龙人旗下深圳市龙芯世纪科技有限公司
  • AMS1503CM
  • 发布时间:2009/9/16 8:49:14   修改时间:2009/9/16 8:49:14 浏览次数:1148
  • AMS1503CM
    AMS1503 series of adjustable and fixed low dropout voltage regulators are designed to provide 3A output current to power the new generation of microprocessors. The dropout voltage of the device is 100mV at light loads and rising to 500mV at maximum output current. A second low current input voltage 1V or greater then the output voltage is required to achieve this dropout. The AMS1503 can also be used as a single supply device. New features have been added to the AMS1503: a remote Sense pin is brought out virtually eliminating output voltage variations due to load changes. The typical load regulation, measured at the Sense pin, for a load current step of 100mA to 3A is less than 1mV. The AMS1503 series has fast transient response. The Adjust pin is brought out on fixed devices. To further improve the transient response the addition of a small capacitor on the Adjust pin is recommended. The AMS1503 series are ideal for generating power supplies of 2V to 3V where both 5V and 3.3V supplies are available. The AMS1503 devices are offered in 5 lead TO-220, 5L TO-263 (plastic DD) and 5L TO-252 (DPAK) packages.
    AMS1503CM 订购型号
    5 LEAD TO-263 5 LEAD TO-220 5 LEAD TO-252  温度范围
    AMS1503CM AMS1503CT AMS1503CD 0 to 125° C
    AMS1503CM-1.5 AMS1503CT-1.5 AMS1503CD-1.5 0 to 125° C
    AMS1503CM-2.5 AMS1503CT-2.5 AMS1503CD-2.5 0 to 125° C
    AMS1503CM-2.85 AMS1503CT-2.85 AMS1503CD-2.85 0 to 125° C
    AMS1503CM-3.0 AMS1503CT-3.0 AMS1503CD-3.0 0 to 125° C
    AMS1503CM-3.3 AMS1503CT-3.3 AMS1503CD-3.3 0 to 125° C
    AMS1503CM-3.5 AMS1503CT-3.5 AMS1503CD-3.5 0 to 125° C
    AMS1503CM-5.0 AMS1503CT-5.0 AMS1503CD-5.0 0 to 125° C
    AMS1503CM 技术支持
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
