龙人旗下深圳市龙芯世纪科技有限公司
  • STR9(ARM)–32位微控制器选型指南
  • 发布时间:2012/7/7 11:14:50   修改时间:2012/7/7 11:14:50 浏览次数:3225
    STR9(ARM)–32位微控制器产品系列
    1. STR910FM32
    2. STR910FW32
    3. STR911FM42
    4. STR911FM44
    5. STR912FW42
    6. STR912FW44
    STR9(ARM) 技术参数
    Generic Part Number Package Internal ROM Size kilobytes  Internal RAM Size  12 or 16-bit timer (IC/OC/PWM)  I/Os (High Current) Supply Voltage(Vcc)  Other Functions 数据手册datasheet下载
    STR910FAM32 TQFP 80 12X12X1.4 - 1.0 256 65536 7x16-bit (8/8/7) 40(16) 2.7V-3.6V 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC, ETM Trace, CPU supply voltage: 1.8V STR910FAM32
    STR910FAW32 TQFP 128 14x14x1.4 1.0 256 65536 7x16-bit (8/8/7) 80 (16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR910FAW32
    STR910FAZ32 LFBGA 10x10x1.7 144 F12x12 0.8 256 65536 7x16-bit (8/8/7) 80 (16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR910FAZ32
    STR911FAM42 TQFP 80 12X12X1.4 - 1.0 256 98304 7x16-bit (8/8/7) 40(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAM42
    STR911FAM44 TQFP 80 12X12X1.4 - 1.0 512 98304 7x16-bit (8/8/7) 40(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAM44
    STR911FAM46 TQFP 80 12X12X1.4 - 1.0 1024 98304 7x16-bit (8/8/7) 40(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAM46
    STR911FAM47 TQFP 80 12X12X1.4 - 1.0 2048 98304 7x16-bit (8/8/7) 40(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAM47
    STR911FAW42 TQFP 128 14x14x1.4 1.0 256 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC, ETM Trace, CPU supply voltage: 1.8V STR911FAW42
    STR911FAW44 TQFP 128 14x14x1.4 1.0 512 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAW44
    STR911FAW46 TQFP 128 14x14x1.4 1.0 1024 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAW46
    STR911FAW47 TQFP 128 14x14x1.4 1.0 2048 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR911FAW47
    STR912FAW42 TQFP 128 14x14x1.4 1.0 256 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR912FAW42
    STR912FAW44 TQFP 128 14x14x1.4 1.0 512 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR912FAW44
    STR912FAW46 TQFP 128 14x14x1.4 1.0 1024 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR912FAW46
    STR912FAW47 TQFP 128 14x14x1.4 1.0 2048 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, Tamper Detect, EMI, CPU supply voltage: 1.8V STR912FAW47
    STR912FAZ42 LFBGA 10x10x1.7 144 F12x12 0.8 256 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR912FAZ42
    STR912FAZ44 LFBGA 10x10x1.7 144 F12x12 0.8 512 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR912FAZ44
    STR912FAZ46 LFBGA 10x10x1.7 144 F12x12 0.8 1024 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR912FAZ46
    STR912FAZ47 LFBGA 10x10x1.7 144 F12x12 0.8 2048 98304 7x16-bit (8/8/7) 80(16) 2.7 96MHz ARM9E CPU core, 9xDMA, Brown-out warning, 3-ph AC MC unit, ETM Trace, EMI, CPU supply voltage: 1.8V STR912FAZ47
    STR9(ARM) 订购型号:
    1. STR910FAW32X6:256+32 Flash 存储器,64KB 的片内RAM,CAN, 40 I/Os,封装形式LQFP128,14x14 mm
    2. STR910FAZ32H6:256+32 Flash 存储器,64KB 的片内RAM,CAN,EMI, 80 I/Os,封装形式LFBGA144 ,10 x 10 x 1.7
    3. STR911FAM42X6:256+32 Flash 存储器,96KB 的片内RAM,USB, CAN, 40 I/Os,封装形式LQFP80 12x12mm
    4. STR911FAM44X6:512+32 Flash 存储器,96KB 的片内RAM,USB, CAN, 40 I/Os,封装形式LQFP80 12x12mm
    5. STR911FAW42X6:256+32 Flash 存储器,96KB 的片内RAM,USB, CAN, EMI, 80 I/Os,封装形式LQFP128 14x14mm
    6. STR911FAW44X6:512+32 Flash 存储器,96KB 的片内RAM,USB, CAN, EMI, 80 I/Os,封装形式LQFP128 14x14mm
    7. STR912FAW34X6:512+32 Flash 存储器,64KB 的片内RAM, Ethernet, USB, CAN, EMI, 80 I/Os,封装形式LQFP128
    8. STR912FAW42X6:256+32 Flash 存储器,96KB 的片内RAM,Ethernet, USB, CAN, EMI, 80 I/Os,封装形式LQFP128
    9. STR912FAW44X6:512+32 Flash 存储器,96KB 的片内RAM,Ethernet, USB, CAN, EMI, 80 I/Os,封装形式LQFP128
    10. STR912FAZ42H6:256+32 Flash 存储器,96KB 的片内RAM,Ethernet, USB, CAN, EMI, 80 I/Os,封装形式LFBGA144 10 x 10 x 1.7
    11. STR912FAZ44H6:512+32 Flash 存储器,96KB 的片内RAM,Ethernet, USB, CAN, EMI, 80 I/Os,封装形式LFBGA144 10 x 10 x 1.7
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
