龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51CC03CA-SLSUM 带有64K系统内可编程FLash存储器PLCC-44封装
  • 发布时间:2009/8/25 11:04:39   修改时间:2009/8/25 11:04:39 浏览次数:1032
    Flash (Kbytes) 64
    CAN (mess. Obj.) 15
    ISP Yes
    Self Program Memory Yes
    EEPROM (Kbytes) 2
    RAM (Bytes) 2304
    F.max (MHz) 40
    Vcc (V) 3-5.5
    I/O Pins 34/37
    UART 1
    16-bit Timers 2
    Watchdog Yes
    SPI Yes
    ADC Yes
    Packages   LQFP 64
    LQFP 44
    PLCC 52
    PLCC 44
    Pb-Free Packages   LQFP 64
    LQFP 44
    PLCC 52
    AT89C51CC03CA-SLSUM 概述
    The Atmel AT89C51CC03 is an 8051 based CMOS controller with PCA, Dual DPTR, WDT, 10 Bit ADC, Full CAN, 40 MHz High-Speed Architecture, X2 function, 32+2 I/O lines, 3 Timers/Counters, 14 Interrupts/4 priority levels, 64K FLASH, 2K EEPROM,256 Bytes on-chip RAM, additional 1K XRAM This document describes the UART bootloader functionalities as well as the serial protocol to efficiently perform operations on the on chip Flash (EEPROM) memories. Additiona l  infor m ation  on  the  AT89C51CC03  pr oduct  c an  be  found  in  the AT89C51CC03 datasheet and the AT89C51CC03 errata sheet available on the Atmel web site.
    AT89C51CC03CA-SLSUM 特性
    • 80C51 Core Architecture
    • 256 Bytes of On-chip RAM
    • 2048 Bytes of On-chip ERAM
    • 64K Bytes of On-chip Flash Memory
      – Data Retention: 10 Years at 85°C
      – Read/Write Cycle: 100K
    • 2K Bytes of On-chip Flash for Bootloader
    • 2K Bytes of On-chip EEPROM
    • Integrated Power Monitor (POR: PFD) To Supervise Internal Power Supply
    • 14-sources 4-level Interrupts
    • Three 16-bit Timers/Counters
    • Full Duplex UART Compatible 80C51
    • High-speed Architecture
      – In Standard Mode:
      40 MHz (Vcc 3V to 5.5V, both Internal and external code execution)
      60 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
      – In X2 mode (6 Clocks/machine cycle)
      20 MHz (Vcc 3V to 5.5V, both Internal and external code execution)
      30 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
    • Five Ports: 32 + 4 Digital I/O Lines
    • Five-channel 16-bit PCA with
      – PWM (8-bit)
      – High-speed Output
      – Timer and Edge Capture
    • Double Data Pointer
    • 21-bit WatchDog Timer (7 Programmable Bits)
    • A 10-bit Resolution Analog to Digital Converter (ADC) with 8 Multiplexed Inputs
    • SPI Interface, (PLCC52 and VPFP64 packages only)
    • Full CAN Controller
      – Fully Compliant with CAN Rev 2.0A and 2.0B
      – Optimized Structure for Communication Management (Via SFR)
      – 15 Independent Message Objects
      – Each Message Object Programmable on Transmission or Reception
      – Individual Tag and Mask Filters up to 29-bit Identifier/Channel
      – 8-byte Cyclic Data Register (FIFO)/Message Object
      – 16-bit Status and Control Register/Message Object
      – 16-bit Time-Stamping Register/Message Object
      – CAN Specification 2.0 Part A or 2.0 Part B Programmable for Each Message
      Object
      – Access to Message Object Control and Data Registers Via SFR
      – Programmable Reception Buffer Length Up To 15 Message Objects
      – Priority Management of Reception of Hits on Several Message Objects at the
      Same Time (Basic CAN Feature)
      – Priority Management for Transmission
      – Message Object Overrun Interrupt
      – Supports
      – Time Triggered Communication
      – Autobaud and Listening Mode
      – Programmable Automatic Reply Mode
      – 1-Mbit/s Maximum Transfer Rate at 8 MHz (1) Crystal Frequency in X2 Mode
      – Readable Error Counters
      – Programmable Link to On-chip Timer for Time Stamping and Network
      Synchronization
      – Independent Baud Rate Prescaler
      – Data, Remote, Error and Overload Frame Handling
    AT89C51CC03CA-SLSUM 订购型号
    Part Number Boot Loader Temperature Range Package Packing Product Marking
    AT89C51CC03UA-RLTUM UART Industrial Green VQFP44 Tray 89C51CC03UA-UM
    AT89C51CC03UA-SLSUM UART Industrial Green PLCC44 Stick 89C51CC03UA-UM
    AT89C51CC03CA-RLTUM CAN Industrial Green VQFP44 Tray 89C51CC03CA-UM
    AT89C51CC03CA-SLSUM CAN Industrial Green PLCC44 Stick 89C51CC03CA-UM
    AT89C51CC03UA-RDTUM UART Industrial Green VQFP64 Tray 89C51CC03UA-UM
    AT89C51CC03UA-S3SUM UART Industrial Green PLCC52 Stick 89C51CC03UA-UM
    AT89C51CC03CA-S3SUM CAN Industrial Green PLCC52 Stick 89C51CC03CA-UM
    AT89C51CC03CA-RDTUM CAN Industrial Green VQFP64 Tray 89C51CC03CA-UM
    AT89C51CC03CA-SLSUM 技术支持
    1. AT89C51CC03 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
