龙人旗下深圳市龙芯世纪科技有限公司
  • 车用娱乐IC
  • 发布时间:2012/7/7 10:57:54   修改时间:2012/7/7 10:57:54 浏览次数:3353
  • 车用娱乐IC
    车用娱乐IC
    型号 概述
    L4953G Voltage regulator with backup and reset, ignition comparator and low voltage warning
    L4954 Voltage regulator with backup and reset, overvoltage protection and low voltage warning
    L5950 Voltage regulator with I2C bus, very low stand-by current and low spread output voltage
    L5951 Voltage regulator with IDR J1850 interface, current/voltage limiter
    L5955 Voltage regulator with I2C, low voltage warning, short circuit protection and overvoltage shutdown
    L5956 Voltage regulator with ignition comparator, reset, overcurrent protection and 3.3V regulator with independent enable
    L5957 Voltage regulator with ignition comparator, reset, overcurrent protection, 5V regulator (CAN) with independent enable
    L5958 Switchable linear voltage regulators with reset and battery voltage warning
    L5959 Voltage regulator with very low stand-by current, reset, hold, backup, under/over voltage detection, overcurrent limitation
    L5962 Voltage regulator with dc-dc plus switchable linear regulators controlled by I2C bus
    STA1052 CD-MP3 audio SOC
    STA3005 Dual-IF AM/FM digital Radio receiver
    STPA001 High sound quality quad BTL output power amplifier with st-by and mute inputs, clip and offset detection, start stop compatibility; High sound quality quad BTL output power amplifier with st-by and mute inputs, clip detection, start stop compatibility
    TDA2004R Dual SE output power amplifier
    TDA2005 Single BTL or dual SE output amplifier
    TDA7256 Differential input, single BTL output power amplifier
    TDA7303 audio processor with loudness
    TDA7333N European (RDS) and American (RDBS) Standards Processor
    TDA7342 Audio Processor
    TDA7342EQ2N Audio Processor
    TDA7350A Single BTL or dual SE output power amplifier with stand-by input
    TDA7360 Single BTL or dual SE output power amplifier with stand-by input and clip detection
    TDA7365 Dual SE output power amplifier with power switch
    TDA7370B Quad SE or dual BTL output power amplifier with stand-by input and clip detection
    TDA7372A Quad SE output power amplifier with stand-by and mute inputs
    TDA7374 Double BTL output with stand-by input and clip detection
    TDA7375AV Dual SE or dual BTL output power amplifier with stand-by input and clip detection
    TDA7375V Quad SE or dual BTL output power amplifier with stand-by input and clip detection
    TDA7376B Differential input, dual BTL output power amplifier with programmable clip detection
    TDA7376PD Differential input, dual BTL output power amplifier with programmable clip detection
    TDA7381 Quad BTL output power amplifier with stand-by and mute inputs, clip detection
    TDA7384A Quad BTL output power amplifier with stand-by and mute inputs
    TDA7385 Quad BTL output power amplifier with stand-by and mute inputs, clip detection
    TDA7386 Quad BTL output power amplifier with stand-by and mute inputs
    TDA7388 Quad BTL output power amplifier with stand-by and mute
    TDA7388A Quad BTL output power amplifier with stand-by and mute inputs, clip and offset detections
    TDA7389 Quad BTL output power amplifier with stand-by and mute inputs, clip detection
    TDA7389A Quad BTL output power amplifier, with stand-by and mute inputs, clip and offset detections
    TDA7391 Differential input, single BTL output power amplifier with stand-by and clip detection
    TDA7391LV Differential input, single BTL output power amplifier with st-by, clip detection and start stop compatibility
    TDA7391PD Differential input, single BTL output power amplifier with stand-by and clip detection
    TDA7393 Dual BTL output power amplifier with stand-by and mute inputs
    TDA7396 Differential input, single BTL output power amplifier with clip detection
    TDA7404 Car Radio Signal Processor
    TDA7415CB Car radio multimedia signal processor
    TDA7416 Car Radio signal Processor with spectrum analyzer
    TDA7417 Audio Processor
    TDA7418 3 BAND CAR AUDIO PROCESSOR
    TDA7419 3Band Car Audio processor
    TDA7432 Basic Function Audio Processor
    TDA7454 Quad BTL output, high efficiency (class SB) power amplifier with clip detection, stand-by and mute inputs
    TDA7478 RDS Digital Demodulator + Filter
    TDA7479 RDS Demodulator + Filter
    TDA7505 Car radio dsp for advanced signal processing
    TDA7512F Fm Car Radio Tuner with Intelligent Selectivity System (ISS)
    TDA7528 AM/FM car radio Front-End receiver for IF sampling tuners
    TDA7529 RF front-end for AM/FM DSP car-radio with IF sampling
    TDA7540B Am/FM Tuner with Stereodecoder and Iss
    TDA7540N AM/FM car radio tuner IC with stereo decoder and intelligent selectivity system (ISS)
    TDA7541 AM/FM car radio tuner IC w stereo decoder and intelligent selectivity system
    TDA7541B AM/FM car radio tuner IC w stereo decoder and intelligent selectivity system
    TDA7560 Hi-fi quad BTL output power amplifier with HDS/offset detection, stand-by and mute
    TDA7560A Hi-fi quad BTL output power amplifier with HSD, offset detection , stand-by and mute
    TDA7561 Intelligent quad BTL output power amplifier with full I2C diagnostics (turn on, permanent)
    TDA7562 Intelligent quad BTL output power amplifier with full I2C diagnostics (permanent) and stand-by/mute input
    TDA7562B Intelligent quad BTL output power amplifier with full I2C diagnostics (permanent and ac) and stand-by/mute input
    TDA7563A Intelligent high efficiency (class SB) quad BTL output with full I2C diagnostics (turn on, permanent, ac) and stand-by/mute input
    TDA7563B Intelligent high efficiency (class SB) quad BTL output with full I2C diagnostics (turn on, permanent, ac) and stand-by/mute input
    TDA7564B Intelligent high efficiency (class SB) quad BTL ouput with full I2C diagnostics (turn on, permanent, ac)
    TDA7565 Intelligent high efficiency (class SB) quad BTL ouput with full I2C diagnostics, built in step up and mute input
    TDA7566 Intelligent quad BTL output with full I2C diagnostics
    TDA7567PD Intelligent high efficient (class SB) differential input, quad BTL output with full I2C diagnostics (turn on, permanent, ac)
    TDA7569LV Quad power amplifier with High efficiency, I2C diagnostic and start stop compatibility
    TDA7570 Single or dual PWM BTL output
    TDA7572 Single PWM BTL output power amplifier with built-in step-up
    TDA7575B Differential input, high efficient (class SB) dual BTL output with full I2C diagnostics, clip detection, stand-by and mute inputs
    TDA7705 Highly integrated tuner
    TDA7706 HIT2 Highly Integrated AM/FM Tuner with HD interface
    TDA7718N 3 BAND CAR AUDIO PROCESSOR
    TDA7719 3 BAND CAR AUDIO PROCESSOR
    TDA7801 Digital input (I2S) quad BTL output with full I2C diagnostics
    TDA7850 Quad BTL output with HSD/offset detection, stand-by and mute inputs
    TDA7850A Quad BTP output with HSD, offset detection , stand-by and mute inputs
    TDA7850LV Low voltage operation, quad BTL output with HDS/offset detection, stand-by and mute inputs
    TDA7851A Quad BTL output with stand-by and mute inputs, clip and offset detection
    TDA7851F Quad BTL output with stand-by and mute inputs, offset detection
    TDA7851L 4 x 45 W MOSFET quad bridge power amplifier
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
