龙人旗下深圳市龙芯世纪科技有限公司
  • AMS3107
  • 发布时间:2009/9/16 9:28:09   修改时间:2009/9/16 9:28:09 浏览次数:2423
  • AMS3107
    AMS3107 series consists of positive fixed and adjustable voltage regulators ideally suited for use in battery-powered systems. These devices feature very low quiescent current of 0.8mA or less when supplying 50mA loads. This unique characteristic and the extremely low input-output differential required for proper regulation (0.2V for output currents of 100mA) make the AMS3107 ideal to use for standby power systems. Internal circuitry of AMS3107 is protected from input fault conditions caused by reverse battery installation or input voltages that exceed maximum rated input voltage. During line transients, such as load dump (40V) when the input voltage to the regulator can momentarily exceed the specified maximum operating voltage, the regulator will automatically shut down to protect both internal circuits and the load. The AMS3107 series also includes internal current limiting, thermal shutdown, and is able to withstand temporary power-up with mirror-image insertion. The AMS3107 is offered in the 3-pin TO-92 package, SOT-89, SOT-223, TO-252 and 8 lead SOIC packages and operates over the industrial temperature range.
    AMS3107 订购型号
      3L TO-92 SOT-89 TO-252 SOT-223 SO-8 温度范围
    FIXED AMS3107CN-X AMS3107CL-X AMS3107CD-X AMS3107C-X AMS3107CS-X -40 to 85° C
    AMS3107N-X AMS3107L-X AMS3107D-X AMS3107-X AMS3107S-X -40 to 85° C
    ADJ         AMS3107S -40 to 85° C
    AMS3107 技术支持
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
