龙人旗下深圳市龙芯世纪科技有限公司
  • OTP和UV可擦除EPROM选型指南
  • 发布时间:2012/7/7 11:25:46   修改时间:2012/7/7 11:26:20 浏览次数:2217
    3.3V Supply
    Generic Part Number Package Marketing Status Storage Capacity Supply Voltage(Vcc) Supply Voltage(Vcc) Memory Organization Address Access Time (tACC)(tACC) Chip Enable To Output Delay(tCE) Output Enable To Output Delay(tOE) General Description Programming Voltage(Vpp) Programming Current(IPP) Operating Temperature Operating Temperature 数据手册
    datasheet 下载
    spec min max nom nom nom nom nom min max
    Mb  ns  ns  ns  mA  °C  °C
    M27V160 PLCC 44 NRND 16 3 3.6 x8 / x16 100 100 50 Low Voltage OTP EPROM 12.5 50 0 70 M27V160
    M27V322 CDIP 42 LSI LENS 630X315 Active 32 3 3.6 x16 - 100 50 UV EPROM 12 50 0 70 M27V322
    5V Supply
    Generic Part Number Package Marketing Status Storage Capacity Supply Voltage(Vcc) Supply Voltage(Vcc) Memory Organization Address Access Time (tACC)(tACC) Chip Enable To Output Delay(tCE) Output Enable To Output Delay(tOE) General Description Operating Temperature Operating Temperature 数据手册
    datasheet 下载
    spec min max nom nom nom min max
    Mb  ns  ns  ns  °C  °C
    M27C1001 CDIP 32 .280 F/S WITH LENS MSI; PDIP 32 .6 Cu .25; PLCC 32 Active 1 4.5 5.5 x8 45.0-100.0 45.0-120.0 25.0-60.0 -; OTP EPROM; UV EPROM -40 85 M27C1001
    M27C160 CDIP 42 F/S LSI LENS 370x450; PDIP 42 .6 STD PITCH .100 Active 16 4.5 5.5 x8 / x16 100 100 50 OTP EPROM; UV EPROM 0 70 M27C160
    M27C2001 CDIP 32 .280 F/S WITH LENS MSI; PLCC 32 Active 2 4.5 5.25 x8 70 70.0-100.0 35.0-50.0 -; OTP EPROM; UV EPROM -40 85 M27C2001
    M27C256B CDIP 28 .526 F/S LENS 280; PDIP 28 .6 Cu .25; PLCC 32 Active 0 4.5 5.25 x8 90.0-100.0 45.0-120.0 25.0-60.0 -; OTP EPROM; UV EPROM -40 85 M27C256B
    M27C322 CDIP 42 F/S LSI LENS 370x450 Active 32 4.5 5.5 x8 / x16 - 100 50 UV EPROM 0 70 M27C322
    M27C4001 CDIP 32 .280 F/S WITH LENS MSI; PDIP 32 .6 Cu .25; PLCC 32 Active 4 4.5 5.25 x8 55.0-100.0 35.0-100.0 20.0-50.0 OTP EPROM; UV EPROM -40 85 M27C4001
    M27C4002 CDIP 40 LEAD MSI WITH LENS.300; PDIP 40 .6 Cu .25; PLCC 44 Active 4 4.5 5.25 x16 70.0-100.0 45.0-120.0 25.0-60.0 OTP EPROM; UV EPROM -40 85 M27C4002
    M27C512 CDIP 28 .526 F/S LENS 280; PDIP 28 .6 Cu .25; PLCC 32 Active 1 4.5 5.25 x8 90 45.0-120.0 25.0-50.0 -; OTP EPROM; UV EPROM -40 85 M27C512
    M27C64A CDIP 28 .526 F/S LENS 280 Active 0 4.5 5.5 x8 - 100 50 UV EPROM 0 70 M27C64A
    M27C801 CDIP 32 .280 F/S WITH LENS MSI; PDIP 32 .6 Cu .25; PLCC 32 Active 8 4.5 5.5 x8 50.0-100.0 50.0-100.0 30.0-50.0 OTP EPROM; UV EPROM -40 85 M27C801
    M87C257 PLCC 32 NRND 32768 4.5 5.5 x8 90 90 40 - 0 70 M87C257
    3V Supply
    Generic Part Number Package Marketing Status Storage Capacity Memory Organization Address Access Time (tACC)(tACC) Chip Enable To Output Delay(tCE) Output Enable To Output Delay(tOE) General Description Programming Voltage(Vpp) Programming Current(IPP) Operating Temperature Operating Temperature 数据手册
    datasheet 下载
    spec nom nom nom nom nom min max
    M27W101 PLCC 32 Active 1 x8 80 80 50 Low Voltage OTP EPROM 12.75 50 -40 85 M27W101
    M27W201 PDIP 32 .6 Cu .25; PLCC 32 Active 2 x8 80 80 50 Low Voltage UV EPROM 12.75 50 -40 85 M27W201
    M27W401 PDIP 32 .6 Cu .25; PLCC 32 Active 4 x8 80 80 50 Low Voltage OTP EPROM 12.75 50 -40 85 M27W401
    M27W512 PLCC 32 Active 1 x8 100 100 60 Low Voltage OTP EPROM 12.75 50 -40 85 M27W512
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
