龙人旗下深圳市龙芯世纪科技有限公司
  • 汽车电子 专用功能
  • 发布时间:2012/7/7 10:55:41   修改时间:2012/7/7 10:55:41 浏览次数:1390
  • 专用功能
    专用功能
    型号 概述
    L9347 four channel valve driver
    L9348 four channel valve driver
    L9349-LF four channel valve driver
    L9352B four channel valve driver
    L9374 four channel valve driver
    L9390 Twelve channel valve driver
    L9466 Car alternator Voltage Regulator with Diagnostic Lamp
    L9468 Alternator voltage regulator with protected diagnostic lamp driver
    L9473 Car Alternator Regulator with NTC Compenation and Diagnostic Lamp
    L9484 Alternator voltage regulator
    L9911 Multifunction Smart Regulator with Lamp/Relay Diagnostic Driver
    L9949 Door actuator driver
    L9950 Door actuator driver
    L9950XP Door actuator driver
    L9951 Rear Door Actuator Driver
    L9952GXP Power management system IC
    L9953 Door actuator driver
    L9953LXP Door actuator driver
    L9954 Door actuator driver
    L9954LXP Specific Functions, Door Module Drivers
    L99DZ70XP Door actuator driver with 6 bridges for double door lock control, mirror fold and mirror axis control, highside driver for mirro
    L99DZ80EP Door actuator driver
    L99DZ81EP Door Actuator driver
    L99MM70XP Integrated microprocessor driven device intended for LIN controlled exterior mirrors
    L99PM60J Power Management IC with LIN transceiver
    L99PM62GXP Power Management IC with LIN and high speed CAN
    L99PM62XP Power management IC with LIN and high speed CAN
    L99PM72PXP Advanced power management system IC with embedded LIN and high speed CAN transceiver supporting CAN Partial Networking
    VB027SP-E High Voltage Ignition Coil Driver Power I.C.
    VB325SP HIGH VOLTAGE IGNITION COIL DRIVER POWER I.C.
    VB326SP HIGH VOLTAGE IGNITION COIL DRIVER POWER I.C.
    VB525SP-E High voltage ignition coil driver power integrated circuit
    VB526SP-E High voltage ignition coil driver power integrated circuit
    VBG15NB22T5SP-E Ignition coil driver
    VL5510 High dynamic range CMOS camera
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
