龙人旗下深圳市龙芯世纪科技有限公司
  • 交流开关选型表
  • 发布时间:2012/7/7 11:34:07   修改时间:2012/7/7 11:34:07 浏览次数:2177
  • 交流开关选型表
    ACS双向三端晶闸管
    ACS Triac 或 ACST,可用作双向开关三极管(Triac),且提高了电压瞬变箍制和吸收能力。 这种器件和系统可成功地吸收负载交换以及电源线路产生的瞬变电压,如IEC 61000-4-5所述。 ACST 箍制和过压保护功能可保证系统和 ACST 安全的瞬间动作。 从而简化电路,不需要 MOV 或缓冲器电路。 这些器件关断电压达 800 V,可选择标准和逻辑电平门控。 器件采用 Fullpack、IPAK、DPAK、D2PAK 或 I2PAK 封装。
    Part Number Package General Description RMS on-state current(IT(RMS)) max (A) Repetitive peak off-state voltage(VDRM/VRRM) max (V) Non repetitive surge peak on-state current(ITSM) max (A) Junction Temperature(Tj) max (°C) Quadrants Clamping Voltage(VCL) (@100μA) min (V) Rate of decrease of commutating on-state current((dI/dt)c min) (@Tj max) min (A/ms) Rising Ratio Of Off Voltage(dv/dt) (@Tj max) min (V/μs) Marketing Status
    ACST10 TO-220
    TO-220FP
    Overvoltage protected AC switch 10 700 100 125 I, II, III 850 4.4 200 Active
    ACST12 D2PAK D-TRACK
    TO-220
    Overvoltage protected AC switch 12 700 120 125 I, II, III 850 5.3 200 Active
    ACST2 DPAK
    TO-220FP
    Overvoltage protected AC switch 2 800 8 125 I, II, III 850 0.5 500 Active
    ACST4 DPAK
    TO-220FP
    Overvoltage protected AC switch 4 800 30 125 I, II, III - 2 500 Active
    ACST6 D2PAK D-TRACK
    I2PAK DT
    TO-220
    TO-220FP
    Overvoltage protected AC switch 6 800 45 125 I, II, III 850 3.5 500 Active
    ACST8 D2PAK D-TRACK
    TO-220
    TO-220FP
    Overvoltage protected AC switch 8 800 80 125 I, II, III 850 8 2000 Active
    ACS逻辑电平门
    ACS are static-switch semiconductors for alternating current. They are simple-to-drive, sensitive-gate devices with highly inductive load switch-off capability. They are targeted at appliance actuators, such as water valves and drain pumps. Their logic-level gate characteristics allow direct input from the microcontroller. The high immunity of the device reduces the need for MOVs and snubbers in the circuit. These devices have a 600 V blocking capability with further clamping and crowbar features for large overvoltage transients. They are available in SO-8, SO-20, SOT-223 or TO-92 packages.
    Part Number Package General Description RMS on-state current(IT(RMS)) max (A) Repetitive peak off-state voltage(VDRM/VRRM) max (V) Non repetitive surge peak on-state current(ITSM) max (A) Junction Temperature(Tj) max (°C) Quadrants Clamping Voltage(VCL) (@1mA) min (V) Rate of decrease of commutating on-state current((dI/dt)c min) (@Tj max) min (A/ms) Rising Ratio Of Off Voltage(dv/dt) (@Tj max) min (V/μs) Marketing Status
    ACS102-6T SO-8;
    TO-92 GLASS
    Overvoltage protected AC switch 0.2 600 7.3 125 II, III 650 0.15 300 Active
    ACS108-6S SMB F3
    SOT-223
    TO-92 GLASS
    Overvoltage protected AC switch 0.8 600 7.3 125 II, III 650 0.3 500 Active
    ACS110 SOT-223 Overvoltage protected AC switch 1 700 8 125 II, III 750 0.5 500 Active
    ACS120 DPAK
    TO-220
    TO-220FP
    Overvoltage protected AC switch 2 700 20 125 II, III 750 1 500 Active
    ACS302 SO-20 Overvoltage protected triple AC switch 0.2 500 7.3 125 II, III 600 0.15 300 Active
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
