龙人旗下深圳市龙芯世纪科技有限公司
  • AT27C020-55JU 2Mbit, OTP EPROM存储器PLCC-32封装
  • 发布时间:2009/9/22 9:32:04   修改时间:2009/9/22 9:32:04 浏览次数:1355
    Density 2M
    Organization 256K x 8
    Speed 55,90 ns
    Vcc (V) 5
    Packages TSOP 32
    VSOP 32
    PLCC 32
    Pb-Free Packages TSOP 32
    PLCC 32
    2M bit EPROM
    The AT27C020 is a low-power, high-performance, 2,097,152-bit, one-time programmable read-only memory (OTP EPROM) organized as 256K by 8 bits. It requires only one 5V power supply in normal read mode operation. Any byte can be accessed in less than 55 ns, eliminating the need for speed-reducing WAIT states on highperformance microprocessor systems. In read mode, the AT27C020 typically consumes 8 mA. Standby mode supply current is typically less than 10 μA.
    The AT27C020 is available in a choice of industry-standard JEDEC-approved onetime programmable (OTP) plastic PDIP, PLCC and TSOP packages. All devices feature two-line control (CE, OE) to give designers the flexibility to prevent bus contention. With 256K bytes storage capability, the AT27C020 allows firmware to be stored reliably and to be accessed by the system without the delays of mass storage media. Atmel’s AT27C020 has additional features to ensure high quality and efficient production use. The Rapid Programming Algorithm reduces the time required to program the part and guarantees reliable programming. Programming time is typically only 100 μs/byte. The Integrated Product Identification Code electronically identifies the device and manufacturer. This feature is used by industry-standard programming equipment to select the proper programming algorithms and voltages.
    AT27C020-55JU 特性
    • Fast Read Access Time – 55 ns
    • Low-power CMOS Operation
      – 100 μA Max Standby
      – 25 mA Max Active at 5 MHz
    • JEDEC Standard Packages
      – 32-lead PDIP
      – 32-lead PLCC
      – 32-lead TSOP
    • 5V ± 10% Supply
    • High-reliability CMOS Technology
      – 2,000V ESD Protection
      – 200 mA Latch-up Immunity
    • Rapid Programming Algorithm – 100 μs/Byte (Typical)
    • CMOS- and TTL-compatible Inputs and Outputs
    • Integrated Product Identification Code
    • Industrial and Automotive Temperature Ranges
    • Green (Pb/Halide-free) Packaging Option
    AT27C020-55JU 订购型号
    Ordering Code Package ICC (mA)
    VCC = 3.6V
    tACC
    (ns)
    Operation Range
    Active AStandby
    AT27C020-55JU
    AT27C020-55PU
    AT27C020-55TU
    32J
    32P6
    32T
     25  0.1 55  Industrial (-40°C to +85°C)
    AT27C020-90JU
    AT27C020-90PU
    AT27C020-90TU
    32J
    32P6
    32T
    90
    AT27C020-55JU 技术支持:
    1. ATMEL 爱特梅尔EPROM 存储器AT27C020 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. EPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT27CXXX Series (1 pages, updated 10/98) . pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
