龙人旗下深圳市龙芯世纪科技有限公司
  • ST9 8位微控制器选型表
  • 发布时间:2012/7/7 11:25:17   修改时间:2012/7/7 11:25:17 浏览次数:4705
  • ST9 8位微控制器选型表
    Generic Part Number Marketing Status Package Core FLASH Size Internal RAM Size Data E2PROM A/D Converter 12 or 16-bit timer (IC/OC/PWM) 8-bit timer (IC/OC/PWM) Other timer functions Serial Interface Supply Voltage(Vcc) Supply Voltage(Vcc) Other Functions 数据手册DataSheet下载
    nom nom nom min max
    kB B B V V
    ST6201CM
    Automotive
    Proposal SO16 ST6 2 64 - 4x8-bit - 1(0/0/0) WDG - - - - ST6201CM
    Automotive
    ST62T52CM
    Automotive
    Active SO16L ST6 2 128 - 4x8-bit - 1+1(1/1/1) WDG - 3 6 - ST62T52CM
    Automotive
    ST62T62CM
    Automotive
    Active SO16L ST6 2 128 64 4x8bit - 1+1(1/1/1) WDG - 3 6 - ST62T62CM
    Automotive
    ST62T65CM
    Automotive
    Active SO28 ST6 4 128 128 13x8-bit - 1+1(1/1/1) WDG - 3 6 - ST62T65CM
    Automotive
    ST72124J2
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 8 384 - - 2(3/3/2) - WDG, RTC SPI, SCI - - Internal RC oscillator, clock security system ST72124J2
    Automotive
    ST72141K2
    Automotive
    Proposal SO 34 SHRINK 7.5 mm ST7 8 256 - 8x8-bit 2(4/4/2) - WDG SPI 4 5.5 Sensorless brushless permanent magnet DC motor controller ST72141K2
    Automotive
    ST72215G2
    Automotive
    Active SO28 ST7 8 256 - 6x8-bit 2(4/4/2) - WDG SPI 3.2 5.5 Internal RC oscillator, clock security system ST72215G2
    Automotive
    ST72254G2
    Automotive
    Active SO28 ST7 8 256 - 6x8-bit 2(4/4/2) - WDG SPI, I2C 3.2 5.5 Internal RC oscillator, clock security system ST72254G2
    Automotive
    ST72314J2
    Automotive
    NRND TQFP 44 10x10x1.4 1.0 ST7 8 384 - 6x8-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.2 5.5 Internal RC oscillator, clock security system ST72314J2
    Automotive
    ST72314J4
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 16 512 - 6x8-bit 2(3/3/2) - WDG, RTC SPI/SCI 3.2 5.5 Internal RC oscillator, clock security system, beep ST72314J4
    Automotive
    ST72314N4
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 16 512 - 8x8-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.2 5.5 Internal RC oscillator, clock security system, beep ST72314N4
    Automotive
    ST72321BAR6
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 32 1024 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BAR6
    Automotive
    ST72321BAR7
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 48 1536 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BAR7
    Automotive
    ST72321BAR9
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 60 2048 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BAR9
    Automotive
    ST72321BJ6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BJ6
    Automotive
    ST72321BJ7
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 48 1536 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BJ7
    Automotive
    ST72321BJ9
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 60 2048 - 10x12-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BJ9
    Automotive
    ST72321BLJ6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 10x12-bit 2(3/3/1) - WDG, RCT SPI, SCI 2.85 3.6 Nested interrupts, beep ST72321BLJ6
    Automotive
    ST72321BR6
    Automotive
    Active TQFP 64 14x14x1.4 1 ST7 32 1024 - 16x10-bit 2(4/4/2) 2(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BR6
    Automotive
    ST72321BR7
    Automotive
    Active TQFP 64 14x14x1.4 1 ST7 48 1536 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BR7
    Automotive
    ST72321BR9
    Automotive
    Active TQFP 64 14x14x1.4 1 ST7 60 2048 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Nested interrupts, beep ST72321BR9
    Automotive
    ST72324BJ2
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 8 384 - 12x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BJ2
    Automotive
    ST72324BJ4
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 16 512 - 12x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BJ4
    Automotive
    ST72324BJ6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 12x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BJ6
    Automotive
    ST72324BK2
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 8 384 - 8x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BK2
    Automotive
    ST72324BK4
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 16 512 - 8x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BK4
    Automotive
    ST72324BK6
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 32 1024 - 8x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST72324BK6
    Automotive
    ST72324BLJ4
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 16 512 - 12x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 2.85 3.6 Nested interrupts, beep ST72324BLJ4
    Automotive
    ST72324BLJ6
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 16x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3 3.6 Nested interrupts, beep ST72324BLJ6
    Automotive
    ST72324BLK4
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 16 512 - 16x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 2.85 5.5 Nested interrupts, beep ST72324BLK4
    Automotive
    ST72324BLK6
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 32 1024 - 16x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 2.85 3.6 Nested interrupts, beep ST72324BLK6
    Automotive
    ST72325AR6
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 32 1024 - 16x10-bit 2(4/4/2) 1(2/4/4) WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325AR6
    Automotive
    ST72325AR7
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 48 1536 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325AR7
    Automotive
    ST72325AR9
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 60 2048 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC, SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325AR9
    Automotive
    ST72325J4
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 16 512 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C - - Clock Security System, nested interrupts, beep ST72325J4
    Automotive
    ST72325J6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325J6
    Automotive
    ST72325J7
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 48 1536 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325J7
    Automotive
    ST72325J9
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 60 2048 - 12x10-bit 2(3/3/2) 1(0/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325J9
    Automotive
    ST72325K4
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 16 512 - - - - - - 3 5.5 Nested interrupts, beep ST72325K4
    Automotive
    ST72325K6
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 32 1024 - 8x10-bit 2(3/3/2) 1(0/2/2) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325K6
    Automotive
    ST72325R6
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 32 1024 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325R6
    Automotive
    ST72325R7
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 48 1536 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325R7
    Automotive
    ST72325R9
    Automotive
    Active TQFP 64 10x10x1.4 1; TQFP 64 14x14x1.4 1 ST7 60 2048 - 16x10-bit 2(4/4/2) 1(2/4/4) ART, WDG, RTC SPI, SCI, I2C 3.8 5.5 Clock Security System, nested interrupts, beep ST72325R9
    Automotive
    ST7232AK1
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 4 384 - 8x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST7232AK1
    Automotive
    ST7232AK2
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 8 384 - 8x10-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.8 5.5 Nested interrupts, beep ST7232AK2
    Automotive
    ST72334J2
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 8 384 256 6x8-bit 2(3/3/2) - WDG, RTC SPI, SCI 3.2 5.5 Internal RC oscillator, clock security system, beep ST72334J2
    Automotive
    ST72334J4
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 16 512 256 6x8-bit 2(3/3/2) - WDG, RTC SPI/SCI 3.2 5.5 Internal RC oscillator, clock security system, beep ST72334J4
    Automotive
    ST72361AR4
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 16 512 - 16x10-bit 1(2/2/1) 2(4/2/5) ART,WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, beep ST72361AR4
    Automotive
    ST72361AR7
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 48 1536 - 16x10-bit 1(2/2/1) 2(4/2/5) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, beep ST72361AR7
    Automotive
    ST72361AR9
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 60 2048 - 16x10-bit 1(2/2/1) 2(2/4/5) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, beep ST72361AR9
    Automotive
    ST72361J4
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 16 512 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361J4
    Automotive
    ST72361J6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361J6
    Automotive
    ST72361J7
    Automotive
    Proposal TQFP 44 10x10x1.4 1.0 ST7 48 1536 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361J7
    Automotive
    ST72361J9
    Auto
    Proposal TQFP 44 10x10x1.4 1.0 ST7 60 2048 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361J9
    Auto
    ST72361K4
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 16 512 - 6x10-bit 1(2/2/1) 1(1/1/3) ART, WWDG, RTC SPI, SCI, I2C 4.5 5.5 Clock Security System, nested interrupts, beep ST72361K4
    Automotive
    ST72361K6
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 32 1024 - 6x10-bit 1(2/2/1) 1(1/1/3) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Clock Security System, nested interrupts, beep ST72361K6
    Automotive
    ST72361K7
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 48 1536 - 6x10-bit 1(2/2/1) 1(1/1/3) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361K7
    Automotive
    ST72361K9
    Automotive
    Proposal LQFP 32 7x7x1.4 1 ST7 60 2048 - 6x10-bit 1(2/1/1) 1(1/1/3) ART, WWDG, RTC SPI, 2xSCI 4.5 5.5 Nested interrupts, beep ST72361K9
    Automotive
    ST72561AR4
    Automotive
    Active TQFP 64 10x10x1.4 1 - - - - - - - - - 4.5 5.5 - ST72561AR4
    Automotive
    ST72561AR6
    Automotive
    Active TQFP 64 10x10x1.4 1 ST7 32 1024 - 16x10-bit 1(2/2/1) 2(4/2/5) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561AR6
    Automotive
    ST72561AR7
    Automotive
    Active TQFP 64 10x10x1.4 1 - - - - - - - - - 4.5 5.5 - ST72561AR7
    Automotive
    ST72561J4
    Automotive
    Active TQFP 44 10x10x1.4 1.0 - - - - - - - - - 4.5 5.5 - ST72561J4
    Automotive
    ST72561J6
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 32 1024 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561J6
    Automotive
    ST72561J7
    Automotive
    Active TQFP 44 10x10x1.4 1.0 - - - - - - - - - 4.5 5.5 - ST72561J7
    Automotive
    ST72561J9
    Automotive
    Active TQFP 44 10x10x1.4 1.0 ST7 60 2048 - 11x10-bit 1(2/2/1) 1(2/1/5) ART, WWDG, RTC SI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561J9
    Automotive
    ST72561K4
    Automotive
    Proposal LQFP 32 7x7x1.4 1 - - - - - - - - - 4.5 5.5 - ST72561K4
    Automotive
    ST72561K6
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 32 1024 - 6x10-bit 1(2/2/1) 1(1/1/3) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561K6
    Automotive
    ST72561K9
    Automotive
    Active LQFP 32 7x7x1.4 1 ST7 60 2048 - 6x10-bit 1(2/2/1) 1(1/1/3) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561K9
    Automotive
    ST72561R4
    Automotive
    Active TQFP 64 10x10x1.4 1; TQFP 64 14x14x1.4 1 - - - - - - - - - 4.5 5.5 - ST72561R4
    Automotive
    ST72561R6
    Automotive
    Proposal TQFP 64 10x10x1.4 1 ST7 32 1024 - 16x10-bit 1(2/2/1) 2(4/2/5) ART, WWDG, RTC SPI, 2xSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561R6
    Automotive
    ST72561R7
    Automotive
    Active TQFP 64 14x14x1.4 1 - - - - - - - - - 4.5 5.5 - ST72561R7
    Automotive
    ST72561R9
    Automotive
    Active TQFP 64 14x14x1.4 1 ST7 60 2048 - 16x10-bit 1(2/2/1) 2(4/2/5) ART, WWDG, RTC SPI, 2XSCI, CAN 4.5 5.5 Nested interrupts, (LINSCI), CAN 2.0B active ST72561R9
    Automotive
    ST7L05 NRND SO16 ST7 2 128 - 5x8-bit 1(0/1/1) 1(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L05
    ST7L09 NRND SO16 ST7 2 128 128 5x8-bit 1(0/1/1) 1(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L09
    ST7L15 NRND SO20 ST7 4 256 - 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L15
    ST7L19 NRND SO20 ST7 4 256 128 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L19
    ST7L34 Active SO20 ST7 8 384 - 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L34
    ST7L35 Active SO20 ST7 8 384 - 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI, LINSCI 3 5.5 Internal RC oscillator ST7L35
    ST7L38 Active SO20 ST7 8 384 256 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7L38
    ST7L39 Active SO20 ST7 8 384 256 7x10-bit 2(1/4/4) 2(1/0/0) ART, WDG, RTC SPI, LINSCI 3 5.5 Internal RC oscillator ST7L39
    ST7LU05 NRND SO8 ST7 2 128 - 5x10-bit 1(0/1/1) 1(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC osclillator ST7LU05
    ST7LU09 NRND SO8 ST7 2 128 128 5x10-bit 1(0/1/1) 1(1/0/0) ART, WDG, RTC SPI 3 5.5 Internal RC oscillator ST7LU09
    ST7LUS5 NRND SO8 ST7 1 128 - 5x10-bit 1(0/1/1) 1(1/0/0) ART, WDG, RTC - 3 5.5 Internal RC oscillator ST7LUS5
    ST7MC1K2
    Automotive
    NRND LQFP 32 7x7x1.4 1 ST7 8 384 - 8x10-bit 1(2/2/1) 1(1/0/1) ART, WWDG, RTC LINSCI 4.5 5.5 BLDC Motor Control cell, (LINSCI), Clock Security System ST7MC1K2
    Automotive
    ST7MC1K6
    Automotive
    NRND LQFP 32 7x7x1.4 1 ST7 32 384 - 8x10-bit 1(2/2/1) 1(1/0/1) ART, WWDG, RTC LINSCI 4.5 5.5 BLDC Motor Control cell, (LINSCI), Clock Security System ST7MC1K6
    Automotive
    ST92124R9T
    Automotive
    Active TQFP 64 14x14x1.4 1 ST9 64 2048 1024 16x10-bit 5(8/6/5) - WDG SPI, SCI, I2C 4.5 5.5 CAN 2.0B active, LIN master ST92124R9T
    Automotive
    ST92124V1Q
    Automotive
    Active PQFP 100 14x20x2.7 1.6 ST9 128 4096 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C 4.5 5.5 CAN 2.0B active, LIN master ST92124V1Q
    Automotive
    ST92124V1T
    Automotive
    NRND TQFP 100 14x14x1.4 1 ST9 128 4096 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C 4.5 5.5 CAN 2.0B active, LIN master ST92124V1T
    Automotive
    ST92150CR9T
    Automotive
    Active TQFP 64 14x14x1.4 1 ST9 64 2048 1024 16x10-bit 5(8/6/5) - WDG SPI, SCI, I2C, CAN 4.5 5.5 CAN 2.0B active, LIN master ST92150CR9T
    Automotive
    ST92150CV1Q
    Automotive
    Active PQFP 100 14x20x2.7 1.6 ST9 128 4096 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C, CAN 4.5 5.5 CAN 2.0B active, PLL clock, low power, LIN master ST92150CV1Q
    Automotive
    ST92150CV1T
    Automotive
    Active TQFP 100 14x14x1.4 1 ST9 128 4096 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C, CAN 4.5 5.5 CAN 2.0B active, LIN master ST92150CV1T
    Automotive
    ST92150CV9T
    Automotive
    Active TQFP 100 14x14x1.4 1 ST9 64 2048 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C, CAN 4.5 5.5 CAN 2.0B active, LIN master ST92150CV9T
    Automotive
    ST92150JDV1Q
    Automotive
    Active PQFP 100 14x20x2.7 1.6 ST9 128 6144 1024 16x10-bit 5(8/7/7) - WDG SPI, 2xSCI, I2C, 2xCAN, J1850 4.5 5.5 CAN 2.0B active, LIN master ST92150JDV1Q
    Automotive
    ST92150JDV1T
    Automotive
    Active TQFP 100 14x14x1.4 1 ST9 128 6144 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, I2C, 2xCAN, J1850 4.5 5.5 CAN 2.0B active, LIN master ST92150JDV1T
    Automotive
    ST92250CV2Q
    Automotive
    Active PQFP 100 14x20x2.7 1.6 ST9 256 8192 1024 16x10-bit 5(8/8/7) - WDG SPI,2x SCI, 2xI2C, CAN 4.5 5.5 CAN 2.0B active, LIN master ST92250CV2Q
    Automotive
    ST92250CV2T
    Automotive
    Active TQFP 100 14x14x1.4 1 ST9 256 8192 1024 16x10-bit 5(8/8/7) - WDG SPI, 2xSCI, 2xI2C, CAN 4.5 5.5 CAN 2.0B active, LIN master ST92250CV2T
    Automotive
    STM8AF5169 Proposal TQFP 64 10x10x1.4 1 STM8 32 2048 1024 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5169
    STM8AF5178 Proposal LQFP 48 7x7x1.4 1 STM8 48 3072 1024 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5178
    STM8AF5179 Preview TQFP 64 10x10x1.4 1 STM8 48 3072 1024 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5179
    STM8AF5188 Proposal LQFP 48 7x7x1.4 1 STM8 64 4096 1024 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5188
    STM8AF5189 Preview TQFP 64 10x10x1.4 1 STM8 64 4096 1024 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5189
    STM8AF5198 Preview LQFP 48 7x7x1.4 1 STM8 96 6144 2048 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5198
    STM8AF5199 Proposal TQFP 64 10x10x1.4 1 STM8 96 6144 2048 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF5199
    STM8AF519A Preview TQFP 80 14x14x1.4 1 STM8 96 6144 2048 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF519A
    STM8AF51A8 Evaluation LQFP 48 7x7x1.4 1 STM8 128 6144 2048 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF51A8
    STM8AF51A9 Preview TQFP 64 10x10x1.4 1 STM8 128 6144 2048 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF51A9
    STM8AF51AA Evaluation TQFP 80 14x14x1.4 1 STM8 128 6144 2048 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU CAN, LIN(UART) SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF51AA
    STM8AF6146 Proposal LQFP 32 7x7x1.4 1 STM8 16 2048 - 7x10-bit 2(6/6/6) 1(0/0/0) WDG, WWDG,AWU LIN(UART),SPI 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6146
    STM8AF6148 Proposal LQFP 48 7x7x1.4 1 STM8 16 2048 - 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6148
    STM8AF6166 Preview LQFP 32 7x7x1.4 1 STM8 32 2048 1.0-1024.0 7x10-bit 3(8/8/8) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6166
    STM8AF6168 Preview LQFP 48 7x7x1.4 1 STM8 32 2048 1 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6168
    STM8AF6169 Preview TQFP 64 10x10x1.4 1 STM8 32 2048 1.0-2.0 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6169
    STM8AF6176 Proposal LQFP 32 7x7x1.4 1 STM8 48 3072 1 7x10-bit 3(8/8/8) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6176
    STM8AF6178 Proposal LQFP 48 7x7x1.4 1 STM8 48 3072 1 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6178
    STM8AF6179 Proposal TQFP 64 10x10x1.4 1 STM8 48 3072 1 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6179
    STM8AF6186 Proposal LQFP 32 7x7x1.4 1 STM8 64 4096 1 7x10-bit 3(8/8/8) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6186
    STM8AF6188 Proposal LQFP 48 7x7x1.4 1 STM8 64 4096 1 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6188
    STM8AF6189 Proposal TQFP 64 10x10x1.4 1 STM8 64 4096 1 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6189
    STM8AF6198 Proposal LQFP 48 7x7x1.4 1 STM8 96 6144 2 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6198
    STM8AF6199 Proposal TQFP 64 10x10x1.4 1 STM8 96 6144 2 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF6199
    STM8AF619A Proposal TQFP 80 14x14x1.4 1 STM8 96 6144 2 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN-UART, SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF619A
    STM8AF61A8 Proposal LQFP 48 7x7x1.4 1 STM8 128 6144 2 10x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF61A8
    STM8AF61A9 Proposal TQFP 64 10x10x1.4 1 STM8 128 6144 2 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF61A9
    STM8AF61AA Proposal TQFP 80 14x14x1.4 1 STM8 128 6144 2.0-2048.0 16x10-bit 3(9/9/9) 1(0/0/0) WDG, WWDG,AWU LIN(UART), SPI, I2C, USART 3 5.5 Single-Wire Debug, Independent WDG Clock, 2 Internal RC Oscillators STM8AF61AA
    STM8AH61AA Evaluation TQFP 80 14x14x1.4 1 - - - - - - - - - - - - STM8AH61AA
    技术支持:
    1. 先进半导体解决方案的门电子. PDF
    2. 汽车的32位微控制器 对动力系统应用. PDF
    3. 意法半导体应用支持. PDF
    4. 参考指南. PDF
    5. 32位汽车微控制器底盘和安全应用. PDF
    6. 汽车的32位闪存微控制器汽车车身应用. PDF
    7. 汽车的32位闪存微控制器为群集应用程序. PDF
    8. 周围半导体机顶盒应用. PDF
    9. 汽车的8位闪存微控制器. PDF
    10. STM8S MCU系列8位微控制器. PDF
    11. STM32开发工具. PDF
    12. STM32,STR7和STR9开发工具 . PDF
    13. 8 ,16和32位微控制器产品和工具选择指南. PDF
    14. 电机控制选型指南. PDF
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
