龙人旗下深圳市龙芯世纪科技有限公司
  • 航空用逻辑IC
  • 发布时间:2012/7/7 11:11:58   修改时间:2012/7/7 11:11:58 浏览次数:2386
  • 航空用逻辑IC
    概述 电子档:
    抗辐射AC/ACT: 5V先进高速CMOS 抗辐射AC/ACT: 5V先进高速CMOS
    抗辐射CMOS 4000B系列4000 抗辐射CMOS 4000B系列4000
    抗辐射HC/HCT 抗辐射HC/HCT
    抗辐射VCX: 超低电压16位总线接口 抗辐射VCX: 超低电压16位总线接口
    型号 概述
    54AC00 Rad-Hard Quad 2-Input NAND Gate
    54AC02 Rad-Hard Quad 2-Input NOR Gate
    54AC04 Rad-Hard Hex Inverter
    54AC08 Rad-Hard Quad 2-Input AND Gate
    54AC10 Rad-Hard Triple 3-Input NAND Gate
    54AC11 Rad-Hard Triple 3-Input AND Gate
    54AC138 Rad-Hard 3 to 8 Line Decoder (Inv.); Rad-Hard 3 to 8 Line Decoder Inverter
    54AC139 Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
    54AC14 Rad-Hard Hex Schmitt Inverter
    54AC151 Rad-Hard 8-Channel Multiplexer
    54AC157 Rad-Hard Quad 2-Channel Multiplexer
    54AC161 Rad-Hard Synchronous Binary Counter With Async. Clear
    54AC16244 Rad-Hard 16-bit Transceiver Non Inverting
    54AC16245 Rad-Hard 16-bit Transceiver 3-state Inverting
    54AC16373 Rad-Hard 16-bit D-Type Latch 3-state
    54AC16374 Rad-Hard 16-bit D-Type Flip Flop 3-state
    54AC164245 Rad-Hard 16-bit transceiver, 3.3 to 5 V bidirectional level shifter transceiver
    54AC174 Rad-Hard Hex D-Type Flip-Flop With Clear; Rad-Hard Hex D-Type Flip-Flop with Clear
    54AC191 Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
    54AC240 Rad-Hard Octal Bus Buffer (3-State/Inv.); Rad-Hard Octal Bus Buffer 3-state Inverter
    54AC244 Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
    54AC245 Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-state
    54AC2525 Rad-Hard 1-to-8 Skew Clock Driver
    54AC273 Rad-Hard Octal D-Type Flip-Flop With Clear; Rad-Hard Octal D-Type Flip-Flop with Clear
    54AC32 Rad-Hard Quad 2-Input OR Gate
    54AC373 Rad-Hard Octal D-Type Latch (3-State); Rad-Hard Octal D-Type Latch 3-state
    54AC374 Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
    54AC521 Rad-Hard 8-bit Comparator with Enable
    54AC540 Rad-Hard Octal Buffer/Line Driver 3-State
    54AC541 Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
    54AC574 Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
    54AC74 Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
    54AC86 Rad-Hard Quad Exclusive OR Gate; Rad-Hard Quad exclusive OR
    54ACT00 Rad-Hard Quad 2-Input NAND Gate
    54ACT02 Rad-Hard Quad 2-Input NOR Gate
    54ACT04 Rad-Hard Hex Inverter
    54ACT08 Rad-Hard Quad 2-Input AND Gate
    54ACT10 Rad-Hard Triple 3-Input NAND Gate
    54ACT11 Rad-Hard Triple 3-Input AND Gate
    54ACT138 Rad-Hard 3 to 8 Line Decoder (Inv.); Rad-Hard 3 to 8 Line Decoder Inverter
    54ACT139 Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
    54ACT14 Rad-Hard Hex Schmitt Inverter
    54ACT151 Rad-Hard 8-Channel Multiplexer
    54ACT157 Rad-Hard Quad 2-Channel Multiplexer
    54ACT161 Rad-Hard Synchronous Binary Counter With Async. Clear
    54ACT16244 Rad-Hard 16-bit Transceiver Non Inverting
    54ACT16245 Rad-Hard 16-bit Transceiver 3-state Inverting
    54ACT16373 Rad-Hard 16-bit D-Type Latch 3-state
    54ACT16374 Rad-Hard 16-bit D-Type Flip-Flop 3-state
    54ACT174 Rad-Hard Hex D-Type Flip-Flop With Clear; Rad-Hard Hex D-Type Flip-Flop with Clear
    54ACT191 Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
    54ACT240 Rad-Hard Octal Bus Buffer (3-State/Inv.); Rad-Hard Octal Bus Buffer 3-state Inverter
    54ACT244 Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
    54ACT245 Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-state
    54ACT273 Rad-Hard Octal D-Type Flip-Flop With Clear; Rad-Hard Octal D-Type Flip-Flop with Clear
    54ACT32 Rad-Hard Quad 2-Input OR Gate
    54ACT373 Rad-Hard Octal D-Type Latch (3-State); Rad-Hard Octal D-Type Latch 3-state
    54ACT374 Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
    54ACT541 Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
    54ACT574 Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
    54ACT74 Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
    54ACT86 Rad-Hard Quad Exclusive OR Gate; Rad-Hard Quad exclusive OR
    抗辐射CMOS 4000B系列4000
    型号 概述
    HCC4001B Rad-hard quad 2-input NOR gate
    HCC4002B Rad-hard dual 4-input NOR gate
    HCC4008B Rad-hard 4-bit full adder
    HCC40103B Rad-hard presettable 8-bit binary down counter
    HCC40106B Rad-hard hex schmitt trigger
    HCC40107B Rad-hard dual 2-input NAND buffer/driver
    HCC40109B Rad-hard quad low-to-high voltage level shifter
    HCC4011B Rad-Hard Quad 2-Input NAND Gate
    HCC4012B Rad-Hard Dual 4-Input NAND Gate; Rad-hard dual 4-input NAND gate
    HCC4013B Rad-Hard Dual D Flip-Flop
    HCC4014B Rad-hard 8-stage static synchronous shift register
    HCC4015B Rad-hard dual 4-stage static shift register
    HCC40161B Rad-Hard Binary Counter with Asynchronous Clear
    HCC4016B Rad-Hard Quad Bilateral Switch
    HCC40174B Rad-Hard Hex D Flip-Flop
    HCC4017B Rad-Hard Decade Counter/Divider
    HCC4018B Rad-hard presettable divide-by N counter
    HCC40193B Rad-hard presettable 4-bit binary up-down counter
    HCC4019B Rad-Hard Quad AND/OR Select Gate; Rad-hard quad AND/OR select gate
    HCC4020B Rad-hard 14-stage binary/ripple counter
    HCC4021B Rad-hard 8-stage static shift register
    HCC4022B Rad-Hard Divide-By-8 Counter/Divider
    HCC4023B Rad-hard triple 3-input NAND gate
    HCC4024B Rad-hard 7-stage binary/ripple counter
    HCC4025B Rad-Hard Triple 3-Input NOR Gate
    HCC4027B Rad-hard dual J-K master-slave Flip-Flop
    HCC4028B Rad-hard BCD-to-decimal decoder
    HCC4029B Rad-hard presettable up/down counter
    HCC4030B Rad-hard quad exclusive OR gate
    HCC4034B Rad-hard 8-stage static bidirectional bus register
    HCC4035B Rad-hard 4-stage parallel I/O shift register
    HCC4040B Rad-hard 12-stage binary/ripple counter
    HCC4041UB Rad-hard quad true/complement buffer
    HCC4042B Rad-hard quad clocked D latch
    HCC4043B Rad-hard quad 3-state NOR R/S latch
    HCC4044B Rad-Hard Quad 3-State NAND R/S Latch
    HCC4046B Rad-hard micropower phase locker loop
    HCC4047B Rad-hard monostable/astable multivibrator
    HCC4049UB Rad-hard hex inverting buffer/converter
    HCC4050B Rad-hard hex non-inverting buffer/converter
    HCC4051B Rad-hard single 8-channel analog mux/demux
    HCC4052B Rad-hard different 4-channel analog mux/demux
    HCC4053B Rad-hard triple 2-channel analog mux/demux
    HCC4060B Rad-hard 14-stage counter/divider AND oscillator
    HCC4063B Rad-hard 4-bit magnitude comparator
    HCC4066B Rad-hard quad bilateral switch
    HCC4067B Rad-hard single 16-channel analog mux/demux
    HCC4068B Rad-hard 8-input NAND/AND gate
    HCC4069UB Rad-hard hex inverter
    HCC4070B Rad-hard quad exclusive OR gate
    HCC4071B Rad-hard quad 2-input OR gate
    HCC4072B Rad-hard dual 4-input OR gate
    HCC4073B Rad-hard triple 3-input AND gate
    HCC4075B Rad-hard triple 3-input OR gate
    HCC4076B Rad-hard 4-bit D-type register
    HCC4077B Rad-hard quad exclusive NOR gate
    HCC4078B Rad-hard 8-input NOR/OR gate
    HCC4081B Rad-hard quad 2-input AND gate
    HCC4082B Rad-hard dual 4-input AND gate
    HCC4093B Rad-hard quad 2-input NAND Schmitt trigger
    HCC4094B Rad-hard 8-stage shift-and-store bus register
    HCC4098B Rad-hard dual monostable multivibrator
    HCC4099B Rad-hard 8-bit addressable latch
    HCC4502B Rad-hard strobed hex inverter/buffer
    HCC4503B Rad-Hard Hex Buffer (3-State Non-Inverter); Rad-hard hex buffer 3-state non-inverter
    HCC4508B Rad-hard dual 4-bit Latch 3-state outputs
    HCC4512B Rad-hard 8-channel data selec. with 3-state output
    HCC4514B 4-Bit Latch/4-To-16 Line Dec. (Out. High); Rad-hard 4-bit Latch / 4-to-16 line decoder output high
    HCC4515B 4-Bit Latch/4-To-16 Line Dec. (Out. Low); Rad-hard 4-bit Latch / 4-to-16 line decoder output low
    HCC4516B Rad-hard presettable 4-bit binary up/down counter
    HCC4520B Rad-hard dual binary up-down counter
    HCC4532B Rad-hard 8-input priority encoder
    HCC4538B Rad-Hard Dual Precision Monostable Multivibrator; Rad-hard dual precision monostable multivibrator
    HCC4555B Rad-Hard Dual 1-Of-4 Decoder/Demultiplexer (Out. High); Rad-hard dual 1-of-4 decoder/demux output high
    HCC4556B Rad-Hard Dual 1-of-4 Decoder/Demultiplexer (Out. Low); Rad-hard dual 1-of-4 decoder/demux output low
    抗辐射HC/HCT
    型号 概述
    M54HC00 Rad-Hard Quad 2-Input NAND Gate
    M54HC02 Rad-Hard Quad 2-Input NOR Gate
    M54HC03 Rad-Hard Quad 2-Input NAND (Open Drain)
    M54HC04 Rad-Hard Hex Inverter
    M54HC08 Rad-Hard Quad 2-Input AND Gate
    M54HC10 Rad-Hard Triple 3-Input NAND Gate
    M54HC109 Rad-Hard Dual J-K Flip-Flop With Preset & Clear
    M54HC11 Rad-Hard Triple 3-Input AND Gate
    M54HC123 Rad-Hard Dual Retrigg. Monostable Multivibrator with Clear
    M54HC125 Rad-Hard Quad Bus Buffer (3-State)
    M54HC132 Rad-Hard Quad 2-Input Schmitt NAND Gate
    M54HC137 Rad-Hard 3 to 8 Line Decoder Latch (Inv.); Rad-Hard 3-to-8 Line Decoder Latch Inverter
    M54HC138 Rad-Hard 3 to 8 Line Decoder (Inv.)
    M54HC139 Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
    M54HC14 Rad-Hard Hex Schmitt Inverter
    M54HC148 Rad-Hard 8-to-3 Line Priority Encoder
    M54HC151 Rad-Hard 8-Channel Multiplexer
    M54HC153 Rad-Hard Dual 4-Channel Multiplexer
    M54HC154 Rad-Hard 4 to 16 Line Decoder/Demultiplexer
    M54HC157 Rad-Hard Quad 2-Channel Multiplexer
    M54HC158 Rad-Hard Quad 2-Channel Multiplexer (Inverting)
    M54HC160 Rad-Hard Synchronous Decade Counter With Async. Clear
    M54HC161 Rad-Hard Synchronous Binary Counter With Async. Clear
    M54HC163 Rad-Had MSynchronous Binary Counter With Sync. Clear
    M54HC164 Rad-Hard 8 Bit SIPO Shift Register
    M54HC165 Rad-Hard 8 Bit PISO Shift Register
    M54HC166 Rad-Hard 8 Bit PISO Shift Register
    M54HC174 Rad-Hard Hex D-Type Flip-Flop with Clear
    M54HC175 Rad-Hard Quad D-Type Flip-Flop With Clear
    M54HC191 Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
    M54HC193 Rad-Hard Synchronous Up/Down Binary Counter
    M54HC194 Rad-Hard 4-bit PIPO Shit Register
    M54HC20 Rad-Hard Dual 4-Input NAND Gate
    M54HC21 Rad-Hard Dual 4-Input AND Gate
    M54HC237 Rad-Hard 3 to 8 Line Decoder Latch; Rad-Hard 3-to-8 Line Decoder Latch
    M54HC240 Rad-Hard Octal Bus Buffer (3-State/Inv.)
    M54HC241 Rad-Hard Octal Bus Buffer (3-State)
    M54HC244 Rad-Hard Octal Bus Buffer (3-State)
    M54HC245 Rad-Hard Octal Bus Transceiver (3-State)
    M54HC251 Rad-Hard 8-Channel Multiplexer (3-State)
    M54HC253 Rad-Hard Dual 4-Channel Multiplexer (3-State)
    M54HC257 Rad-Hard Quad 2-Channel Multiplexer (3-State)
    M54HC259 Rad-Hard 8-bit Adressable Latch
    M54HC27 Rad-Hard Triple 3-Input NOR Gate
    M54HC273 Rad-Hard Octal D-Type Flip-Flop with Clear
    M54HC283 Rad-Hard 4-bit Binary Full Adder
    M54HC30 Rad-Hard 8-Input NAND Gate
    M54HC32 Rad-Hard Quad 2-Input OR Gate
    M54HC365 Rad-Hard Hex Bus Buffer (3-State)
    M54HC367 Rad-Hard Hex Bus Buffer (3-State)
    M54HC373 Rad-Hard Octal D-Type Latch (3-State)
    M54HC374 Rad-Hard Octal D-Type Flip-Flop (3-State)
    M54HC393 Rad-Hard Dual Binary Counter
    M54HC4002 Rad-Hard Dual 4-Input NOR Gate
    M54HC4020 Rad-Hard 14-Stage Binary Counter
    M54HC4040 Rad-Hard 12-Stage Binary Counter
    M54HC4049 Rad-Hard Hex Buffer/Converter (Inv.)
    M54HC4050 Rad-Hard Hex Buffer/Converter
    M54HC4051 Rad-Hard Single 8-Channel Analog Multiplexer/Demultiplexer
    M54HC4053 Rad-Hard Triple 2-Channel Analog Multiplexer/Demultiplexer; Rad-Hard Triple 2-Channel Analog Mux/Demux
    M54HC4060 Rad-Hard 14-Stage Binary Counter/Oscillator
    M54HC4066 Rad-Hard Quad Bilateral Switch
    M54HC4072 Rad-Hard Dual 4-Input OR Gate
    M54HC4075 Rad-Hard Triple 3-Input OR Gate
    M54HC4078 Rad-Hard 8-Input Nor/OR Gate
    M54HC4094 Rad-Hard 8-bit SIPO Shit Register 3-State
    M54HC4514 Rad-Hard 4 to 16 Line Decoder Latch
    M54HC540 Rad-Hard Octal Bus Buffer (3-State/Inv.)
    M54HC541 Rad-Hard Octal Bus Buffer (3-State)
    M54HC573 Rad-Hard Octal D-Type Latch (3-State)
    M54HC574 Rad-Hard Octal D-Type Flip-Flop (3-State)
    M54HC590 Rad-Hard 8 Bit Binary Counter Register (3-State)
    M54HC595 Rad-Hard 8 Bit Shift Register Output Latch (3-State)
    M54HC597 Rad-Hard 8 Bit Latch Shift Register; Rad-Hard 8 Bit Latch/Shift Register
    M54HC688 Rad-Hard 8 Bit Equality Comparator
    M54HC73 Rad-Hard Dual J-K Flip-Flop With Clear
    M54HC74 Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
    M54HC75 Rad-Hard 4-Bit D-Type Latch
    M54HC85 Rad-Hard 4-Bit Magnitude Comparator
    M54HC86 Rad-Hard Quad Exclusive OR Gate
    M54HCT240 Rad-Hard Octal Bus Buffer 3-State Inverter
    M54HCT244 Rad-Hard Octal Bus Buffer (3-State)
    M54HCT245 Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-State
    M54HCT373 Rad-Hard Octal D-Type Latch 3-State
    M54HCT374 Rad-Hard Octal D-Type Flip-Flop 3-State
    M54HCT74 Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
    M54HCU04 Rad-Hard Hex Inverter Single Stage
    抗辐射VCX: 超低电压16位总线接口
    型号 概述
    54VCXH162244 Rad-Hard 16-bit Transceiver Non Inverting
    54VCXH162245 Rad-Hard 16-bit Transceiver 3-state Non Inverting
    54VCXH162373 Rad-Hard 16-bit D-Type Latch 3-state
    54VCXH162374 Rad-Hard 16-bit D-Type Flip-Flop 3-state
    54VCXH163245 Rad-hard 16-bit transceiver, 1.8 V to 3.3 V bi-directional level shifter
    54VCXHR162245 Rad-Hard 16-bit Transceiver Non Inverting with Resistor
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
