龙人旗下深圳市龙芯世纪科技有限公司
  • AT89LS51-16AU 带有4K系统内可编程Flash系统TQFP-44封装
  • 发布时间:2009/8/28 9:46:58   修改时间:2009/8/28 9:46:58 浏览次数:1843
    Flash (Kbytes)   4
    ISP   SPI
    RAM (Bytes)   128
    F.max (MHz)   16
    Vcc (V)   2.7-4.0
    I/O Pins   32
    UART   1
    16-bit Timers   2
    Watchdog   Yes
    Pb-Free Packages   TQFP 44
    PDIP 40
    PLCC 44
    Low-Voltage Microcontroller with 4K Bytes In-System Programmable Flash
    AT89LS51-16AU 概述
    The AT89LS51 is a low-voltage, high-performance CMOS 8-bit microcontroller with 4K bytes of in-system programmable Flash memory. The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard 80C51 instruction set and pinout. The on-chip Flash allows the programmemory to be reprogrammed in-system or by a conventional nonvolatile memory programmer. By combining a versatile 8-bit CPU with in-system programmable
    Flash on a monolithic chip, the Atmel AT89LS51 is a powerful microcontroller which provides a highly-flexible and cost-effective solution to many embedded control applications.
    The AT89LS51 provides the following standard features: 4K bytes of Flash, 128 bytes of RAM, 32 I/O lines, Watchdog timer, two data pointers, two 16-bit timer/counters, a five-vector two-level interrupt architecture, a full duplex serial port, on-chip oscillator, and clock circuitry. In addition, the AT89LS51 is designed with static logic for operation down to zero frequency and supports two software selectable power saving modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial port, and interrupt system to continue functioning. The Power-down mode saves the RAM contents but freezes the oscillator, disabling all other chip functions until the next external interrupt or hardware reset.
    AT89LS51-16AU 特性
    • Compatible with MCS?-51 Products
    • 4K Bytes of In-System Programmable (ISP) Flash Memory
      – Endurance: 1000 Write/Erase Cycles
    • 2.7V to 4.0V Operating Range
    • Fully Static Operation: 0 Hz to 16 MHz
    • Three-level Program Memory Lock
    • 128 x 8-bit Internal RAM
    • 32 Programmable I/O Lines
    • Two 16-bit Timer/Counters
    • Six Interrupt Sources
    • Full Duplex UART Serial Channel
    • Low-power Idle and Power-down Modes
    • Interrupt Recovery from Power-down Mode
    • Watchdog Timer
    • Dual Data Pointer
    • Power-off Flag
    • Flexible ISP Programming (Byte and Page Mode)
    • Green (Pb/Halide-free) Packaging Option
    AT89LS51-16AU 订购型号
    Speed (MHz)) 电源供应 订购型号 封装 适用范围
    16 2.7V to 4.0V AT89LS51-16AU
    AT89LS51-16JU
    AT89LS51-16PU
    44A
    44J
    40P6
    Industrial (-40°C to 85°C)
    AT89LS51-16AU 技术支持
    1. AT89LS51数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
