龙人旗下深圳市龙芯世纪科技有限公司
  • 接口IC
  • 发布时间:2012/7/7 11:01:14   修改时间:2012/7/7 11:01:14 浏览次数:1665
  • 接口IC
    概述 电子档:
    ASI ASI
    达林顿二极管阵列 达林顿二极管阵列
    LVDS LVDS
    RS-232 RS-232
    RS-422 RS-423 RS-485 RS-422 RS-423 RS-485
    USB USB
    ASI
    型号 概述
    STPMS1 Smart sensor Dual channel 1st order ΣΔ modulator with embedded PGA
    STPM12 Single phase energy metering IC with pulsed output and digital calibration
    STPM01 PROGRAMMABLE SINGLE PHASE ENERGY METERING IC WITH TAMPER DETECTION
    STPM11 Single phase energy metering IC with pulsed output and digital calibration
    STPM13 Single phase energy metering IC with pulsed output and digital calibration
    STPMC1 Programmable poly-phase energy calculator IC
    STPM14 Single phase energy metering IC with pulsed output and digital calibration
    STPMS2 Smart sensor II Dual channel 2nd order sigma-delta modulator with embedded PGA
    ST802RT1A 10/100 real-time Ethernet 3.3 V transceiver
    ST8024L Smart card interface
    STPM10 Programmable single phase energy metering IC with tamper detection
    ST802RT1B 10/100 real-time Ethernet 3.3 V transceiver
    ST8024 Smartcard interface
    ST8004 Smartcard Interface for Class A-B Cards; NDS Compliance
    达林顿二极管阵列
    型号 概述
    ULN2001 Seven Darlington Arrays
    ULN2003 Seven Darlington Arrays
    ULN2004 Seven Darlington Arrays
    ULN2065B 80 V - 1.5 A quad Darlington switches
    ULN2066B 50 V - 1.5 A quad Darlington switches
    ULN2068B 50 V - 1.5 A quad Darlington switches
    ULN2069B 80 V - 1.5 A quad Darlington switches
    ULQ2001 Seven darlington array
    ULQ2003 Seven darlington array
    ULN2802A Eight Darlington Arrays
    ULN2803A Eight Darlington Arrays
    ULN2074B 50 V - 1.5 A quad Darlington switches
    ULN2064B 50 V - 1.5 A quad Darlington switches
    ULQ2004 Seven darlington array
    ULQ2802 Eight Darlington array
    ULN2002 Seven darlington array
    ULN2067B 80 V - 1.5 A quad Darlington switches
    ULQ2801 Eight Darlington array
    ULQ2803 Eight Darlington array
    ULQ2804 Eight Darlington array
    ULN2801A Eight Darlington Arrays
    ULN2804A Eight Darlington Arrays
    ULN2075B 80 V - 1.5 A quad Darlington switches
    LVDS
    型号 概述
    STLVD111B Programmable low voltage 1:10 differential LVDS clock driver
    STLVDS31B HIGH SPEED DIFFERENTIAL LINE DRIVERS
    STLVDS32B HIGH SPEED DIFFERENTIAL LINE RECEIVERS
    RS-232
    型号 概述
    ST202B 5V POWERED MULTI-CHANNEL RS-232 DRIVERS AND RECEIVERS
    ST202C 5V POWERED MULTI-CHANNEL RS-232 DRIVERS AND RECEIVERS
    ST202EB 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST202EC 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST207EB 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST207EC 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST232AB VERY HIGH SPEED, ULTRA LOW POWER CONSUMPTION 5V POWERED RS-232 DRIVERS AND RECEIVERS
    ST232AC VERY HIGH SPEED, ULTRA LOW POWER CONSUMPTION 5V POWERED RS-232 DRIVERS AND RECEIVERS
    ST232B 5V POWERED MULTI-CHANNEL RS-232 DRIVERS AND RECEIVERS
    ST232C 5V POWERED MULTI-CHANNEL RS-232 DRIVERS AND RECEIVERS
    ST232EB 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST232EC 15KV ESD PROTECTED 5V RS-232 TRANSCEIVER
    ST3222B 3 TO 3.6V, LOW POWER, UP TO 400 KBPS RS-232 DRIVERS AND RECEIVERS
    ST3222C 3 TO 3.6V, LOW POWER, UP TO 400 KBPS RS-232 DRIVERS AND RECEIVERS
    ST3222EB 15 KV ESD PROTECTED 3 TO 5.5V, LOW POWER, UP TO 250KBPS RS-232 DRIVERS AND RECEIVERS
    ST3222EC 15 KV ESD PROTECTED 3 TO 5.5V, LOW POWER, UP TO 250KBPS RS-232 DRIVERS AND RECEIVERS
    ST3232B 3 TO 5.5V, LOW POWER, UP TO 400KBPS RS-232 DRIVERS AND RECEIVERS
    ST3232C 3 TO 5.5V, LOW POWER, UP TO 400KBPS RS-232 DRIVERS AND RECEIVERS
    ST3232EB 15KV ESD PROTECTED, 3 TO 5.5 V LOW POWER UP TO 250KBPS, RS232 DRIVERS AND RECEIVERS
    ST3232EC 15KV ESD PROTECTED, 3 TO 5.5 V LOW POWER UP TO 250KBPS, RS232 DRIVERS AND RECEIVERS
    ST3237EB 15KV ESP PROTECTED 3 TO 5.5V 250KBPS RS-232 TRANSCEIVER WITH STAND-BY
    ST3241EB 3 TO 5.5V 400KBPS, RS-232 TRANSCEIVER WITH AUTO-POWERDOWN
    ST3241EC 3 TO 5.5V 400KBPS, RS-232 TRANSCEIVER WITH AUTO-POWERDOWN
    ST3243C 3 to 5.5 V, 400 Kbps, RS-232 transceiver with auto-power-down
    ST3243EB ± 15 kV ESD protected 3 to 5.5 V, 400 kbps, RS-232 transceiver with auto power-down
    ST3243EC ± 15 kV ESD protected 3 to 5.5 V, 400 kbps, RS-232 transceiver with auto power-down
    ST75185C MULTIPLE RS-232 DRIVERS AND RECEIVERS
    型号 概述
    SERC816 SERCOS Interface controller
    ST1480AB 3.3V POWERED, 15KV ESD PROTECTED TRASMIT AT UP TO 12MBPS TRUE RS-485/RS422 TRANSCEIVER
    ST1480AC 3.3V POWERED, 15KV ESD PROTECTED TRASMIT AT UP TO 12MBPS TRUE RS-485/RS422 TRANSCEIVER
    ST26C31B CMOS QUAD TRI-STATE DIFFERENTIAL LINE DRIVER
    ST26C32AB CMOS QUAD 3-STATE DIFFERENTIAL LINE RECEIVER
    ST3485EB 3.3 V powered, 15 kV ESD protected, up to 12 Mbps RS-485/RS-422 transceiver
    ST3485EC 3.3 V powered, 15 kV ESD protected, up to 12 Mbps RS-485/RS-422 transceiver
    ST485AB VERY HIGH SPEED LOW POWER RS-485/RS-422 TRANSCEIVER
    ST485B LOW POWER RS-485/RS-422 TRANSCEIVER
    ST485C LOW POWER RS-485/RS-422 TRANSCEIVER
    ST485EB +/-15 kV ESD protected, low power RS-485/RS-422 transceiver
    ST485EC +/-15 kV ESD protected, low power RS-485/RS-422 transceiver
    ST485ERB ± 15 kV ESD protected, low power RS-485/RS-422 transceiver
    ST485EX +/-15 kV ESD protected, low power RS-485/RS-422 transceiver
    ST490AB Low power high speed RS-485/RS-422 transceiver
    USB
    型号 概述
    STULPI01B High speed USB On-The-Go ULPI transceiver
    STUSBCD01B USB charger detection interface
    STULPI01A High speed USB On-The-Go ULPI transceiver
    STOTG04ES USB-OTG Full-speed Transceiver with usb UART and Audio Operating Modes
    STUSB06E 3.3 V USB transceiver
    STOTG04E USB-OTG Full-speed Transceiver with USB, UART, Audio and I2C Operating Modes
    STUSB03E USB TRANSCEIVER
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
