龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51AC3-RLTUM 带有64K系统内可编程FLash存储器VQFP-44封装
  • 发布时间:2009/8/27 11:13:44   修改时间:2009/8/27 11:13:44 浏览次数:1649
  • AT89C51AC3-RLTUM 带有64K系统内可编程FLash存储器VQFP-44封装 Flash (Kbytes) 64 ISP UART Self Program Memor API EEPROM (Kbytes) 2 RAM (Bytes) 2304 F.max (MHz) 60 Vcc (V) 3-5.5 I/O Pins 32 UART 1 16-bit Timers 3 Watchdog Yes SPI Yes ADCYes Packages LQFP 64 LQFP 44 PLCC 52 PLCC 44 Pb-Free Packages LQFP 64 LQFP 44 PLCC 52 PLCC 44 8-bit microcontroller with A/D converter and 64-Kbyte Flash. 2-Kbyte RAM, 2-Kbyte EEPROM, SPI. Power Fail Detect (no need for external brown- out). Pinout compatible with T89C51AC2. The AT89C51AC3 is a high performance Flash version of the 80C51 single chip 8-bit microcontrollers. In X2 mode a maximum external clock rate of 20 MHz reaches a 300 ns cycle time. Besides the AT89C51AC3 provides 64K Bytes of Flash memory including In-System Programming (ISP) and IAP, 2K Bytes Boot Flash Memory, 2K Bytes EEPROM and 2048 byte ERAM.Primary attention is paid to the reduction of the electro-magnetic emission of AT89C51AC3. AT89C51AC3-RLTUM 特性 80C51 Core Architecture 256 Bytes of On-chip RAM 2048 Bytes of On-chip ERAM 64K Bytes of On-chip Flash Memory – Data Retention: 10 Years at 85°C – Read/Write Cycle: 100K Boot Code Section with Independent Lock Bits 2K Bytes of On-chip Flash for Bootloader In-System Programming by On-Chip UART Boot Program and IAP Capability 2K Bytes of On-chip EEPROM Read/Write Cycle: 100K Integrated Power Monitor (POR: PFD) To Supervise Internal Power Supply 14-sources 4-level Interrupts Three 16-bit Timers/Counters Full Duplex UART Compatible 80C51 High-speed Architecture – In Standard Mode: 40 MHz (Vcc 3V to 5.5V, both Internal and external code execution) 60 MHz (Vcc 4.5V to 5.5V and Internal Code execution only) – In X2 mode (6 Clocks/machine cycle) 20 MHz (Vcc 3V to 5.5V, both Internal and external code execution) 30 MHz (Vcc 4.5V to 5.5V and Internal Code execution only) Five Ports: 32 + 4 Digital I/O Lines Five-channel 16-bit PCA with – PWM (8-bit) – High-speed Output – Timer and Edge Capture Double Data Pointer 21-bit WatchDog Timer (7 Programmable Bits) A 10-bit Resolution Analog to Digital Converter (ADC) with 8 Multiplexed Inputs SPI Interface (PLCC52 and VPFP64 packages only) On-chip Emulation Logic (Enhanced Hook System) Power Saving Modes – Idle Mode – Power-down Mode Power Supply: 3 volts to 5.5 volts Temperature Range: Industrial (-40° to +85°C) Packages: VQFP44, PLCC44, VQFP64, PLCC52 AT89C51AC3-RLTUM 订购型号 Part NumberBoot LoaderTemperature RangePackagePackingProduct Marking AT89C51AC3-RLTUMUARTIndustrial GreenVQFP44TrayAT89C51AC3-M AT89C51AC3-SLSUMUARTIndustrial GreenPLCC44StickAT89C51AC3-IM AT89C51AC3-RDTUMUARTIndustrial GreenVQFP64TrayAT89C51AC3-IM AT89C51AC3-S3SUMUARTIndustrial GreenPLCC52StickAT89C51AC3-IM AT89C51AC3-RLTUM 技术支持 AT89C51AC3 数据手册DataSheet 下载. PDF 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049) 80C51在系统Flash编程. PDF (编号:8051 00050) Device Programmers for 8051 Devices (Other, updated 09/07) This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers Emulators for 80C51 Devices (Other, updated 11/03) This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers Package Adapters of 80C51 Devices (Other, updated 10/04) This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
