龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51RE2-RLTUM 带有128K系统可编程Flash存储器VQFP-44封装
  • 发布时间:2009/8/28 9:46:14   修改时间:2009/8/28 9:46:14 浏览次数:4665
    Flash (Kbytes)   128
    ISP   UART
    Self Program Memor   Yes
    RAM (Bytes)   8448
    F.max (MHz)   60
    Vcc (V)   2.7-5.5
    I/O Pins   34
    UART   2
    16-bit Timers   3
    Watchdog   Yes
    SPI   Yes
    Pb-Free Packages    LQFP 44
     PLCC 44
    AT89C51RE2-RLTUM 概述
    AT89C51RE2 is a high performance CMOS Flash version of the 80C51 CMOS single chip 8-bit microcontroller. It contains a 128 Kbytes Flash memory block for program.
    The 128 Kbytes Flash memory can be programmed either in parallel mode or in serial mode with the ISP capability or with software. The programming voltage is internally generated from the standard VCC pin.
    The AT89C51RE2 retains all features of the Atmel 80C52 with 256 bytes of internal RAM, a 10-source 4-level interrupt controller and three timer/counters.In addition, the AT89C51RE2 has a Programmable Counter Array, an XRAM of 8192 bytes, a Hardware Watchdog Timer, SPI and Keyboard, two serial channels that facilitates multiprocessor communication (EUART), a speed improvement mechanism (X2 mode) and an extended stack mode that allows the stack to be extended in the lower 256 bytes of XRAM.
    The fully static design of the AT89C51RE2 allows to reduce system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The AT89C51RE2 has 2 software-selectable modes of reduced activity and 8-bit clock prescaler for further reduction in power consumption. In the Idle mode the CPU is frozen while the peripherals and the interrupt system are still operating. In the power-down mode the RAM is saved and all other functions are inoperative.
    The added features of the AT89C51RE2 make it more powerful for applications that need pulse width modulation, high speed I/O and counting capabilities such as alarms, motor control, corded phones, smart card readers.
    AT89C51RE2-RLTUM 特性
    • 80C52 Compatible
      – 8051 Instruction Compatible
      – Six 8-bit I/O Ports (64 pins or 68 Pins Versions)
      – Four 8-bit I/O Ports (44 Pins Version)
      – Three 16-bit Timer/Counters
      – 256 bytes Scratch Pad RAM
      – 11 Interrupt Sources With 4 Priority Levels
    • ISP (In-System Programming) Using Standard VCC Power Supply
    • Integrated Power Monitor (POR/PFD) to Supervise Internal Power Supply
    • Boot ROM Contains Serial Loader for In-System Programming
    • High-speed Architecture
      – In Standard Mode:
      40 MHz (Vcc 2.7V to 5.5V, Both Internal and External Code Execution)
      60 MHz (Vcc 4.5V to 5.5V and Internal Code Execution Only)
      – In X2 Mode (6 Clocks/Machine Cycle)
      20 MHz (Vcc 2.7V to 5.5V, Both Internal and External Code Execution)
      30 MHz (Vcc 4.5V to 5.5V and Internal Code Execution Only)
    • 128K bytes On-chip Flash Program/Data Memory
      – 128 bytes Page Write with auto-erase
      – 100k Write Cycles
    • On-chip 8192 bytes Expanded RAM (XRAM)
      – Software Selectable Size (0, 256, 512, 768, 1024, 1792, 2048, 4096, 8192 bytes)
    • Dual Data Pointer
    • Extended stack pointer to 512 bytes
    • Variable Length MOVX for Slow RAM/Peripherals
    • Improved X2 Mode with Independant Selection for CPU and Each Peripheral
    • Keyboard Interrupt Interface on Port 1
    • SPI Interface (Master/Slave Mode)
    • 8-bit Clock Prescaler
    • Programmable Counter Array with:
      – High Speed Output
      – Compare/Capture
      – Pulse Width Modulator
      – Watchdog Timer Capabilities
    • Asynchronous Port Reset
    • Two Full Duplex Enhanced UART with Dedicated Internal Baud Rate Generator
    • Low EMI (inhibit ALE)
    • Hardware Watchdog Timer (One-time Enabled with Reset-Out), Power-Off Flag
    • Power Control Modes: Idle Mode, Power-down Mode
    • Power Supply: 2.7V to 5.5V
    • Temperature Ranges: Industrial (-40 to +85°C)
    • Packages: PLCC44, VQFP44
    AT89C51RE2-RLTUM 订购型号
    Part Number Supply Voltage Temperature Range Package
    AT89C51RE2-SLSUM 2.7V-5.5V Industrial Green PLCC44
    AT89C51RE2-RLTUM 2.7V-5.5V Industrial Green VQFP44
    AT89C51RE2-RLTUM 技术支持
    1. AT89C51RE2数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
