龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51IC2-SLSUM 带有32K系统内可编程Flash存储器PLCC-44封装
  • 发布时间:2009/8/28 9:13:49   修改时间:2009/8/28 9:13:49 浏览次数:1393
    Flash (Kbytes)   32
    ISP   UART
    Self Program Memor   API
    RAM (Bytes)   1280
    F.max (MHz)   60
    Vcc (V)   2.7-5.5
    I/O Pins   34
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    SPI   Yes
    Packages    LQFP 44
     PLCC 44
    Pb-Free Packages    LQFP 44
     PLCC 44
    AT89C51IC2-SLSUM 概述
    AT89C51IC2 is a high performance Flash version of the 80C51 8-bit microcontrollers. It contains a 32K bytes Flash memory block for program and data.
    The 32K bytes Flash memory can be programmed either in parallel mode or in serial mode with the ISP capability or with software. The programming voltage is internally generated from the standard VCC pin.
    The AT89C51IC2 retains all features of the 80C52 with 256 bytes of internal RAM, a 10-source 4-level interrupt controller and three timer/counters.
    In addition, the AT89C51IC2 has a 32 kHz Subsidiary clock Oscillator, a Programmable Counter Array, an XRAM of 1024 byte, a Hardware Watchdog Timer, a Keyboard Interface,a 2-wire interface, an SPI Interface, a more versatile serial channel that facilitates multiprocessor communication (EUART) and a speed improvement mechanism (X2 mode).
    The fully static design of the AT89C51IC2 allows to reduce system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The AT89C51IC2 has 2 software-selectable modes of reduced activity and 8-bit clock prescaler for further reduction in power consumption. In the Idle mode the CPU is frozen while the peripherals and the interrupt system are still operating. In the power-down mode the RAM is saved and all other functions are inoperative.
    The added features of the AT89C51IC2 make it more powerful for applications that need pulse width modulation, high speed I/O and counting capabilities such as alarms, motor control, corded phones, smart card readers.
    AT89C51IC2-SLSUM 特性
    • 80C52 Compatible
      – 8051 Pin and Instruction Compatible
      – Four 8-bit I/O ports + 2 I/O 2-wire Interface (TWI) Pins
      – Three 16-bit Timer/Counters
      – 256 bytes Scratch Pad RAM
      – 10 Interrupt Sources with 4 Priority Levels
      – Dual Data Pointer
    • Variable Length MOVX for Slow RAM/Peripherals
    • ISP (In-System-Programming) Using Standard Vcc Power Supply
    • Boot ROM Contains Low Level Flash Programming Routines and a Default Serial
      Loader
    • High-speed Architecture
      – In Standard Mode:
      40 MHz (Vcc 2.7V to 5.5V, both Internal and external code execution)
      60 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
      – In X2 mode (6 Clocks/machine cycle)
      20 MHz (Vcc 2.7V to 5.5V, both Internal and external code execution)
      30 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
      – 32K Bytes On-chip Flash Program/Data Memory
      – Byte and Page (128 Bytes) Erase and Write
      – 100K Write Cycles
    • On-chip 1024 Bytes Expanded RAM (XRAM)
      – Software Selectable Size (0, 256, 512, 768, 1024 Bytes)
      – 256 Bytes Selected at Reset for TS87C51RB2/RC2 Compatibility
    • Keyboard Interrupt Interface on Port P1
    • 400-Kbits/s Multimaster 2-wire Interface
    • SPI Interface (Master/Slave Mode)
    • Sub-clock 32 kHz Crystal Oscillator
    • 8-bit clock Prescaler
    • Improved X2 Mode With Independant Selection for CPU and Each Peripheral
    • Programmable Counter Array 5 Channels with:
      – High Speed Output
      – Compare/Capture
      – Pulse Width Modulator
      – Watchdog Timer Capabilities
    • Asynchronous Port Reset
      Full-duplex Enhanced UART
    • Dedicated Baud Rate Generator for UART
    • Low EMI (Inhibit ALE)
    • Hardware Watchdog Timer (One-time enabled with Reset-Out)
    • Power Control Modes:
      – Idle Mode
      – Power-down Mode
      – Power-Off Flag
    • Power Supply:
      – 2.7 to 3.6 (3V Version)
      – 2.7 to 5.5V (5V Version)
    • Temperature Ranges: Commercial (0 to +70°C) and Industrial (-40°C to +85°C)
    • Packages: PLC44, VQFP44
    AT89C51IC2-SLSUM 订购型号
    Part Number Flash Memory
    Size
    Supply Voltage Boot Loader Temperature Range Package Packing Product Marking
    AT89C51IC2-SLSUM 32K bytes 5V UART Industrial Green PLCC44 Stick 89C51IC2-UM
    AT89C51IC2-RLTUM 32K bytes UART Industrial Green VQFP44 Tray 89C51IC2-UM
    AT89C51IC2-RLTUL 32K bytes 5V CAN Industrial Green VQFP44 Tray 89C51IC2-UL
    AT89C51IC2-SLSUL 32K bytes CAN Industrial Green PLCC44 Stick 89C51IC2-UL
    AT89C51IC2-SLSUM 技术支持
    1. AT89C51IC2数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
