龙人旗下深圳市龙芯世纪科技有限公司
  • 放大器
  • 发布时间:2012/7/7 11:06:02   修改时间:2012/7/7 11:06:02 浏览次数:1992
  • 放大器
    概述 电子档:
    运算放大器 运算放大器
    功率运算放大器 功率运算放大器
    运算放大器
    型号 概述
    LF247 JFET inputs, low input bias & offset current, (15nV/√Hz & 0.01%)
    LF253 JFET inputs, low input bias & offset current, (15nV/√Hz & 0.01%)
    LF347 JFET inputs, low input bias & offset current, (15nV/?Hz & 0.01%)
    LF351 JFET inputs, low input bias & offset current, (15nV/?Hz & 0.01%)
    LF353 JFET inputs, low input bias & offset current, (15nV/?Hz & 0.01%)
    LM124 Low power, low input bias current
    LM148 Quad UA741 bipolar op-amp
    LM158 Low power dual op-amps with low input bias current
    LM158W Low power dual operational amplifiers
    LM201A Input & output overload protection, low input offset current
    LM224 Low power quad op-amps with low input bias current
    LM224A Low power, low input bias current
    LM248 Quad UA741 bipolar op-amp
    LM258 Low-power dual op-amps with low input bias current
    LM258W Low power dual operational amplifiers
    LM2902 Low power, bipolar op-amp
    LM2902W Low power quad operational amplifier
    LM2904 Low power, bipolar op-amp
    LM2904A Low power, bipolar op-amp
    LM2904W Low Power Dual Operational Amplifier
    LM2904WH Dual general purpose operational amplifier
    LM301A Input & output overload protection, low input offset current
    LM324 Low power, low input bias current
    LM324A Low power, low input bias current
    LM324W Low power, low input bias current
    LM346 Programmable quad bipolar op-amp
    LM348 Quad UA741 bipolar op-amp
    LM358 Low-power dual op-amps with low input bias current
    LM833 Low-noise dual op-amps amplifier
    LMV321 Low cost low power rail-to-rail input/output op-amp
    LMV324 Low cost low power rail-to-rail input/output op-amp
    LMV358 Low cost low power rail-to-rail input/output op-amp
    LMV820 Low power, high accuracy, general purpose operational amplifier
    LMV820A Low power, high accuracy, general purpose operational amplifier
    LMV821 Low power, high accuracy, general purpose operational amplifier
    LMV821A Low power, high accuracy, general purpose operational amplifier
    LMV822 Low power, high accuracy, general purpose operational amplifier
    LMV822A Low power, high accuracy, general purpose operational amplifier
    LMV823 Low power, high accuracy, general purpose operational amplifier
    LMV823A Low power, high accuracy, general purpose operational amplifier
    LMV824 Low power, high accuracy, general purpose operational amplifier
    LMV824A Low power, high accuracy, general purpose operational amplifier
    LMV825 Low power, high accuracy, general purpose operational amplifier
    LMV825A Low power, high accuracy, general purpose operational amplifier
    LS204 Low-noise bipolar op-amps
    LS404 Low-noise bipolar op-amps
    MC1458 High performance dual op-amps with wide input common-mode voltage range
    MC1558 High performance dual op-amps with wide input common-mode voltage range
    MC3303 Quad enhanced UA741 version with lower consumption
    MC33078 Low-noise op-amps
    MC33079 Low-noise op-amps
    MC33171 Low consumption versus speed
    MC33172 Low consumption versus speed
    MC33174 Low consumption versus speed
    MC3403 Quad enhanced UA741 version with lower consumption
    MC4558 Widebandwidth dual bipolar op-amps
    TJM4558 Wide bandwidth dual bipolar op-amps
    TL061 JFET inputs, low input bias current
    TL062 JFET inputs, low input bias current
    TL062A JFET inputs, low input bias current
    TL062B JFET inputs, low input bias current
    TL064 JFET inputs, low input bias current
    TL071 JFET inputs, low input bias current
    TL072 JFET inputs, low input bias current
    TL072A JFET inputs, low input bias current
    TL072B JFET inputs, low input bias current
    TL074 JFET inputs, low input bias current
    TL081 JFET inputs, low input bias current
    TL082 JFET inputs, low input bias current
    TL084 JFET inputs, low input bias current
    TS1851 1.8V min. voltage supply, micropower
    TS1851A 1.8V min. voltage supply, micropower
    TS1852 1.8V min. voltage supply, micropower
    TS1852A 1.8V min. voltage supply, micropower
    TS1854 1.8V min. voltage supply, micropower
    TS1854A 1.8V min. voltage supply, micropower
    TS1871 1.8V Input/Output Rail-to-Rail Low Power Operational Amplifiers
    TS1871A 1.8V Input/Output Rail-to-Rail Low Power Operational Amplifiers
    TS1872 1.8V min. voltage supply, micropower
    TS1872A 1.8V min. voltage supply, micropower
    TS1874 1.8V min. voltage supply, micropower
    TS1874A 1.8V min. voltage supply, micropower
    TS271 Micropower, programmable op-amp
    TS272 Micropower, wide range of input offset voltage
    TS274 Micropower, wide range of input offset voltage
    TS27L2 Micropower, high voltage CMOS op-amp
    TS27L4 Micropower, high voltage CMOS op-amp
    TS27M2 Micropower, high voltage CMOS op-amp
    TS27M2A Micropower, high voltage CMOS op-amp
    TS27M2B Micropower, high voltage CMOS op-amp
    TS27M4 Micropower, high voltage CMOS op-amp
    TS321 Single LM324, LM358 enhanced version in sot23-5 package
    TS461 Output rail-to-rail op-amps
    TS462 Output rail-to-rail op-amps
    TS464 Output rail-to-rail op-amps
    TS507 High precision single supply rail to rail op-amp
    TS512 Precision op-amps
    TS512A Low noise & distortion (8nV/?Hz & 0.03%)
    TS514 Precision op-amps
    TS522 Precision low-noise dual op-amps
    TS524 Very low noise suitable for audio applications (4.5nV/?Hz)
    TS912 Low power with CMOS inputs
    TS912A Low power with CMOS inputs
    TS912B Low power with CMOS inputs
    TS914 Low power with CMOS inputs
    TS914A Low power with CMOS inputs
    TS921 Rail-to-rail high output current op-amps
    TS922 Excellent audio performance / low distortion (0.005%)
    TS9222 Precision rail-to-rail high output current op-amps
    TS9224 Precision rail-to-rail high output current op-amps
    TS922A Excellent audio performance / low distortion (0.005%)
    TS924 Rail-to-rail high output current op-amps
    TS924A Excellent audio performance / low distortion (0.005%)
    TS925 Excellent audio performance / low distortion (0.005%)
    TS931 Micropower amplifier with CMOS inputs
    TS931A Micropower amplifier with CMOS inputs
    TS931B Micropower amplifier with CMOS inputs
    TS932 Micropower amplifier with CMOS inputs
    TS932B Micropower amplifier with CMOS inputs
    TS934 Micropower amplifier with CMOS inputs
    TS934A Micropower amplifier with CMOS inputs
    TS934B Micropower amplifier with CMOS inputs
    TS941 Ultra-micropower amplifier with CMOS inputs
    TS941A Ultra-micropower amplifier with CMOS inputs
    TS941B Ultra-micropower amplifier with CMOS inputs
    TS942 Ultra-micropower amplifier with CMOS inputs
    TS942A Ultra-micropower amplifier with CMOS inputs
    TS944 Ultra-micropower amplifier with CMOS inputs
    TS944A Ultra-micropower amplifier with CMOS inputs
    TS951 Real input & output rail to rail / low distortion (0.01%)
    TS9511 Precision rail-to-rail input/output 3 MHz single operational amplifier
    TS952 Real input & output rail to rail / low distortion (0.01%)
    TS954 Real input & output rail to rail / low distortion (0.01%)
    TS971 Output rail-to-rail very low-noise op-amps
    TS972 Output rail-to-rail very low-noise op-amps
    TS974 Output rail-to-rail very low-noise op-amps
    TS982 High output current dual operational amplifier
    TSH22 High gain bandwidth product bipolar op-amp
    TSH24 High gain bandwidth product bipolar op-amp
    TSV321 General purpose low voltage rail to rail input/output op-amp
    TSV324 General purpose low voltage rail to rail input/output op-amp
    TSV358 General purpose low voltage rail to rail input/output op-amp
    TSV611 Rail to rail input/output CMOS op-amp
    TSV611A Rail to rail input/output CMOS op-amp
    TSV612 Rail to rail input/output CMOS op-amp
    TSV612A Rail to rail input/output CMOS op-amp
    TSV6191 Rail to rail input/output CMOS op-amp
    TSV6191A Rail to rail input/output CMOS op-amp
    TSV6192 Rail to rail input/output CMOS op-amp
    TSV6192A Rail to rail input/output CMOS op-amp
    TSV620 Micro-power CMOS op-amp with standby
    TSV620A Micro-power CMOS op-amp
    TSV621 Micro-power CMOS op-amp
    TSV621A Micro-power CMOS op-amp
    TSV622 Micro-power CMOS op-amp
    TSV622A Micro-power CMOS op-amp
    TSV623 Micro-power CMOS op-amp with standby
    TSV623A Micro-power CMOS op-amp with standby
    TSV624 Micro-power CMOS op-amp
    TSV624A Micro-power CMOS op-amp
    TSV625 Micro-power CMOS op-amp with standby
    TSV625A Micro-power CMOS op-amp with standby
    TSV6290 Micro-power CMOS op-amp with standby
    TSV6290A Micro-power CMOS op-amp
    TSV6291 Micro-power CMOS op-amp
    TSV6291A Micro-power CMOS op-amp
    TSV6292 Micro-power CMOS op-amp
    TSV6292A Micro-power CMOS op-amp
    TSV6293 Micro-power CMOS op-amp with standby
    TSV6293A Micro-power CMOS op-amp
    TSV6294 Micro-power CMOS op-amp
    TSV6294A Micro-power CMOS op-amp
    TSV6295 Micro-power CMOS op-amp with standby
    TSV6295A Micro-power CMOS op-amp with standby
    TSV630 Micro-power CMOS op-amp with standby
    TSV630A Micro-power CMOS op-amp with standby
    TSV631 Micro-power CMOS op-amp
    TSV631A Micro-power CMOS op-amp
    TSV632 Micro-power CMOS op-amp
    TSV632A Micro-power CMOS op-amp
    TSV633 Micro-power CMOS op-amp with standby
    TSV633A Micro-power CMOS op-amp with standby
    TSV634 Micro-power CMOS op-amp
    TSV634A Rail-to-rail input/output 60uA, 880kHz CMOS operational amplifiers
    TSV635 Micro-power CMOS op-amp with standby
    TSV635A Micro-power CMOS op-amp with standby
    TSV6390 Micro-power CMOS op-amp with standby
    TSV6390A Micro-power CMOS op-amp with standby
    TSV6391 Micro-power CMOS op-amp
    TSV6391A Micro-power CMOS op-amp
    TSV6392 Micro-power CMOS op-amp
    TSV6392A Micro-power CMOS op-amp
    TSV6393 Micro-power CMOS op-amp with standby
    TSV6393A Micro-power CMOS op-amp with standby
    TSV6394 Micro-power CMOS op-amp
    TSV6394A Micro-power CMOS op-amp
    TSV6395 Micro-power CMOS op-amp with standby
    TSV6395A Micro-power CMOS op-amp with standby
    TSV850 Low power, high accuracy, general purpose operational amplifier
    TSV850A Low-power, high accuracy, general-purpose operational amplifier
    TSV851 Low-power, high accuracy, general-purpose operational amplifier
    TSV851A Low-power, high accuracy, general-purpose operational amplifier
    TSV852 Low-power, high accuracy, general-purpose operational amplifier
    TSV852A Low-power, high accuracy, general-purpose operational amplifier
    TSV853 Low-power, high accuracy, general-purpose operational amplifier
    TSV853A Low-power, high accuracy, general-purpose operational amplifier
    TSV854 Low-power, high accuracy, general-purpose operational amplifier
    TSV854A Low-power, high accuracy, general-purpose operational amplifier
    TSV855 Low-power, high accuracy, general-purpose operational amplifier
    TSV855A Low-power, high accuracy, general-purpose operational amplifier
    TSV911 Rail to rail input/output widebandwidth op-amps
    TSV911A Rail to rail input/output widebandwidth op-amps
    TSV912 Rail to rail input/output widebandwidth op-amps
    TSV912A Rail to rail input/output widebandwidth op-amps
    TSV912H High temperature rail to rail input/output widebandwidth op-amps
    TSV914 Rail to rail input/output widebandwidth op-amps
    TSV914A Rail to rail input/output widebandwidth op-amps
    TSV991 Rail to rail input/output high merit factor op-amps
    TSV991A Rail to rail input/output high merit factor op-amps
    TSV992 Rail to rail input/output high merit factor op-amps
    TSV992A Rail to rail input/output high merit factor op-amps
    TSV994 Rail to rail input/output high merit factor op-amps
    TSV994A Rail to rail input/output high merit factor op-amps
    UA741 Wide applications range
    UA748 Wide applications range
    功率运算放大器
    型号 概述
    L165 3 A power operational amplifier
    L272 Dual power operational amplifier
    L2720W Low drop dual power operational amplifiers
    L2722 Low Drop Dual Power Operational Amplifier
    L2726 Dual Power Operational Amplifier
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
