龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51AC3-SLSUM 带有64K系统内可编程FLash存储器PLCC-44封装
  • 发布时间:2009/8/27 11:14:38   修改时间:2009/8/27 11:14:38 浏览次数:1060
    Flash (Kbytes)   64
    ISP   UART
    Self Program Memor   API
    EEPROM (Kbytes)   2
    RAM (Bytes)   2304
    F.max (MHz)   60
    Vcc (V)   3-5.5
    I/O Pins   32
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    SPI   Yes
    ADC Yes
    Packages     LQFP 64
    LQFP 44
    PLCC 52
    PLCC 44
    Pb-Free Packages     LQFP 64
    LQFP 44
    PLCC 52
    PLCC 44
    8-bit microcontroller with A/D converter and 64-Kbyte Flash. 2-Kbyte RAM, 2-Kbyte EEPROM, SPI. Power Fail Detect (no need for external brown- out). Pinout compatible with T89C51AC2.
    The AT89C51AC3 is a high performance Flash version of the 80C51 single chip 8-bit microcontrollers.
    In X2 mode a maximum external clock rate of 20 MHz reaches a 300 ns cycle time. Besides the AT89C51AC3 provides 64K Bytes of Flash memory including In-System Programming (ISP) and IAP, 2K Bytes Boot Flash Memory, 2K Bytes EEPROM and 2048 byte ERAM.Primary attention is paid to the reduction of the electro-magnetic emission of AT89C51AC3.
    AT89C51AC3-SLSUM 特性
    • 80C51 Core Architecture
    • 256 Bytes of On-chip RAM
    • 2048 Bytes of On-chip ERAM
    • 64K Bytes of On-chip Flash Memory
      – Data Retention: 10 Years at 85°C
      – Read/Write Cycle: 100K
    • Boot Code Section with Independent Lock Bits
    • 2K Bytes of On-chip Flash for Bootloader
    • In-System Programming by On-Chip UART Boot Program and IAP Capability
    • 2K Bytes of On-chip EEPROM
    • Integrated Power Monitor (POR: PFD) To Supervise Internal Power Supply
    • 14-sources 4-level Interrupts
    • Three 16-bit Timers/Counters
    • Full Duplex UART Compatible 80C51
    • High-speed Architecture
      – In Standard Mode:
      40 MHz (Vcc 3V to 5.5V, both Internal and external code execution)
      60 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
      – In X2 mode (6 Clocks/machine cycle)
      20 MHz (Vcc 3V to 5.5V, both Internal and external code execution)
      30 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
    • Five Ports: 32 + 4 Digital I/O Lines
    • Five-channel 16-bit PCA with
      – PWM (8-bit)
      – High-speed Output
      – Timer and Edge Capture
    • Double Data Pointer
    • 21-bit WatchDog Timer (7 Programmable Bits)
    • A 10-bit Resolution Analog to Digital Converter (ADC) with 8 Multiplexed Inputs
    • SPI Interface (PLCC52 and VPFP64 packages only)
    • On-chip Emulation Logic (Enhanced Hook System)
    • Power Saving Modes
      – Idle Mode
      – Power-down Mode
    • Power Supply: 3 volts to 5.5 volts
    • Temperature Range: Industrial (-40° to +85°C)
    • Packages: VQFP44, PLCC44, VQFP64, PLCC52
    AT89C51AC3-SLSUM 订购型号
    Part Number Boot Loader Temperature Range Package Packing Product Marking
    AT89C51AC3-RLTUM UART Industrial Green VQFP44 Tray AT89C51AC3-M
    AT89C51AC3-SLSUM UART Industrial Green PLCC44 Stick AT89C51AC3-IM
    AT89C51AC3-RDTUM UART Industrial Green VQFP64 Tray AT89C51AC3-IM
    AT89C51AC3-S3SUM UART Industrial Green PLCC52 Stick AT89C51AC3-IM
    AT89C51AC3-SLSUM 技术支持
    1. AT89C51AC3 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
