型号 |
概述 |
L4925 |
Very Low Drop Voltage Regulator |
L4938ED |
Standard Functions, Voltage Regulators |
L4938EPD |
Advanced voltage regulator |
L4949E |
5V Low drop voltage regulator |
L4949ED-E |
Multifunction very low drop voltage regulator |
L4949EP-E |
L4979D |
L4979MD |
L4988 |
L4993 |
Low drop voltage regulator with watchdog |
L4995 |
L5150BN |
L5150CJ |
L5150CS |
L5150GJ |
L5300AH7 |
L5300EPT |
5 V low dropout voltage regulator |
L5300GJ |
L5300RPT |
L9332 |
Quad Intelligent Power Low Side Switch |
L9333 |
Quad Low-Side Driver |
L9337MD |
Triple Low Side Driver |
L9338 |
L9339 |
L9362 |
Quad Low Side Driver |
L9380 |
Triple High Side MOSFET Driver |
L9386 |
Dual Intelligent Power Low Side |
L93PI |
L9613 |
Medium Speed Data interface |
L9615 |
High Speed Can Bus Tranceiver |
L9616 |
L9637 |
ISO9141 Interface |
L9651 |
Smart Quad Switch |
L9700 |
Hex precision limiter |
L9733 |
Octal configurable low/high side driver |
L9758 |
Multiple supply for engine control |
L9820 |
High Side Driver |
L9822E |
Octal Serial Solenoid Driver |
L9823 |
Octal Low-Side Driver for bulb, resistive and inductive loads with serial input control, output protection and diagnostic |
L9825 |
Octal Low-Side Driver for Resistive and Inductive Loads With Serial/Parallel lnput Control Output Protection and Diagnostic |
L9826 |
L9848 |
L9856 |
High voltage high side driver |
L9903 |
ISO9141 Motor Bridge Controller |
L9904 |
Motor bridge Controller |
L9930 |
Dual Full Bridge |
L9935 |
Two-Phase Stepper Motor Driver |
L9942 |
Stepper Motor Driver for Bipolar Motors with ustepping & programmable current profile |
L9958 |
SPI Controlled H-Bridge |
L9997ND |
Dual Half Bridge Driver |
L99H01 |
Motor bridge driver for automotive applications |
L99LD01 |
High Efficiency Constant Current Led Driver |
L99MC6 |
L99MD01 |
Standard Functions, Motor Drivers |
L99MD02 |
L99PD08 |
AMICO 8 Channel Pre Diagnosis Device |
VN02H |
HIGH SIDE SMART POWER SOLID STATE RELAY |
VN02N |
VN03 |
ISO HIGH SIDE SMART POWER SOLID STATE RELAY |
VN03-E |
VN06 |
VN06SP |
VN16B |
HIGH SIDE SMART POWER SOLID STATE RELAY; ISO HIGH SIDE SMART POWER SOLID STATE RELAY |
VN16BSP |
VN31 |
VN31SP |
VN460SP |
SINGLE CHANNEL HIGH SIDE SMART SOLID STATE RELAY |
VN5010AK-E |
Single channel high side switch |
VN5012AK-E |
VN5016AJ-E |
Single channel high side driver with analog current sense for automotive applications |
VN5025AJ-E |
Single channel high side driver |
VN5050AJ-E |
VN5050J-E |
Single channel high side driver for automotive applications |
VN5160S-E |
Single channel high side drive for automotive applications |
VN5770AKP-E |
Quad smart power solid state relay for complete H-bridge configurations |
VN5772AK-E |
Quad smart power solid state relay for complete H bridge configurations |
VN5E006ASP-E |
Single channel high-side driver with analog current sense for automotive applications |
VN5E010AH |
10 m} high-side driver with analog current sense for automotive applications |
VN5E010MH-E |
Single-channel high-side driver with analog current sense for automotive applications |
VN5E016AH-E |
16 m} high side driver with analog current sense for automotive applications |
VN5E025AJ-E |
VN5E050AJ-E |
VN5E050J-E |
VN5E050MJ-E |
VN5E160AS-E |
Single channel high side driver with analog for automotive applications |
VN5E160MS-E |
Single-channel high-side driver with analog for automotive applications |
VN5E160S-E |
VN5R003H-E |
3 mOhm reverse battery protection switch |
VN610SP |
SINGLE CHANNEL HIGH SIDE SOLID STATE RELAY |
VN610SP-E |
VN750 |
High Side Driver |
VN750-E |
High Side Driver |
VN750PS-E |
High Side Driver |
VN750SM |
High Side Driver |
VN750SMP-E |
Single channel high-side driver |
VN770K |
VN770KP-E |
VN771K |
Quad smart power solid state relay for complete H-bridge configuration |
VN772K |
VN772KP-E |
VN800PS-E |
High-side driver |
VN800PT-E |
High Side Driver |
VN800S-E |
High Side Driver |
VN820 |
High Side Driver |
VN820-E |
High Side Driver |
VN920 |
VN920-E |
High Side Driver; SINGLE CHANNEL HIGH SIDE SOLID STATE RELAY |
VN920B5-E |
VN920D-B5 |
High Side Driver |
VN920DB5-E |
High-side driver |
VN920DSP |
VN920PEP-E |
VN920SP |
VN920SP-E |
VNB10N07 |
OMNIFET :FULLY AUTOPROTECTED POWER MOSFET |
VNB14N04 |
VNB14NV04 |
OMNIFET :FULLY AUTOPROTECTED POWER MOSFET; OMNIFET II :FULLY AUTOPROTECTED POWER MOSFET |
VNB20N07 |
VNB28N04 |
VNB35N07 |
VNB35NV04 |
VNB49N04 |
VND05B(012Y) |
DOUBLE CHANNEL HIGH SIDE SMART POWER SOLID STATE RELAY |
VND05BSP |
VND10N06 |
VND14NV04 |
VND14NV04-1 |
VND1NV04 |
VND3NV04 |
VND3NV04-1 |
VND5004A-E |
Double 4mOhm high side driver with analog current sense for automotive applications |
VND5004ASP30-E |
VND5004B-E |
Double 4m Ohm high side driver with analog current sense for automotive applications |
VND5004BSP30-E |
VND5012AK-E |
Double channel high side driver with analog current sense for automotive applications |
VND5025AK-E |
Double channel high side driver with analog current sense |
VND5025LAK-E |
SMART POWER HIGH SIDE SWITCH - DOUBLE CHANNEL |
VND5050AJ-E |
Double channel high side driver with analog current sense; to be inherit |
VND5050AK-E |
VND5050J-E |
VND5050K-E |
VND5160AJ-E |
VND5160J-E |
Double channel high side driver for automotive applications |
VND5E004A-E |
Double 4m? high-side driver with analog current sense |
VND5E004ASP30-E |
Double 4m? high-side driver with analog current sense for automotive applications |
VND5E006ASP-E |
VND5E008AY-E |
VND5E008MY-E |
Double channel high-side driver with analog current sense for automotive applications |
VND5E012AY-E |
VND5E012MY-E |
VND5E025AK-E |
VND5E025BK-E |
VND5E025LK-E |
VND5E025MK-E |
VND5E050ACJ-E |
VND5E050ACK-E |
VND5E050AJ-E |
VND5E050AK-E |
VND5E050J-E |
VND5E050K-E |
VND5E050MCJ-E |
VND5E050MCK-E |
VND5E050MJ-E |
Double-channel high-side driver with analog current sense for automotive applications |
VND5E050MK-E |
VND5E160AJ-E |
VND5E160J-E |
VND5E160MJ-E |
VND5N07 |
VND5T035AK-E |
Double Channel High Side Driver with Analog Current Sense for 24V Automotive Applications |
VND5T100AJ-E |
Double channel high-side driver with analog current sense |
VND600 |
DOUBLE CHANNEL HIGH SIDE SOLID STATE RELAY |
VND600P-E |
VND600PEP-E |
DOUBLE CHANNEL HIGH SIDE DRIVER |
VND600SP |
VND600SP-E |
VND7N04 |
VND7N04-1 |
VND7NV04 |
VND7NV04-1 |
VND810 |
VND810MSP-E |
VND810P-E |
Standard Functions, High Side Switches |
VND810PEP-E |
VND810SP |
VND810SP-E |
VND830 |
VND830AEP-E |
VND830ASP |
VND830ASP-E |
VND830E-E |
VND830LSP |
VND830LSP-E |
VND830MSP |
VND830MSP-E |
VND830P-E |
Double channel high-side driver |
VND830PEP-E |
VND830SP |
VND830SP-E |
VND920 |
VND920P-E |
VNH2SP30-E |
AUTOMOTIVE FULLY INTEGRATED H-BRIDGE MOTOR DRIVER |
VNH3ASP30-E |
VNH3SP30-E |
VNH5019A-E |
Automotive fully integrated H-bridge motor driver |
VNH5050A-E |
VNH5180A-E |
VNL5050N3-E |
OMNIFET III fully protected low-side driver |
VNL5050S5-E |
VNL5160N3-E |
VNL5160S5-E |
Standard Functions, Low Side Switches |
VNN1NV04 |
VNN1NV04P-E |
VNN3NV04 |
VNN3NV04P-E |
OMNIFET II fully autoprotected Power MOSFET |
VNN7NV04 |
VNN7NV04P-E |
OMNIFET II - fully autoprotected Power MOSFET |
VNP10N06 |
OMINFET: FULLY AUTOPROTECTED POWER MOSFET |
VNP10N07 |
VNP20N07 |
VNP28N04 |
VNP35N07 |
OMNIFET FULLY AUTOPROTECTED POWER MOSFET |
VNP35NV04 |
VNP49N04 |
VNP5N07 |
VNP7N04 |
VNQ05XSP16 |
QUAD CHANNEL HIGH SIDE SOLID STATE RELAY |
VNQ500 |
M0-3.5; Single channel high side switch |
VNQ5027AK-E |
Quad channel high side driver with analog current sense for automotive applications |
VNQ5050AK-E |
Quad channel high side driver with analog current sense for automotive application |
VNQ5050K-E |
VNQ5160K-E |
Quad channel high side driver with analog current sense for automotive applications; Quad channel high side switch |
VNQ5E050AK-E |
VNQ5E050K-E |
VNQ5E050MK-E |
VNQ5E160AK-E |
VNQ5E160K-E |
VNQ5E250AJ-E |
VNQ600 |
VNQ600A |
VNQ600AP-E |
VNQ600P-E |
VNQ6040S-E |
Quad-channel high-side driver |
VNQ660SP |
VNQ690SP |
VNQ690SP-E |
VNQ810 |
QUAD CHANNEL HIGH SIDE SOLID |
VNQ810M |
VNQ810M-E |
VNQ810P-E |
Quad Channel High Side Driver |
VNQ810PEP-E |
VNQ830 |
VNQ830M |
VNQ830M-E |
VNQ830P-E |
VNQ830PEP-E |
VNS14NV04 |
VNS14NV04P-E |
VNS1NV04 |
VNS1NV04D |
VNS1NV04DP-E |
VNS1NV04P-E |
VNS3NV04 |
VNS3NV04D |
VNS3NV04D-E |
OMNIFET II: FULLY AUTOPROTECTED POWER MOSFET |
VNS3NV04DP-E |
VNS7NV04 |
VNS7NV04P-E |
VNV10N07 |
VNV14N04 |
VNV20N07 |
VNV28N04 |
VNV35N07 |
VNV35NV04 |
VNV49N04 |
