龙人旗下深圳市龙芯世纪科技有限公司
  • ST7 选型指南
  • 发布时间:2012/7/7 11:21:28   修改时间:2012/7/7 11:21:28 浏览次数:2278
  • ST7 选型指南
    Generic Part Number Package Marketing Status Program Memory Type Internal ROM Size Internal RAM Size A/D Converter 12 or 16-bit timer (IC/OC/PWM) 8-bit timer (IC/OC/PWM) Other timer functions Serial Interface I/Os (High Current) Supply Voltage(Vcc) Supply Voltage(Vcc) Other Functions 数据手册
    DataSheet
    下载
    nom nom min max
    kB B V V
    ST72104G1 PDIP 32 .4 Cu .25 Shrink; SO28 Active FLASH 4 256 - 1x16-bit (2/2/1) - WDG SPI 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72104G1
    ST72104G2 SO28 Active FLASH 8 256 - 1x16-bit (2/2/1) - WDG SPI 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72104G2
    ST72124J2 TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 - 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 32(4) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72124J2
    ST72215G2 PDIP 32 .4 Cu .25 Shrink; SO28 Active FLASH 8 256 6x8-bit 2x16-bit (4/4/2) - WDG SPI 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72215G2
    ST72216G1 PDIP 32 .4 Cu .25 Shrink; SO28 Active FLASH 4 256 6x8-bit 1x16-bit (2/2/1) - WDG SPI 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72216G1
    ST72254G2 PDIP 32 .4 Cu .25 Shrink; SO28 Active FLASH 8 256 6x8-bit 2x16-bit (4/4/2) - WDG SPI/I2C 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72254G2
    ST72260G1 SO28 Active FLASH 4 256 - 2x16-bit (4/4/2) - WDG, RTC SPI 22(8) 2.7 5.5 ROP, ICP, IAP, PLL, nested interrupts ST72260G1
    ST72262G1 SO28 Active FLASH 4 256 6x10-bit 2x16-bit (4/4/2) - WDG, RTC SPI 22(8) 2.7 5.5 ROP, ICP, IAP, PLL, nested interrupts ST72262G1
    ST72262G2 PDIP 32 .4 Cu .25 Shrink; SO28 Active FLASH 8 256 6x10-bit 2x16-bit (4/4/2) - WDG, RTC SPI 22(8) 2.7 5.5 ROP, ICP, IAP, PLL, nested interrupts ST72262G2
    ST72264G1 SO28 Active FLASH 4 256 6x10-bit 2x16-bit (4/4/2) - WDG, RTC SPI/SCI/I2C 22(8) 2.7 5.5 ROP, ICP, IAP, PLL, nested interrupts ST72264G1
    ST72264G2 SO28 Active FLASH 8 256 6x10-bit 2x16-bit (4/4/2) - WDG, RTC SPI/SCI/I2C 22(8) 2.7 5.5 ROP, ICP, IAP, PLL, nested interrupts ST72264G2
    ST72314J2 TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 6x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 32(4) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72314J2
    ST72314J4 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 16 512 6x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 32(4) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72314J4
    ST72314N4 TQFP 64 14x14x1.4 1 Active FLASH 16 512 8x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 44(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72314N4
    ST72321AR6 TQFP 64 10x10x1.4 1 Active FLASH 32 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 not recommended for new design (use ST72321BAR6) ST72321AR6
    ST72321AR7 TQFP 64 10x10x1.4 1 Active FLASH 48 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 not recommended for new design (use ST72321BAR7) ST72321AR7
    ST72321AR9 TQFP 64 10x10x1.4 1 Active FLASH 60 2048 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 not recommended for new design (use ST72321BAR9) ST72321AR9
    ST72321BAR6 TQFP 64 10x10x1.4 1 Active FLASH 32 1024 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BAR6
    ST72321BAR7 TQFP 64 10x10x1.4 1 Active FLASH 48 1536 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BAR7
    ST72321BAR9 TQFP 64 10x10x1.4 1 Active FLASH 60 2048 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BAR9
    ST72321BJ6 TQFP 44 10x10x1.4 1.0 Active FLASH 32 - 12X10-bit 2x16-bit (3/3/2) 1(0/4/4) WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BJ6
    ST72321BJ7 TQFP 44 10x10x1.4 1.0 Active FLASH 48 - 12X10-bit 2x16-bit (3/3/2) 1(0/4/4) WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BJ7
    ST72321BJ9 TQFP 44 10x10x1.4 1.0 Active FLASH 60 2048 12X10-bit 2x16-bit (3/3/2) 1(0/4/4) WDG, RTC SPI/SCI/I2C 32(12) 3.2 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BJ9
    ST72321BK6 LQFP 32 7x7x1.4 1 Active FLASH 32 1024 - - - WDG, RTC SPI/SCI/I2C - 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BK6
    ST72321BR7 TQFP 64 14x14x1.4 1 Active FLASH 48 1536 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BR7
    ST72321BR9 TQFP 64 14x14x1.4 1 Active FLASH 60 2048 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.2 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321BR9
    ST72321J7 TQFP 44 10x10x1.4 1.0 Active FLASH 48 - 12X10-bit 2x16-bit (3/3/2) 1(0/4/4) WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 Upgraded by ST72321BJ7 ST72321J7
    ST72321J9 TQFP 44 10x10x1.4 1.0 Active FLASH 60 - 12X10-bit 2x16-bit (3/3/2) 1(0/4/4) WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 Upgraded by ST72321BJ9 ST72321J9
    ST72321M6 TQFP 80 14x14x1.4 1 Active FLASH 32 1024 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 64(16) 3.8 5.5 Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321M6
    ST72321M9 TQFP 80 14x14x1.4 1 Active FLASH 60 2048 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 64(16) 3.8 5.5 Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72321M9
    ST72321R6 TQFP 64 14x14x1.4 1 Active FLASH 32 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 not recommended for new design (use ST72321BR6) ST72321R6
    ST72321R9 TQFP 64 14x14x1.4 1 Active FLASH 60 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 not recommended for new design (use ST72321BR9) ST72321R9
    ST72324BJ2 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BJ2
    ST72324BJ4 TQFP 44 10x10x1.4 1.0 Active FLASH 16 512 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BJ4
    ST72324BJ6 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH; ROM 32 - 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BJ6
    ST72324BK2 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH; ROM 8 384 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BK2
    ST72324BK4 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 16 512 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BK4
    ST72324BK6 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH; ROM 32 - 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324BK6
    ST72324J2 TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 Upgraded by ST72324BJ2 ST72324J2
    ST72324J4 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 16 512 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 Upgraded by ST72324BJ4 ST72324J4
    ST72324J6 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 32 - 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 Upgraded by ST72324BJ6 ST72324J6
    ST72324K2 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 8 384 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 Upgraded by ST72324BK2 ST72324K2
    ST72324K4 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 16 512 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 Upgraded by ST72324BK4 ST72324K4
    ST72324K6 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 32 - 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 Upgraded by ST72324BK6 ST72324K6
    ST72324LJ2 TQFP 44 10x10x1.4 1.0 Active FLASH; ROM 8 384 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LJ2
    ST72324LJ4 TQFP 44 10x10x1.4 1.0 Active FLASH; ROM 16 512 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LJ4
    ST72324LJ6 TQFP 44 10x10x1.4 1.0 Active FLASH 32 1024 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LJ6
    ST72324LK2 LQFP 32 7x7x1.4 1 Active FLASH; ROM 8 384 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LK2
    ST72324LK4 LQFP 32 7x7x1.4 1 Active FLASH 16 512 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LK4
    ST72324LK6 LQFP 32 7x7x1.4 1 Active FLASH 32 1024 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LK6
    ST72324LS2 LQFP 48 7x7x1.4 1 Active FLASH 8 384 12x10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LS2
    ST72324LS4 LQFP 48 7x7x1.4 1 Active FLASH 16 512 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 2.85 3.6 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72324LS4
    ST72325AR9 TQFP 64 10x10x1.4 1 Active FLASH 60 2048 16x10-bit 2x16-bit (4/4/2) 1 (2/4/4) CSS,WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325AR9
    ST72325J4 TQFP 44 10x10x1.4 1.0 Active FLASH 16 512 12X10-bit 2x16-bit (3/3/2) 1 (0/4/4) CSS, WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325J4
    ST72325J6 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 32 - 12X10-bit 2x16-bit (3/3/2) 1 (0/4/4) CSS, WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325J6
    ST72325J7 TQFP 44 10x10x1.4 1.0 Active FLASH 48 1536 12x10-bit 2x16-bit (3/3/2) 1 (0/4/4) CSS,WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325J7
    ST72325K4 LQFP 32 7x7x1.4 1 Active FLASH 16 512 8X10-bit 2x16-bit (3/3/1) 1 (0/3/3) CSS,WDG, RTC SPI/SCI/I2C 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325K4
    ST72325K6 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 32 1024 8X10-bit 2x16-bit (3/3/1) 1 (0/3/3) CSS,WDG, RTC SPI/SCI/I2C 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325K6
    ST72325R9 TQFP 64 14x14x1.4 1 Active FLASH 60 - 16x10-bit 2x16-bit (4/4/2) 1 (2/4/4) CSS,WDG, RTC SPI/SCI/I2C 48(16) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325R9
    ST72325S4 LQFP 48 7x7x1.4 1 Active FLASH 16 512 12X10-bit 2x16-bit (3/3/2) 1 (0/4/4) CSS, WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325S4
    ST72325S6 LQFP 48 7x7x1.4 1 Active FLASH 32 1024 12X10-bit 2x16-bit (3/3/2) 1 (0/4/4) CSS, WDG, RTC SPI/SCI/I2C 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72325S6
    ST7232AJ2 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 12X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 32(12) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST7232AJ2
    ST7232AK1 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 4 384 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST7232AK1
    ST7232AK2 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 8 384 8X10-bit 2x16-bit (3/3/1) - WDG, RTC SPI/SCI 24(10) 3.8 5.5 ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST7232AK2
    ST72334J2 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 8 384 6x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 32(4) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72334J2
    ST72334J4 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 16 512 6x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 32(4) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72334J4
    ST72334N4 TQFP 64 14x14x1.4 1 Active FLASH 16 512 8x8-bit 2x16-bit (3/3/2) - WDG, RTC SPI/SCI 44(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP, beep (Audio Square Wave Generator) ST72334N4
    ST72344K4 LQFP 32 7x7x1.4 1 Active FLASH 16 1024 8x10-bit 2x16-bit (3/3/2) - WWDG, RTC SPI/SCI/I2C 22(10) 2.7 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST72344K4
    ST72344S4 TQFP 44 10x10x1.4 1.0 Active FLASH 16 1024 12x10-bit 2x16-bit (3/3/2) - WWDG, RTC SPI/SCI/I2C 32(12) 2.7 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST72344S4
    ST72345C4 LQFP 48 7x7x1.4 1 Active FLASH 16 1024 12x10-bit 2x16-bit (3/3/2) - WWDG, RTC SPI/SCI/I2C/i2C slave 3-Addr. 34(12) 2.7 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST72345C4
    ST72361AR6 TQFP 64 10x10x1.4 1 Active FLASH 32 - 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI 48(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361AR6
    ST72361AR7 TQFP 64 10x10x1.4 1 Active FLASH 48 2048 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI 48(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361AR7
    ST72361J6 TQFP 44 10x10x1.4 1.0 Active FLASH 32 - 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI 34(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361J6
    ST72361J7 TQFP 44 10x10x1.4 1.0 Active FLASH 48 - 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI 34(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361J7
    ST72361J9 TQFP 44 10x10x1.4 1.0 Active FLASH 60 - 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI 34(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361J9
    ST72361K6 LQFP 32 7x7x1.4 1 Active FLASH 32 - 6x10-bit 1x16-bit (2/2/1) 1(1/1/3) WWDG, RTC SPI/ 2xSCI 24(5) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361K6
    ST72361K7 LQFP 32 7x7x1.4 1 Active FLASH 48 - 6x10-bit 1x16-bit (2/2/1) 1(1/1/3) WWDG, RTC SPI/ 2xSCI 24(5) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361K7
    ST72361K9 LQFP 32 7x7x1.4 1 Active FLASH 60 - 6x10-bit 1x16-bit (2/2/1) 1(1/1/3) WWDG, RTC SPI/ 2xSCI 24(5) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), AWU ST72361K9
    ST72521AR9 TQFP 64 10x10x1.4 1; TQFP 64 14x14x1.4 1 Active FASTROM; FLASH 60 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C/CAN 48(16) 3.8 5.5 Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator), CAN (2.0B passive) ST72521AR9
    ST72521R9 TQFP 64 14x14x1.4 1 Active FASTROM; FLASH 60 - 16x10-bit 2x16-bit (4/4/2) 1(2/4/4) WDG, RTC SPI/SCI/I2C/CAN 48(16) 3.8 5.5 Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator), CAN (2.0B passive) ST72521R9
    ST72561AR4 TQFP 64 10x10x1.4 1 Active FLASH 16 1024 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI/CAN 48(16) 4.5 5.5 Nested Interrupts,TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, window watchdog, AWU ST72561AR4
    ST72561AR6 TQFP 64 10x10x1.4 1 Active FLASH 32 - 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI/CAN 48(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561AR6
    ST72561AR7 TQFP 64 10x10x1.4 1 Active FLASH 48 2048 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI/CAN 48(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561AR7
    ST72561AR9 TQFP 64 10x10x1.4 1 Active FLASH 60 - 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI/CAN 48(6) 4.5 5.5 Nested Interrupts,TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561AR9
    ST72561J4 TQFP 44 10x10x1.4 1.0 Active FLASH 16 1024 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI/CAN 34(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561J4
    ST72561J6 TQFP 44 10x10x1.4 1.0 Active FLASH 32 - 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI/CAN 34(6) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561J6
    ST72561J9 TQFP 44 10x10x1.4 1.0 Active FLASH 60 - 11x10-bit 1x16-bit (2/2/1) 1(2/1/5) WWDG, RTC SPI/2xSCI/CAN 34(6) 4.5 5.5 Nested Interrupts,TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561J9
    ST72561K6 LQFP 32 7x7x1.4 1 Active FLASH 32 - 6x10-bit 1x16-bit (2/2/1) 1(1/1/3) WWDG, RTC SPI/2xSCI/CAN 24(5) 4.5 5.5 Nested Interrupts, TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561K6
    ST72561K9 LQFP 32 7x7x1.4 1 Active FLASH 60 - 6x10-bit 1x16-bit (2/2/1) 1(1/1/3) WWDG, RTC SPI/2xSCI/CAN 24(5) 4.5 5.5 Nested Interrupts,TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561K9
    ST72561R9 TQFP 64 14x14x1.4 1 Active FLASH 60 - 16x10-bit 1x16-bit (2/2/1) 2(4/2/5) WWDG, RTC SPI/2xSCI/CAN 48(6) 4.5 5.5 Nested Interrupts,TLI, ROP, SCIs with LIN features (LINSCI), CAN 2.0B active, AWU ST72561R9
    ST7260E1 SO 24 .30 TO JEDEC MS-013AD Active FLASH 4 384 - 1x16-bit (2/1/1) - WDG USB/SCI 14(6) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7260E1
    ST7260E2 SO 24 .30 TO JEDEC MS-013AD Active FLASH 8 384 - 1x16-bit (2/1/1) - WDG USB/SCI 14(6) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7260E2
    ST7260K1 VFQFPN 6X6X1.0 40L PITCH 0.5 SAW Active FLASH 4 384 - 1x16-bit (2/2/1) - WDG USB/SCI 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7260K1
    ST7260K2 VFQFPN 6X6X1.0 40L PITCH 0.5 SAW Active FLASH 8 384 - 1x16-bit (2/2/1) - WDG USB/SCI 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7260K2
    ST72621J4 PDIP 42 .6 Cu .25 SHRINK; TQFP 44 10x10x1.4 1.0 Active FLASH 16 768 8x10-bit - 2(2/2/2) WDG USB/SPI/SCI 31(8) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST72621J4
    ST72621L4 SO 34 SHRINK 7.5 mm Active FLASH 16 768 8x10-bit - 2(2/2/2) WDG USB/SPI/SCI 23(8) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST72621L4
    ST72622L2 SO 34 SHRINK 7.5 mm Active FLASH 8 384 8x10-bit - 2(2/2/2) WDG USB/SPI 23(8) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST72622L2
    ST72623F2 SO20 Active FLASH 8 384 3x10-bit - 2(2/2/2) WDG USB 11(8) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST72623F2
    ST7263BE1 SO 24 .30 TO JEDEC MS-013AD Active FLASH 4 384 - 1x16-bit (2/1/1) - WDG USB/SCI/I2C 14(6) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BE1
    ST7263BE2 SO 24 .30 TO JEDEC MS-013AD Active FLASH 8 384 - 1x16-bit (2/1/1) - WDG USB/SCI/I2C 14(6) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BE2
    ST7263BE6 SO 24 .30 TO JEDEC MS-013AD Active FLASH 32 1024 - 1x16-bit (2/1/1) - WDG USB/SCI/I2C 14(6) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BE6
    ST7263BH2 LQFP 48 7x7x1.4 1 Active FLASH 8 384 12x8-bit 1x16-bit (2/2/1) - WDG USB/SCI/I2C 27(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BH2
    ST7263BH6 LQFP 48 7x7x1.4 1 Active FLASH 32 1024 12x8-bit 1x16-bit (2/2/1) - WDG USB/SCI/I2C 27(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BH6
    ST7263BK1 PDIP 32 .4 Cu .25 Shrink; SO 34 SHRINK 7.5 mm Active FASTROM; FLASH; ROM 4 384 8x8-bit 1x16-bit (2/2/1) - WDG USB 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BK1
    ST7263BK2 PDIP 32 .4 Cu .25 Shrink; SO 34 SHRINK 7.5 mm; VFQFPN 6X6X1.0 40L PITCH 0.5 SAW Active FASTROM; FLASH 8 384 8x8-bit 1x16-bit (2/2/1) - WDG USB/SCI 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BK2
    ST7263BK4 PDIP 32 .4 Cu .25 Shrink; SO 34 SHRINK 7.5 mm Active FASTROM; FLASH 16 512 8x8-bit 1x16-bit (2/2/1) - WDG USB/SCI/I2C 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BK4
    ST7263BK6 SO 34 SHRINK 7.5 mm Active FLASH 32 1024 8x8-bit 1x16-bit (2/2/1) - WDG USB/SCI/I2C 19(10) 4 5.5 3 low-speed USB endpoints, ICP, IAP, ROP ST7263BK6
    ST72651AR6 TQFP 64 10x10x1.4 1 Active FLASH 32 - 8x8-bit 1x16-bit (0/2/2) - WDG USB/DTC/I2C/SPI 47(11) 2.7 5.5 DSC, PVR, ROP, 5 full -speed USB endpoints, ICP,IAP ST72651AR6
    ST7DALIF2 SO20 Active FASTROM; FLASH 8 384 7x10-bit 1x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI/DALI 15(7) 2.4 5.5 1% internal RC oscillator, PLL, 32MHz timer, DALI, AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7DALIF2
    ST7FOXF1 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 4 384 5x10-bit 2x12-bit (1/4/4) 2x8-bit (0/0/0) WDG, RTC I2C 16(7) 4.5 5.5 Precise RC, AWU, ROP, ICP, IAP ST7FOXF1
    ST7FOXK1 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 4 384 10x10-bit 2x12-bit(1/4/4/) 2x8bit (1/0/0) WDG, RTC I2C 24(8) 4.5 5.5 Precise RC, AWU, ROP, ICP, IAP ST7FOXK1
    ST7FOXK2 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 8 384 10x10-bit 2x12-bit (1/4/4) 1x16-bit (2/2/2) 2(1/0/0) WDG, RTC I2C, SPI 24(8) 4.5 5.5 Precise RC, AWU, ROP, ICP, IAP ST7FOXK2
    ST7GEME4 SO 24 .30 TO JEDEC MS-013AD; VFQFPN24 5X5X1.0 PITCH0.65 SAWN Active ROM 16 768 - - 1(0/0/0) WDG USB/ISO7816 4(1) 4 5.5 Turnkey firmware from GEMALTO ST7GEME4
    ST7LCRDIE6 DICE Active ROM 16 768 - - 1(0/0/0) WDG USB/ISO7816 no serial 1 4 5.5 Light ROM version for USB token ST7LCRDIE6
    ST7LCRE4U1 VFQFPN24 5X5X1.0 PITCH0.65 SAWN Active ROM 16 768 - - 1(0/0/0) WDG USB/ISO7816 no serial 1 4 5.5 Light ROM version for USB token ST7LCRE4U1
    ST7LIT10BF0 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LIT10BF0
    ST7LIT10BF1 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LIT10BF1
    ST7LIT10BY0 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LIT10BY0
    ST7LIT10BY1 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LIT10BY1
    ST7LIT15BF0 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT15BF0
    ST7LIT15BF1 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT15BF1
    ST7LIT15BY0 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT15BY0
    ST7LIT15BY1 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT15BY1
    ST7LIT19BF0 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT19BF0
    ST7LIT19BF1 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 17(7) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT19BF1
    ST7LIT19BY0 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 2 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT19BY0
    ST7LIT19BY1 PDIP 16 .3 Cu .25 STD; SO16L Active FLASH 4 256 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 13(5) 2.7 5.5 1% internal RC oscillator, PLL, 32MHz timer, ART with deadtime and enhanced one pulse mode, AWU, ADC with op-amp, Analog Comp., ROP, ICP, IAP, Debug module ST7LIT19BY1
    ST7LITE02Y0 PDIP 16 .3 Cu .25 STD; SO16 Active FASTROM; FLASH 1.5 128 - 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC SPI 13(6) 2.4 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST7LITE02Y0
    ST7LITE05Y0 PDIP 16 .3 Cu .25 STD; SO16 Active FASTROM; FLASH 1.5 128 5x8-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC SPI 13(6) 2.4 5.5 1% internal RC oscillator, PLL, ADC with op-amp, ROP, ICP, IAP ST7LITE05Y0
    ST7LITE09Y0 PDIP 16 .3 Cu .25 STD; SO16 Active FASTROM; FLASH 1.5 128 5x8-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC SPI 13(6) 2.4 5.5 1% internal RC oscillator, PLL, ADC with op-amp, ROP, ICP, IAP ST7LITE09Y0
    ST7LITE19F1 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 4 256 7x10-bit 1x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 15(7) 2.4 5.5 1% internal RC oscillator, PLL, 32MHz timer, AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LITE19F1
    ST7LITE20F2 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 8 384 7x10-bit 1x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 15(7) 2.4 5.5 PLL, AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LITE20F2
    ST7LITE25F2 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 8 384 7x10-bit 1x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 15(7) 2.4 5.5 1% internal RC oscillator, PLL, 32MHz timer, AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LITE25F2
    ST7LITE29F2 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 8 384 7x10-bit 1x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI 15(7) 2.4 5.5 1% internal RC oscillator, PLL, 32MHz timer, AWU, ADC with op-amp, ROP, ICP, IAP, Debug module ST7LITE29F2
    ST7LITE35F2 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 8 384 7x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC SPI/LINSCI 15(7) 2.7 5.5 1% internal RC oscillator, PLL, AWU, ROP, ICP, IAP, Debug module ST7LITE35F2
    ST7LITE39F2 PDIP 20 .3 Cu 0.25; SO20 Active FLASH 8 384 7x10-bit 2x12-bit (1/4/4) 1(1/0/0) WDG, RTC SPI/LINSCI 15(7) 2.7 5.5 1% internal RC oscillator, PLL, AWU, ROP, ICP, IAP, Debug module ST7LITE39F2
    ST7LITE49K2 LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 8 384 10x10-bit 2x12-bit (1/4/4), 1x16-bit (2/2/2) 2x8-bit(1/0/0) - SPI, I2C 24(8) 2.4 5.5 8MHz internal RC oscillator, ART with deadtime and enhanced one pulse mode, AWU, ROP, ICP, IAP, debug module ST7LITE49K2
    ST7LITE49M LQFP 32 7x7x1.4 1; PDIP 32 .4 Cu .25 Shrink Active FLASH 4 384 10x10-bit 2x12-bit (1/4/4) 2(1/0/0) WDG, RTC I2C 24(8) 2.4 5.5 8MHz internal RC oscillator, ART with deadtime and enhanced one pulse mode, AWU, ROP, ICP, IAP, debug module ST7LITE49M
    ST7LITES2Y0 PDIP 16 .3 Cu .25 STD; SO16 Active FASTROM; FLASH 1 128 - 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC SPI 13(6) 2.4 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST7LITES2Y0
    ST7LITES5Y0 PDIP 16 .3 Cu .25 STD; SO16 Active FASTROM; FLASH 1 128 5x8-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC SPI 13(6) 2.4 5.5 1% internal RC oscillator, PLL, ROP, ICP, IAP ST7LITES5Y0
    ST7LITEU09 PDIP8; SO8 Active FLASH 2 128 5x10-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC - 5(5) 2.4 5.5 8MHz internal RC oscillator, AWU, ROP, ICP, IAP, 5 I/Os + 1 additional output ST7LITEU09
    ST7LNB0V2Y0 SO16 Active ROM 1.5 128 - - - - - 13(6) 4.5 5.5 DiSEqC? 2.1 interface, 22 kHz tone detector ST7LNB0V2Y0
    ST7LNB1Y0 SO16 Active ROM 1.5 128 - - - - - 13(6) 4.5 5.5 DiSEqC? interface, SatCR control ST7LNB1Y0
    ST7MC1K2 LQFP 32 7x7x1.4 1 Active FASTROM; FLASH; ROM 8 384 8x10-bit 1x16-bit (2/2/1) 1(1/0/1) WWDG LINSCI 17(3) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts ST7MC1K2
    ST7MC1K4 LQFP 32 7x7x1.4 1 Active FASTROM; FLASH; ROM 16 768 8x10-bit 1x16-bit (2/2/1) 1(1/0/1) WWDG LINSCI 17(3) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts ST7MC1K4
    ST7MC2M9 TQFP 80 14x14x1.4 1 Active FLASH 60 1536 16x10-bit 2x16-bit (2/2/2) 1(2/0/4) WWDG LINSCI/SPI 60(12) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts, beep (Audio Square Wave Generator) ST7MC2M9
    ST7MC2R6 TQFP 64 14x14x1.4 1 Active FLASH 32 1024 16x10-bit 2x16-bit (2/2/2) 1(2/0/4) WWDG LINSCI/SPI 44(12) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts, beep (Audio Square Wave Generator) ST7MC2R6
    ST7MC2R7 TQFP 64 14x14x1.4 1 Active FASTROM; FLASH 48 1536 16x10-bit 2x16-bit (2/2/2) 1(2/0/4) WWDG LINSCI/SPI 44(12) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts, beep (Audio Square Wave Generator) ST7MC2R7
    ST7MC2S4 TQFP 44 10x10x1.4 1.0 Active FASTROM; FLASH; ROM 16 768 11x10-bit 2x16-bit (2/2/1) 1(1/0/1) WWDG LINSCI/SPI 26(6) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts ST7MC2S4
    ST7MC2S6 TQFP 44 10x10x1.4 1.0 Active FASTROM; FLASH 32 1024 11x10-bit 2x16-bit (2/2/1) 1(1/0/1) WWDG LINSCI/SPI 26(6) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts ST7MC2S6
    ST7MC2S7 TQFP 44 10x10x1.4 1.0 Active FLASH 48 1536 11x10-bit 2x16-bit (2/2/1) 1(1/0/1) WWDG LINSCI/SPI 26(6) 4.5 5.5 Sensorless brushless motor control cell, ICD, ICP, IAP, LVD, CSS/PLL, ROP, RTC, nested interrupts ST7MC2S7
    ST7SCR1E4 SO 24 .30 TO JEDEC MS-013AD Active FLASH 16 768 - - 1(0/0/0) WDG USB/ISO7816 4(1) 4 5.5 Smartcard power supply unit, ISO7816, 7 full -speed USB endpoints, ICP,IAP, 4 LED outputs ST7SCR1E4
    ST7SCR1R4 TQFP 64 14x14x1.4 1 Active FLASH 16 768 - - 1(0/0/0) WDG USB/ISO7816 35(4) 4 5.5 Smartcard power supply unit, ISO7816, 7 full -speed USB endpoints, ICP,IAP, 4 LED outputs ST7SCR1R4
    ST72254G1 PDIP 32 .4 Cu .25 Shrink NRND FLASH 4 256 6x8-bit 2x16-bit (4/4/2) - WDG SPI/I2C 22(8) 3.2 5.5 RC oscillator, clock security system, ISP, ROP ST72254G1
    ST72681 LQFP 48 7x7x1.4 1 NRND ROM - - - - - - USB 2.0 HS - 3 3.6 Mass Storage Controller Interface, Reed-Solomon error correction engine ST72681
    ST72682 TQFP 64 10x10x1.4 1 NRND ROM - - - - - - USB 2.0 HS - 3 3.6 Mass Storage Controller Interface, Reed-Solomon error correction engine ST72682
    ST7FOXA0 PDIP8; SO8 NRND FLASH 2 128 5 x 10-bit 1 x 12-bit (0/1/1) 1 x 8-bit (1/0/0) - - 6(5) 4.5 5.5 precise RC, AWU, ROP, ICD; IAP ST7FOXA0
    ST7LITEU05 PDIP8; SO8 NRND FLASH 2 128 5x10-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC - 5(5) 2.4 5.5 8MHz internal RC oscillator, AWU, ROP, ICP, IAP, 5 I/Os + 1 additional output ST7LITEU05
    ST72323 TQFP 44 10x10x1.4 1.0 Proposal ROM 8 384 12x10-bit 12x16-bit (3/3/1) - WDG, RTC SPI 32(12) 3.8 5.5 RC [6-8MHz], ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72323
    ST72323L TQFP 44 10x10x1.4 1.0 SLUG DOWN Proposal ROM 8 384 12x10-bit 12x16-bit (3/3/1) - WDG, RTC SPI 32(12) 2.85 3.6 RC [6-8MHz], ICP, IAP, Nested interrupts, TLI, ROP, beep (Audio Square Wave Generator) ST72323L
    ST72652C4 TQFP 48 7x7x1.0 1.0 Exp Pad Down Proposal ROM 16 512 - - - WDG USB/DTC 31(5) 4 5.5 PVR, ROP, 5 full-speed USB endpoints ST72652C4
    ST7267C8 TQFP 48 7x7x1.0 1.0 Exp Pad Down Proposal ROM 54 - - 1x16-bit (2/2/1) 1(0/0/0) WDG SPI/USB 2.0 HS 26(8) 2.7 3.6 Mass Storage Controller Interface, Reed-Solomon error correction engine ST7267C8
    ST7267R8 TQFP 64 10x10x1.4 1.0 SLUG DOWN Proposal ROM 54 - - 1x16-bit (2/2/1) 1(0/0/0) WDG SPI/USB 2.0 HS 40(8) 2.7 3.6 Mass Storage Controller Interface, Reed-Solomon error correction engine ST7267R8
    ST7LITEUS2 PDIP8; SO8; VFDFPN 4.5X3.5X1.0 8L PITCH 0.8 Proposal FASTROM 1 128 - 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC - 5(5) 2.4 5.5 8MHz internal RC oscillator, AWU, ROP, ICP, IAP, 5 I/Os + 1 additional output ST7LITEUS2
    ST7LITEUS5 PDIP8; SO8; VFDFPN 4.5X3.5X1.0 8L PITCH 0.8 Proposal FASTROM; FLASH 1 128 5x10-bit 1x12-bit (0/1/1) 1(1/0/0) WDG, RTC - 5(5) 2.4 5.5 8MHz internal RC oscillator, AWU, ROP, ICP, IAP, 5 I/Os + 1 additional output ST7LITEUS5
    ST7系列8位微控制器ST7系列单片机的内核是一个8位CPU,CPU中具有6个内部寄存器。ST7系列单片机内部集成低电压检测器(LVD)、看门狗、高抗干扰的电磁兼容电路。通过编程可实现读/写保护、多种低功耗模式等,片上外设包括10位多通道A/D转换器、SCI、SPI、I2C、USB和CAN接口,还有各种8位和16位带PWM功能的定时器。
    它的复位和时钟电路可以不用任何外部组件,内部的低电压检测器和一个完整的1% RC振荡器就能确保充分安全地启动单片机工作,从而是其应用成本降至最低。
    ST7系列单片机都建立在一个满足通用工业标准的8位CPU之上,具有增强的指令集。ST7系列的闪存具有可逐字节在线编程和在应用中编程的功能。ST7系列单片机有等待、慢速、暂停、掉电等多种低功耗工作模式。
    ST7内核使用基于行业标准的8位架构,并加以改进,使之支持高级语言编程,并提供额外的中断处理特性:。ST7 微控制器系列尤其适用于智能化电器、电机控制、汽车车身、家庭自动化及许多新兴的微控制应用。这一成熟的8位微控制器系列能够灵活地进行闪存编程,并且具备满足多种应用所需的可靠性。针对客户预算和需求,ST提供了一系列的方案。
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
