号
    Ordering Code Package Package Type Operating Temperature Range
    AT91SAM7L128-AU LQFP128 Green Industrial (-40° C to 85° C)
    AT91SAM7L64-AU LQFP128 Green Industrial (-40° C to 85° C)
    AT91SAM7L128-CU LFBGA144 Green Industrial (-40°C to 85°C)
    AT91SAM7L64-CU LFBGA144 Green Industrial (-40°C to 85°C)
    AT91SAM7L64 技术支持
    1. AT91SAM7L64数据手册DataSheet 下载. PDF(完整版)
    2. AT91SAM7L64数据手册DataSheet 下载. PDF(简洁版)
    3. ARM7TDMI 技术白皮书
    4. AT91SAM 系列产品选型指南(Brochure, 2 pages, revision E, updated 2/09)
      Product selection guide to Atmel's AT91SAM microcontrollers that give immediate access to market-leading ARM processors.
    5. Atmel's ARM-based Microcontroller Excels in Real-Time (White Paper, 6 pages, revision A, updated 3/01)
      Applications such as mobile communicators, PDAs, solid-state music players and internet appliances demand the best possible real-time performance. Atmel's AT91 series of ARM-based microcontrollers incorporates a number of advanced features that enhance the real-time performance of the ARM7TDMI core, making it ideal for applications of this nature.
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
