龙人旗下深圳市龙芯世纪科技有限公司
  • AMS2950 AMS2951
  • 发布时间:2009/9/16 9:28:48   修改时间:2009/9/16 9:28:48 浏览次数:1651
  • AMS2950 AMS2951
    AMS2950 /AMS2951 are micro power voltage regulators ideally suited for use in battery-powered systems. These devices feature very low quiescent current (typ.75?A), and very low dropout voltage (typ.45mV at light loads and 380mV at 150mA) thus prolonging battery life. The quiescent current increases only slightly in dropout. The AMS2950/AMS2951 has positive transient protection up to 60V and can survive unregulated input transient up to 20V below ground. The AMS2950 and AMS2951 were designed to include a tight initial tolerance (typ. 0.5%), excellent load and line regulation (typ. 0.05%), and a very low output voltage temperature coefficient, making these devices useful as a low-power voltage reference. The AMS2950 is offered in the 3-pin TO-92 package. AMS2951 is available in 8-pin plastic SOIC and DIP packages and offers three major additional system features. An error flag output warns of a low output voltage, often due to failing batteries on input. The AMS2951 also features the logic-compatible shutdown input which enables the regulator to be switched on and off. The AMS2951 device may be pin-strapped for a 2.5V, 3.0V, 3.3V or 5.0V output, or programmed from 1.24V to 29V with an external pair of resistors.
    AMS2950 AMS2951 订购型号
    TO-92 8 LEAD PDIP 8 LEAD SOIC 温度范围
    AMS2950ACN-X AMS2951ACP- AMS2951ACS-X IND.
    AMS2950CN-X AMS2951CP-X AMS2951CS-X IND
    AMS2950 AMS2951 技术支持
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
