龙人旗下深圳市龙芯世纪科技有限公司
  • 超高速整流器
  • 发布时间:2012/7/7 10:44:31   修改时间:2012/7/7 10:44:31 浏览次数:1486
  • 超高速整流器
    超高速整流器
    型号 概述
    PKC-136 PEAK CLAMP
    STTH10002 Ultrafast recovery diode
    STTH1002C High Efficiency Ultrafast Diode
    STTH1003S High Efficiency Rectifier
    STTH102 High Efficiency Fast Recovery Diode
    STTH108 High Voltage Ultrafast Rectifier Diode
    STTH10BC065C 650 V high voltage rectifier for BC2 toplology
    STTH10LCD06 Turbo 2 ultrafast - high voltage rectifier for LCD SMPS
    STTH10LCD06C Turbo2 ultrafast - high voltage rectifier for SMPS
    STTH110 High Voltage Ultrafast Rectifier Diode
    STTH112 High Voltage Ultrafast Rectifier Diode
    STTH12003 Ultrafast Recovery Rectifier Diode
    STTH12010TV Ultrafast recovery - high voltage diode
    STTH12012TV Ultrafast recovery - 1200 V diode
    STTH1202 Ultrafast recovery diode
    STTH120L06TV TURBO 2 Ultrafast High Voltage Rectifier
    STTH120R04TV Ultrafast recovery diodes
    STTH1210 Ultrafast recovery - high voltage diode
    STTH1212 Ultrafast recovery - 1200 V diode
    STTH12R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH12S06 Turbo 2 ultrafast high voltage rectifier
    STTH1302 High Efficiency Fast Recovery Diode
    STTH1502 Ultrafast recovery diode
    STTH1506D Tandem 600V Hyperfast Boost Diode
    STTH1506TPI Tandem 600V Hyperfast Rectifier
    STTH1512 Ultrafast recovery - 1200 V diode
    STTH15L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH15R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH16003 Ultrafast Recovery Rectifier Diode
    STTH1602C High Efficiency Ultrafast Diode
    STTH16BC065C 650 V high voltage rectifier for BC2 topology
    STTH16L06C TURBO 2 Ultrafast High Voltage Rectifier
    STTH16R04C Ultrafast recovery diodes
    STTH1L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH1R02 Ultrafast recovery diode
    STTH1R04 Ultrafast recovery diode
    STTH1R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH20002TV High Efficiency Ultrafast Diode
    STTH20003 Ultrafast Recovery Rectifier Diode
    STTH20004TV1 Ultrafast high voltage rectifier
    STTH2002 Ultrafast recovery diode
    STTH2002C High Efficiency Ultrafast Diode
    STTH2003 Ultrafast Recovery Rectifier Diode
    STTH200L04TV1 Ultrafast high voltage rectifier
    STTH200L06TV TURBO 2 Ultrafast High Voltage Rectifier
    STTH200R04TV Ultrafast recovery diodes
    STTH208 High Voltage Ultrafast Rectifier Diode
    STTH20LCD06C Turbo2 ultrafast - high voltage rectifier for SMPS
    STTH20R04 High efficiency recrifier
    STTH212 High voltage ultrafast diode
    STTH2L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH2R02 Ultrafast recovery diode
    STTH2R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH3002 Ultrafast recovery diode
    STTH3002C High Efficiency Ultrafast Diode
    STTH3003 Ultrafast Recovery Rectifier Diode
    STTH3006 Turbo 2 utrafast high voltage rectifier
    STTH3006D Tandem 600V Hyperfast Boost Diode
    STTH3010 Ultrafast recovery - high voltage diode
    STTH3012 Ultrafast recovery - 1200 V diode
    STTH302 High Efficiency Fast Recovery Diode
    STTH302S High Efficiency Fast Recovery Diode
    STTH30L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH30L06C Turbo 2 ultrafast high voltage rectifier
    STTH30R02DJF Ultrafast recovery diode high efficiency
    STTH30R03 Ultrafast Recovery Rectifier Diode
    STTH30R04 Ultrafast recovery diodes
    STTH30R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH30R06C TURBO 2 Ultrafast High Voltage Rectifier
    STTH310 High Voltage Ultrafast Rectifier Diode
    STTH312 Ultrafast recovery - 1200 V diode
    STTH3BCF060 600 V high voltage freewheel rectifier for BC2 topology
    STTH3L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH3R02 Ultrafast recovery diode
    STTH3R04 Ultrafast recovery diode
    STTH3R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH40P03S Ultrafast rectifier PDP energy recovery
    STTH4L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH4R02 Ultrafast recovery diode
    STTH506 Turbo 2 ultrafast _ high voltage rectifier
    STTH506D Tandem 600V Hyperfast Boost Diode
    STTH512 Ultrafast recovery - 1200 V diode
    STTH5BCF060 600 V high voltage freewheel rectifier for BC2 topology
    STTH5L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH5R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH5R06DJF Ultrafast recovery diode high efficiency
    STTH6002C High Efficiency Ultrafast Diode
    STTH6003 Ultrafast Recovery Rectifier Diode
    STTH6004W Ultrafast high voltage rectifier
    STTH6006TV Turbo2 ultrafast - high voltage rectifier
    STTH6006W Turbo 2 ultrafast - high voltage rectifier
    STTH6010 Ultrafast recovery - high voltage diode
    STTH6012 Ultrafast recovery - 1200 V diode
    STTH602C Ultrafast recovery diode
    STTH60L04W Ultrafast high voltage rectifier
    STTH60L06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH60L06C TURBO 2 Ultrafast High Voltage Rectifier
    STTH60L06TV TURBO 2 Ultrafast High Voltage Rectifier
    STTH60P03S Ultrafast rectifier PDP energy recovery
    STTH60R04 Ultrafast recovery diodes
    STTH6110TV Ultrafast recovery - high voltage diode
    STTH6112TV Ultrafast recovery - 1200 V diode
    STTH61R04TV Ultrafast recovery diodes
    STTH8003 Ultrafast Recovery Rectifier Diode
    STTH8006 Turbo 2 ultrafast high voltage rectifier
    STTH802 Ultrafast recovery diode
    STTH802C High Efficiency Fast Recovery Diode
    STTH803 Ultrafast Recovery Rectifier Diode
    STTH806 Turbo 2 ultrafast - high voltage rectifier
    STTH806DTI Tandem 600 V hyperfast boost diode
    STTH806TTI Tandem 600V Ultrafast Boost Diode
    STTH810 Ultrafast recovery - high voltage diode
    STTH812 Ultrafast recovery -1200 V diode
    STTH8BC060 600 V high voltage rectifier for BC2 topology
    STTH8BC065 650 V high voltage rectifier for BC2 topology
    STTH8L06 Turbo 2 ultrafast high voltage rectifier
    STTH8R03 300V Hyperfast Rectifier
    STTH8R03DJF Ultrafast recovery diode high efficiency
    STTH8R04 Ultrafast recovery diodes
    STTH8R06 TURBO 2 Ultrafast High Voltage Rectifier
    STTH8S06 Turbo 2 ultrafast high voltage rectifier
    STTH9012TV Ultrafast recovery - 1200 V diode
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
